Using a resistor to fake a Inverter into thinking a CCFL is good
  • Nama
    • May 2009
    • 127
    A man was telling me to try this.
    How would I go about it?.
    ^Learning to walk on rice paper without leaving a trace,
  • PlainBill
    • Feb 2009
    • 7034
    Re: Using a resistor to fake a Inverter into thinking a CCFL is good
    Ohms law. At a rough guess a CCFL runs at 650 - 1000 Volts and draws 3-5 mA.
    E / I = R or 800/.004 = 200Kohms
    I X E = P or .004 X 800 = 3.2 watts
    So a 200K ohm, 5 watt resistor hooked to an appropriate connector should do it. Probably be a good idea to use a resistor rated for high voltage.
    No warranty at this price.
    Now, I've been thinking it should be possible to do something similar, except use two resistors (180K, 20K) in series to form a voltage divider so you could actually measure the output voltage without frying a DMM.
    PlainBill
    • Nama
      • May 2009
      • 127
      Thanks Mr Bill
      I have been meaning to tell you I have access to thousands of LCD's and parts for them at the moment.
      If you need anything let me know. That goes for all of you. Jacob
      • EGuevarae
        • Nov 2008
        • 1336
        Thanks Mr Bill
        Hi Jacob. Hi, Bill.
        I have been thinking about this for quite some time. Here's my scenario:
        I have a 24" LCD Panel (not mine) that was removed from a Samsung brand monitor (or so I was said. No plastic frame available, and no pics at hand). Six lamps in there, only one is fried. If I use a spare lamp that I have so the inverter don't have to shut down, you can not tell the 6th lamp is not lit. So it would be possible to just "fool" the inverter and with the appropriate resistor, use it like that?
        • ASUS ROG Maximus IX Code
        • Intel Core i5-7600K 3.8GHz
        • Windows 10 Pro x64
        • GeForce GT1050
        • Nama
          • May 2009
          • 127
          Yes it does work, I can verify this. I had a tray of resistors and since Bill thought what was suggested to me would work I tried it today on a 22" acer Took me a few tries but it is flawless now!. I will be using this trick many times over from here on out.
          So whats the model number on your samsung. I will see if I have a bezel for you, Jacob
          • EGuevarae
            • Nov 2008
            • 1336
            OK. First of all, thanks for the confirmation.
            As for the model, I don't have it. I checked it on a friend's house, and it did not have a bezel (anymore). He did kind of a custom Jukebox and made a front "bezel" with acrylic and put some vinyl decorations so it looks like an old record player (I dunno how to put this in English. You know, the old machine that you put a quarter or two in and it plays your selected song). I will try to get pictures of it as it is kind of cool. Well, he did it quite colorful and with a great sound system, but did not make ventilation holes/grills, and the caps in the samsung went south : ([LCD heat] + [PSU Heat] + [MoBo's heat] + [amp & sound crap heat]) - [Air Ventilation] = crap caps giving in ....
            Well, when he tried to fix it, he damaged one of the CCFLs (How? I don't know). Well, after the caps were replaced and some nice grills & fans were in place, we ended up with a panel with a dead lamp.
            I think he'll be happy when I go to his place and with a dummy load solve his problem.
            And thanks for the bezel offer!
            • GeForce GT1050
            • Bill Lee
              • Nov 2010
              • 9
              Dear sir,
              Very interesting with your method to light up the backlight, I'm very new
              to repair LCD, would you kindly show me which resistor in my BenQ DV3250
              to replace? Image is attached.
              • retiredcaps
                • Apr 2010
                • 9271
                Originally posted by Bill Lee
                'm very new
                to replace?
                I suggest start a NEW thread and telling us what exactly is wrong with this monitor (is the power LED on, can you see the display flash, can you see it with a flashlight shined on it). We will also need a clear focused picture of both sides of the board.
                --- begin sig file ---
                --- end sig file ---
                • EGuevarae
                  • Nov 2008
                  • 1336
                  I agree. This thread has been dead for a year ...
                  • GeForce GT1050
                  • Bill Lee
                    • Nov 2010
                    • 9
                    Glad for your quick responses. Please inform me how to start a new thread. ( Forgive me for so dummy...).
