HP Pavilion Laptop Motherboard Not Starting Up DA0R53MB6E1
  • Zentech
    • Feb 2021
    • 94
    • Usa
    Ok, I have an HP Pavilion Motherboard that is not starting up. The model is DA0R53MB6E1 REV E R53. I got the schematic from HERE. I went through the startup voltage sequence. and I have detected the following.
    -- CHARGER CIRCUIT --
    19V ok at charger circuit.
    pu8 is giving out ACPRES (which if I'm not mistaken is charger voltage connected)
    PU8 ACDET I'm getting 2.7v
    -- POWER SUPPLY 5VALW/3VALW --
    PU7 has 19v VIN
    REF 2V
    HAVE 19V on drain of PQ50 and PQ53, but no 5V or 3V output
    could it be the chip? I don't have oscilloscope to see the lgate/ugate pulse to mosfet, just voltmeter. looking for advise here.
    any help appreciated
    thanks
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP Pavilion Laptop Motherboard Not Starting Up
    This is how you should check a 3/5V regulator:
    01.Check VIN
    02.VREG3 & VREG5
    03.ENABLE
    04.POWERGOOD
    05.ENTRIP1
    06.ENTRIP2
    Measute these pins and report back.
    • Zentech
      • Feb 2021
      • 94
      • Usa
      01.Check VIN
      02.VREG3 & VREG5
      03.ENABLE
      04.POWERGOOD
      05.ENTRIP1
      06.ENTRIP2
      Measure these pins and report back.
      ok.. I just measure the voltages and this is what I found (power bt off)
      Code:
      VIN 19V
      VRE5 5V
      VRE3 3V
      EN0 3.2V
      POWERGOOD 0V
      ENC 0V
      ENTRIP1 0V
      ENTRIP2 0V
      I didn't know which of the two EN was enabled, I assume is EN0, but just in case I measure ENC too... I guess POWERGOOD goes the the KBC saying we're good to go... but is not there!
      any help appreciated. Thanks
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        ENC-This is the Enable for this IC and this signal comes from kbc pin48 as S5_ON. Since this is missing, you need to check the basic requirement of kbc like Pin11/121/124/18/21/69/123/14/4
        You can remove the resistor PR93 and inject 3V on IC side of this resistor to see if you get 3v/5V on coil.
        • Zentech
          • Feb 2021
          • 94
          • Usa
          pin 11 VCC = 1.2 should be 3V Acording to schematic
          pin 121 VPCU = 3.2V
          pin 124 ECPWROK = 1.1V
          this are my findings.. I didn't continue b/c I'm missing VCC which is only 1.2 and it should be 3V. Where does this 3V comes from? is this 3VALW? does the 3V/5V VPC needs ENC from kbc in order to provide 3/5V? if this is the case where does 3V on pin 11 (vcc) come from?
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            C451 and R406 are connected with this pin. Try removing them and see if 3V appears there. What is the resistance on Pin11?? Note the resistance before removing C451/R406 and re-check the resistance after removing these components.
            • Zentech
              • Feb 2021
              • 94
              • Usa
              for some reason R406 is not in the motherboard, I think this went through some revision and they removed it or something because the number is there but the actual resistor is missing. I've noticed this with several other components.... where does this 3V come from? is it 3VPCU or 3V_S5? or internally from EC?
              this are the measurement from EC
              11 VCC = 1.2 should be 3V According to schmtic
              121 VPCU = 3.2V
              123 RSMRST = 0V
              124 ECPWROK = 1.1V
              21 ACIN = 3.1V
              69 AD_AIR = 2.7V
              18 LID_EC = 3.2V
              14 WRST = 3.1V
              4 EC_RCIN = 0.4V do I need this in order for the EC to come on?
              I also have 3V on SW1 (power on) and as soon as I press btn voltage drops on pin 125, which is what it should do; however the board is not coming on. I don't the the S5_ON for the ENC power supply.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                With VCC remaing low at 1.2V , there is no question of board getting on. Try removing the kbc, clean the pads and then apply power and see if you get 3v at pin11 of kbc. If you have the skills and eqipment, then give it a try or else go to a professional repair shop.
                • Zentech
                  • Feb 2021
                  • 94
                  • Usa
                  My question here's where does the 3V on VCC pin 11 come from? these are not 3V vreg from PU7, which is 3V,5V power supply. on the schematic it doesn't say where those 3V come from. Usually you see a page number. Once you press power btn, KBC sends signal to PU7 which is 3V,5VALW and enable those, and from there South Bridge gets engage. But where does 3V come from?
                  PS: the reason that I come here, like many other, is because we lack specialized knowledge, like in this case laptop motherboard. Even if you have knowledge of electronic repair, you still need to understand how a laptop motherboard powers up. No one knows everything from start. I'm sure at some point you didn't know either.
                  thanks for the help
                  • paulo66
                    • Dec 2020
                    • 88
                    • Portugal
                    There is a boardview file for this board.
                    https://drive.google.com/file/d/1v4P...UsNkK88Xa/view
                    This one in particular offers limited info so you still need the schematics for parts names and values. For instance, R406 is zero ohms, and it leads to 116 other components.
