RCA RLDED3258A-B wont turn on
  • Plaf70
    • Dec 2020
    • 9
    • canada
    RCA RLDED3258A-B, Board TP-MS3393.p81
    Stay in stanby, red light.
    Have change the eeprom but it seem the old one was ok.
    Now I have notice there is two photocoupler "L817"
    One show 17v on pin 1, 16v on pin 2, 68v on pin 3 and 67v on pin 4.
    The second on have nothing on pin 1 and 2. It is normal?
  • R_J
    • Jun 2012
    • 9535
    Re: RCA RLDED3258A-B wont turn on
    Photocoupler's are opto isolators, One side (pin1&2) are likely on the cold side, Pins 3&4 are on the HOT side and to check there voltage you must use HOT GROUND (main filter (-)
    It is not likely a photocoupler problem.
    Was the new eeprom pre programmed?
    • Plaf70
      • Dec 2020
      • 9
      • canada
      Thank you for your reply
      No, I have buy a new blank one but after programming and resolder it, I realise the bin file was maybe not the good one for this model. Have use "RCA RLDED3258A (25Q16BSIG)" from here. And I can program the older eeprom whitout any error. So it was probably not the problem.
      • neilc6
        • Nov 2015
        • 1550
        Still possibly the EEPROM. You should have froze the original one on the main board to see if the TV turned on and read and saved it before reprogramming it. I repaired a similar model by wiping the original EEPROM and reprogramming it.
        • Plaf70
          • Dec 2020
          • 9
          • canada
          Too late and I regret. I thought I had the right bin. I don't understand the versions are so close.
          • Plaf70
            • Dec 2020
            • 9
            • canada
            Well, I finally found the right file. Still nothing, stanby light that's all.
            The only difference is the eeprom I bought. It has the number 25q16csig instead of 25q16bsig, can that be the problem? Also, should I have used the lock function?
            I now need to check the voltages on the board. It is difficult since there are not many notes. I took the ones I have.
            Thank you for your time. Happy Holidays
            • pajdek
              Lenovo Y700-17ISK turn on and off
              by pajdek
              Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
              09-20-2023, 02:49 AM
            • SidneyCanadas
              93C46 and 93C56 EEPROM
              by SidneyCanadas
              I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
              https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
              Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
              06-14-2023, 01:16 PM
            • RdeveLabs
              MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
              by RdeveLabs
              To all the members here...
              Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
              So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
              05-05-2025, 04:59 AM
            • robante15
              Acer Aspire 4520 won't turn on after reboot
              by robante15
              Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
              It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
              The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
              If I remove the...
              04-06-2024, 06:50 PM
            • masoksian
              Dell latitude e7470 not turn on .power buton on off and Run Power problem
              by masoksian
              Hi everyone,
              I am dealing with the problem of turning on and off my Dell e7470 notebook.
              The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
              The system does not turn on, there is no post.
              I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
              The problem continues in the same way.
              I tried to turn on the Fn key, nothing came to the screen....
              02-15-2025, 12:08 PM
