Hello. I recently had 5 6.3v caps blow on my motherboard its an EVGA board and i am going to recap them myself. I just need to know what do I order? Going to order them from this site but just not familiar with any values other than they are 6.3 v? Thanks for any help.
New DIY recapper
Tags: None
Re: New DIY recapper
heres a pic of 2 of the caps ( pic sucks but best I can do atm sorry)
You can see the 2 under the red light are cracked and the 1 on the left is leaking out. Juts trying to figure out exactly what to order to replace them. AllI know is they are 6.3V.
[/IMG]
Looks like Sacon FZ. Is there a "FZ" marking in the first line on the top of the capacitors?
If yes, those are known to be problematic - would be a good idea to replace all that have the FZ marking all the way down to (and including) 470uF.
As far as cap replacements (brand and series), you can get Rubycon MBZ or MCZ here. There's also Panasonic FM at Digikey and Nichicon HM/HN/HZ at Mouser.
You need to provide the uF rating of the caps, though. The aforementioned FZ caps usually have it written above the voltage. If you're unsure, just write down all the info and numbers you see on the cap.Comment
they caps say
FZ5A
1500
6.3V
is 1500 the uF? What would you recomend to replace them if so?Comment
The 1500 is indeed the uF. Replace them with new 1500uF caps from a reliable manufacturer. Also, don't just replace the busted ones. Replace ALL Sacon FZ on the motherboard. Even if they are good now they will almost definately fail soon. Also, it is common for caps to fail with no visible signs. Any one of the series that momaka mentioned should be fine for replacments.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
Thanks for the replies. I ordered enough Rubycon caps to replace all the FZ caps on the mobo. Strangely all the caps that blew were all 6.3v FZ caps. When they blew I remember being at my computer and hearing a loud POP noise. At the time I had no idea what it was. For about 3 weeks time I would hear a loud POP on occasion. I finally narrowed the sound down to my PC and got a flashlight to look inside and saw the caps with the tops blown.
Anyway thanks again for the replies. I'll reply back after my order comes in and I replace them.I've done some minor electrical soldering on guitars/ amps but this will be my 1st computer soldering so wish me luck.Comment
Hope it all goes wellI love putting bad caps and flat batteries in fire and watching them explode!!
The "5A" is probably a date or a batch code.
You need to replace ALL the FZ's. - Every one.
- Unless you wanna do this again soon.
FZ are made by Sacon/Evercon who used to be GSC.
Google "GSC bad" or "Sacon FZ"
Here is the FZ data sheet.
You just need caps with:
- the same ESR or lower
- the same Ripple or higher
Technically FZ are rated a tad better than MBZ but FZ only come in 12mm and 12.5mm length.
By using longer caps in good brands you can get ESR and Ripple into the same range.
For example a 20mm ZL has slightly better specs than a 12mm or 12.5mm FZ with the same uF.
.Attached FilesLast edited by PCBONEZ; 11-27-2009, 10:51 PM.Mann-Made Global Warming.
- Dr Seuss
- Dr Seuss
I'm just getting everything I need together to do the replacement and waiting for the caps to get here so I'll be ready when they arrive. It'll be my 1st time doing this on a mobo but I have done some electrical soldering work before. I looked up FZ caps on google and they do have a bad reputation to say the least hehe. I just wish I knew what that loud POP noise was when they 1st blew. Scared the crap outta me lol. From the 1st POP to the last was about 3 weeks total. All 5 of the 1500uF 6.3V blew and the 1 of the 10V caps.
Thanks again for all the replies.Comment
The biggest difference with motherboards is they are thick so you need a higher wattage iron and it's good to avoid long thin tips. When you touch the iron to the joint the tip will cool right down. More mass in the tip minimizes that and higher watts means a shorter recovery time for the iron. If you don't have enough umpth behind it you will find you are slowly heating the whole board to solder melting temp rather than quickly melting the joint and getting off the board before the heat gets to other things. Some folks get by with a 40 watt but I think most prefer a 50-60 watt. A few even use 80-100 watt irons but I'd probably fry traces with one'a those. A 1.5-2.5mm chisel tip is about right. I did the first few mobos I did with a 40 watt but later found a 60 watt was much easier to use and faster too. Frys Electronics has a decent basic 60 watt for like $10-$15. [They do mail order from their website if you don't have one nearby.] If you plan to do this often a Hakko 926 or 936 station [both are the same inside, difference is visual] might be a good choice. They are 50 watt w/temp adjust, many tips sizes available, and are easy to find parts for. They show up fairly often on eBay and there is an eBay seller [in Hong Kong] that sells tips for like $2.