                    The KBC_P+3V must be derived from the +3.3v linear output of pu7. Which reads normal, right? One of those 116 parts must be sinking a bit of current.
                    What is the voltage across pin 8 of the bios chip?
                    Good luck.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      @Zentech, If you are interested only on knowing wherefrom +3V on VCC of kbc comes from- then the answer is +3V LDO. You have LDO voltage but still voltage at VCC pin is low and that's where you need to focus on. You didnt follow what is suggested and keep on asking the same question again and again. Remove the kbc, clean the pads and check voltage at VCC pin. If it is stable 3V, your kbc is bad else you need to put it back.
                      • paulo66
                        • Dec 2020
                        • 88
                        • Portugal
                        Is it safe to power up the unit without the kbc in place? On another thread I was told not to do that.
                        Ldo is vreg, right? If there's 3.3 present at pin 8 of pu7, and there's less than 2v at kbc, then there is some kind of isolation. Otherwise the voltage loss would come all the way down to pu7.
                        The fact that there is a 0.3v difference under normal conditions seems to point to a semiconductor drop.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          It is absolutely safe to power up without kbc. Yes LDO is vreg. I've explained and advised steps to solve the problem. If you are not convinced, you can explore more opinion from learned members of this forum or elsewhere. Thats your choice and i respect that.
                          • Zentech
                            • Feb 2021
                            • 94
                            • Usa
                            Good luck.
                            pin 8 BIOS 3.3V
                            thanks
                            • Zentech
                              • Feb 2021
                              • 94
                              • Usa
                              Good luck.
                              if one of these parts is sinking current/voltage and they're all connected to vreg pu7 3.3V why do I have 3.3V on 3VPCU ON KBC pin 121? if it is drawing voltage to ground and is all connected to same place? that's why I thought it was from a different place... I'm going to lift KBC to see if that makes any difference... thanks all for help
                              • paulo66
                                • Dec 2020
                                • 88
                                • Portugal
                                Second and third paragraphs in post #12. No answers yet, just speculating. Still trying to learn how the motherboards work at component level.
                                I´ve had a similar case with 1.8v ax pin 8 of the bios chip. Didn´t read the kbc vin because I didnt know what to look for. But the vreg was 3.3. The bios was defective.
                                • paulo66
                                  • Dec 2020
                                  • 88
                                  • Portugal
                                  It´s not a matter of being convinced or not. It´s just me trying to learn with the limited info available. Instead of just, you know, blindly following orders.
                                  I´m sure you know the old saying "Give a man a fish..." Maybe your knowledge is only empirical, and I respect that. Or maybe that´s your thing, in which case I´m out.
                                  • paulo66
                                    • Dec 2020
                                    • 88
                                    • Portugal
                                    One thing I forgot to mention: maybe your laconic approach is the type professionals want to read. Practical advice for a quick fix. No time for theory because of deadlines. No customer likes to wait. I respect that and maybe this forum is not the right place for hobbyists that like to zoom in.
                                    • paulo66
                                      • Dec 2020
                                      • 88
                                      • Portugal
                                      Last post in a row.
                                      What about injecting 3.3 at r406 (opposite side of the kbc) or at the kbc itself (pin 11)?
                                      • paulo66
                                        • Dec 2020
                                        • 88
                                        • Portugal
                                        Is there any continuity between kbc vdd and the +3v_rtc?
                                        Because there is only one point in the schematic where it´s clear the connection between +3vpcu and +3v. Page 7. Locate D11 and D12. D11 prevents the coin cell current from reaching the ldo output of pu7, or the low resistance would drain the battery quickly. D12 on the other hand prevents pu7 from charging up the coin cell. Which isn't rechargeable.
                                        They´re Schottkys. So all this is at the cost of D11 voltage drop of 0.3V. Hence +3V < 3.3V.
                                        Diodes fail open. If there is a connection between +3V_RTC and the KBC Vdd, maybe D11 is faulty and the remaining voltage comes out of a dying cmos battery.
                                          HP Pavilion Pavilion Laptop 14-dv0569sa Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Laptop 14-dv0569sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv0569sa boardview and Pavilion Laptop 14-dv0569sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-07-2024, 05:50 AM
                                          HP Pavilion Pavilion Laptop 14-dv0631sa Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Laptop 14-dv0631sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv0631sa boardview and Pavilion Laptop 14-dv0631sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          HP Pavilion Pavilion Laptop 14-dv2504sa Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Laptop 14-dv2504sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv2504sa boardview and Pavilion Laptop 14-dv2504sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          HP Pavilion Pavilion Laptop 14-dv2501sa Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Laptop 14-dv2501sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv2501sa boardview and Pavilion Laptop 14-dv2501sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          HP Pavilion Pavilion Laptop 14-dv0632sa Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Laptop 14-dv0632sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv0632sa boardview and Pavilion Laptop 14-dv0632sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
