NVidia bumpgate
  • piernov
    • Jan 2016
    • 4437
    • France
    NVidia bumpgate
    Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
    Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
    May complete this post at a later date with more details.
    Basically issue is a combination of thermal dissipation of the chip with hotspot, generating mechanical stress due to thermal expansion, wrong underfill material and wrong bump material.
    It's not the solder balls between the chip and the board.
    Chips affected are mostly from 2006-2008.
    MCP and GPUs are affected, both in laptops and desktops.
    Some articles list G86, G86A2, G84, C51, G72, G72M, G73, G72A3, MCP67 and NV42. But these aren't the only ones, some G9x and other MCPs were affected too.
    That's some later GeForce 6000, almost all GeForce 7000, almost all GeForce 8000, some early GeForce 9000. Affected MCPs are MCP5x (northbridge only, not southbridge), MCP6x and early MCP7x.
    NVidia started producing fixed revision for some affected chips in the summer of 2008. Some defective ones were still produced a bit after that.
    Fixed revision of affected chips got a new underfill material that's white rather than dark, so it should be easy to recognize them. They'll typically have a datecode after 0830, and some of them have an odd digit instead of an even digit at the end of the model number (eg. G84-603-A2 instead of G84-602-A2).
    Note that some chips were still using the bad bump material with the good underfill material (early 9600M) but they're much less prone to failure than earlier series.
    Fixed chips include most G84/G86, most of them are still available at see-ic.
    Attached is a copy of the pages if ever links get broken. File is *not* a zip, it's a tar.xz but uploaded with .zip extension, so .zip extension must be removed after downloading.
    • 21103
    Re: NVidia bumpgate
    Stickied .Very useful info ,thanks .
    • FrozenHaxor
      • Jun 2015
      • 260
      • Poland
      Re: NVidia bumpgate
      It's so good of you to bring this back, people forget far too quickly about it. There is even a video with Jensen admitting to the faults on camera:
      https://www.youtube.com/watch?v=QZB6kxxgnOQ
      AMD chips I find to be very prone to this failure mode across many years, people reflow or reball them thinking it's the fix, while all that happens is the micro bumps shift a bit renewing the failed connection for a limited time.
      • piernov
        • Jan 2016
        • 4437
        • France
        Re: NVidia bumpgate
        Thanks, somehow I had never seen this video. What he's saying and what happened don't really sound exactly the same strangely enough… Not really "admitting" to much.
        About ATi/AMD unfortunately I've never heard of any failure analysis. (and of course they never cared about some of their chips having a pretty high failure rate)
        • mosfetratus
          Sure Not
          • Feb 2019
          • 174
          • Resistron
          Re: NVidia bumpgate
          laughing at xbox 360 and ps3 reballers xD.
          i think it was a huge cover up, because microsoft and sony didn't stated exact reason for failed GPU chips.
          • TechGeek
            Computer Geek
            • Jan 2015
            • 2254
            Re: NVidia bumpgate
            Just had an Asus M2N68-LA (from a Compaq SR-5130NX) motherboard quit on me. Started as intermittent no-POSTing, then it got extremely hard to make it POST. And somewhere in the process, the audio controller totally disappeared from the system, never to return.
            EDIT: Up and running on a Compaq SR-5404F from early-2008. Bumpgated??
            Permanently Retired Systems:
            Kooky and Kool Systems
            sigpic
            • Dan81
              SNES-powered
              • Oct 2013
              • 1866
              • Romania
              Re: NVidia bumpgate
              6100 and 6150 wree hot garbage for quite a long time already, and a sea of dead Turion based dv2000,6000 and 9000 should be the biggest proof ever.
              It's a miracle these do survive a bit longer on mobos though. At least I've rarely seen them fail, unless they're the unified version - for example, look at the M2NPV-VM and M2N-VM. The former is the classic config of NB+ SB - GF6150 and nForce 430, while the M2N-VM seems to be the unified version, as there's just one big heatsink covering the whole chip.
              Then there's the 7025 and 7150s. How bad are those?
              Main rig:
              Gigabyte B75M-D3H
              Core i5-3470 3.60GHz
              16GB DDR3-1600
              Samsung SH-224AB DVD-RW
              Delux MG760 case
              • TechGeek
                Computer Geek
                • Jan 2015
                • 2254
                Re: NVidia bumpgate
                Would adding external cooling to the chipset heatsink help extend the lifespan?
                Just added an HSF from an Athlon XP-era heatsink directly onto the chipset heatsink in the Compaq SR5404F, the surviving twin of the two Compaq towers. I've got it running directly off of the PSU's 12V rail at full speed- always running as long as the system's turned on.
                sigpic
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  Re: NVidia bumpgate
                  Cooling it like that helps a lot!
                  • TechGeek
                    Computer Geek
                    • Jan 2015
                    • 2254
                    Re: NVidia bumpgate
                    Good to hear. Hopefully it lasts a lot longer than the system that came before it.
                    sigpic
                    • Octal450
                      • Jun 2019
                      • 4
                      Re: NVidia bumpgate
                      Same exact fault on X360 graphics chips from ATi/TSMC. MS even admits this a bit vaguely (due to the audience target being non-technicians). Was never the solder
                      Kind Regards,
                      Josh
                      • Admin
                        Other Useful Threads - Laptop Screen Compatibility, Useful ICs, BGA Chip Suppliers, NVidia bumpgate
                        by Admin
                        Some sticky topics have been moved to this thread:
                        - finding a compatible laptop screen with LED-backlight.
                        Most Common ICs - a list of the most common ICs (Integrated Circuits) required for repairing a laptop
                        MOST COMMON IC FOR LAPTOP YOU SHOULD HAVE IN STOCK
                        Let's Talk About BGA Chip Suppliers - anyone who repairs computers at component level has had to order chips from China at some point. Large BGA chips like graphics chips, chipsets and now CPUs are in increasing demand, due to their...
                        12-27-2023, 03:43 AM
                      • ugamazing
                        Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                        by ugamazing
                        I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                        08-31-2022, 07:34 AM
                        NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                        The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                        10-02-2024, 08:52 AM
                        NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                        The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                        10-02-2024, 07:51 AM
                        NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
                        The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
                        10-01-2024, 01:54 PM