- Dr Seuss
what you can also do is pre-heat the entire board (i know some not everyone will agree) in the oven or with a hair dryer to about 50 or 60°C.
i found this can help with boards with large (and sometimes buried) power planes so the board doesn't suck away too much heat before the solder melts.
so far i haven't seen any disadvantages, i'd even say it reduces the thermal stress during the soldering process.
most component manufacturers recommend a specific soldering temp profile that includes pre-heating."Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. MenckenComment
That makes a lot of sense engineering wise kikkoman.
I'm too lazy to do it, but it makes total sense.Mann-Made Global Warming.
- Dr Seuss
I can't for the life of me figure out how to desolder chokes and other large components on some equipment. I use a hakko 60 watt station and tried with many different tips. What usually happens is that the component doesn't want to come out but the traces/plated holes sure love to lift off the pcb or burn into nothing.
The problem is the ground plane + the damn lead free solder. I never had problems with pre rohs equipment in the past. Environmentally friendly my ass. When you have a bunch of junk electronics where repair is a pain in the ass.Comment
Are you using solder wick?
- Dr Seuss
I first apply a bit more solder or flux and use solder suckers. The preheating method above would probably help it initially flow but it would be useless if you need to remove a lot of components due to rapid cooling. I'm considering a hotair system since I think it would help with the ground plane.Comment
I think you will find solder wick to be easier, especially on those big joints with gobs of solder.
- Dr Seuss
I got my caps today in the mail and went ahead to try out my hand at recapping about 2 hours ago. The iron I ordered stayed hot long enough to tin the tip then died to I had to dig out my dads old 1970s era iron and use it.Aftrer removing the mobo and the RAM gfx card I noticed on the gfx card there was a blown cap as well. So I replaced it too. It was an Evercon 1500uF 6.3V I replaced all the Sacon 6.3Vs and 2 Sacon 1500uF 10V. But I DID IT!!! After cleaning the case out and reinstalling everything I hooked it up and it works great! Below are a few before and after pics ( remember this is my 1st time doing this)
this last 1 is the bad Evercon on the GFX card:
Just wanna say thanks for all the help from everyone! Best 20$ I ever spent!Last edited by Keith41501; 12-03-2009, 09:56 PM.Comment
Thats just a pic right after i replaced the 6.3Vs I wasnt completely done yet.Comment
by coinwizxThe power supply is 2020 Corsair HX1200 modular power supply.
Cause of damage: I connected EVGA molex cable to the Sata port and test it with a ATX tester. Since the pin out on the EVGA is wrong, result in the 12V pin shorted to the 5V pin, in the 12V back-feeded to the 5v port.
Damage: Power supply shorted out, shut off itself internally, damaged the 5v or 3v rail or the monitoring circuitry. The self protection circuit shut off the power supply when power up because it detected some abnormal/defect. I waited a few minutes, let it self reset then try to re power up.... -
by coinwizxThe power supply is 2024 newest version of NZXT C850 modular power supply.
Damage: Power supply shorted out, shut off itself internally, damaged the 5v or 3v rail or the monitoring circuitry. The self protection circuit shut off the power supply when power up because it detected some abnormal/defect. I waited a few minutes, let it self reset then... -
by onix331Asking here as a last ditch effort:
GPU: EVGA RTX2070 Black Edition XC Gaming
A few weeks ago i noticed a burning electronics smell in my room, after a bit of confusion i realized that the RGB LED light of my GPU was out. Weird.
I didn't think much of it until i tried to look at the power usage in HWinfo, i then noticed that the entry "GPU Power (Total)" was gone entirely, it would also not boost above 1410Mhz.
Looking further i noticed that "Performance Limit - Utilization" was always at "Yes". The card did perform mostly...05-27-2024, 08:34 AM -
by s_henyaHi guys,
Got this EVGA GTX750TI 2GB GPU
MB Bios is beeping when GPU is connected.
When booting with onboard GPU, MB is booting but the GTX isn't showing in windows device manager.
I would like to reprogram the bios EVGA 750Ti 2GB non-6pin 82.07.55.00.50
I searched around but couldn't fins 256kb BIOS like mine.
Anyone can please assist?...-
Channel: BIOS & Schematic Requests!
by Rayvenhello everyone , im looking for a schematic file for a gpu card EVGA 760 SC , i already made measurements in many places and all looking good but i want to verificate the mos critics zones and verify routes , im going to atach an a PCB photo and if anyone have the file .fz , .brd or any technical reference please sended to me , i really apreciate any help .1 Photo
Channel: Schematic Requests ONLY!
10-18-2025, 09:15 PM -
- Loading...
- No more items.