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Click on Troubleshooting Computer Displays at the top of this thread. At the next screen you will see a blue button 'New Thread' on the left about half way down the page. Click on it.
                      Or you can just click on This Link.
                      PlainBill
                      • Bill Lee
                        • Nov 2010
                        • 9
                        Thanks Mr.PlainBill, I'd just post the new thread. Please kindly be visit :
                        BenQ DV3250 backlight problem
                        Last edited by Bill Lee; 11-11-2010, 11:19 PM. Reason: Don't get it how to make a text link
                        • lord
                          • May 2011
                          • 319
                          • Croatia
                          About the resistor instead of CCFL, i tried 100k, 56k and some similar but they were all overheating (they were all under 1W). But i noticed that the current is always 0,2A (don't know why though).
                          Then i put in the 150R 1/2W and everything was fine (no overheating).
                          The reason i did this because i have a Qosmio G20 with a broken screen, and the replacement screen is hard to get because it has 2 lamps. So the laptop has a double inverter, and i need to disable one lamp, which i did. Put in the standard LP171WP4, everything fits and the job is done.
                          I noticed that some of you have a "dead lamp" problem. I fixed some lamps with resoldering the cables on the lamp leads (cold joints), but you must be very carefull since the tend to brake very easily.
                          Sory on my poor english!
                          Cheers!
                          Edit: Shit, the holes for the screws dont match
                          I have to make new ones...
                            Typical CCFL used in monitor is about 8~10Watts
                            It depends on the running voltage that the inverter board will put out, usually about 800~1000VAC at about 8mA (Start up voltage is about 1500~2000VAC), so that is about 8Watts, so about 125K Ohms 8 Watts will be needed (@1000VAC). Your meter does not high enough bandwidth to measure AC voltage or AC current at 70~90KHz.
                            You can use CFL T5 4W lamp for testing or old CFL. At 150 Ohms, you will more likely burn up the high voltage winding of the transformer.
                            See pictures here:
                            http://s807.photobucket.com/albums/y...g%20old%20CFL/
                            Bad lamps/lamp assemblies:
                            • lord
                              • May 2011
                              • 319
                              • Croatia
                              OK. But the problem is that i tried out a couple of resistors, several resistances and wattage, but they were all overheating and through all of them ran the same current. When i put the 150 ohm resistor there was no overheating a no excessive current. All between 15-20mA. I don't know why would that burn the transformer. But then again, I'm not that kind of a expert.
                                It is basic voltage, resistance, current, and power math. Unless the transformer no longer puts out 800V and also the safety shutdown no longer function. You can calculate the current flowing through 150 Ohms resistor with an applied voltage of 800V.
                                • cfrantzol
                                  • Dec 2012
                                  • 2
                                  • Greece
                                  Hi everyone!
                                  Here is the trouble I had and how I solved it:
                                  A friend had a 17' Neovo F-417 that would flash the screen on for a couple of seconds then it would go black with the power light on and would latch on this condition until unplugged and restarted. He bought another one and since he knows I love dismantling things he gave it to me to play with.
                                  I am relatively experienced with electronics (especially low frequency, linear and logic) but had never worked on an LCD or HT circuit before. So I had no other components of the sort (CCFL, inverter and the like) and could not test or swap anything.
                                  Initially I changed the caps even though they seemed and measured ok. It worked fine for around 10 mins and then started over the same problem. So I swapped some caps, changed the rectifier bridge, resoldered all HT points, etc. What intrigued me was that after almost every change, it worked for a while and then reverted to the same problem. A couple of times it even worked fine for more than 30 minutes. This fooled me to think that there is a bad contact somewhere but I couldn't find it.
                                  So I decided to test the lamps one by one (this monitor has 4 of them). I thought that since there was no pink tint or bad spot on the screen whenever it worked, turning each one on alone would reveal more.
                                  I had no single lamp inverter to connect but I had a very old scanner stored somewhere since 2000. I took off its glass and removed its ccfl then used its inverter (complete with the scanner) to power each of the monitor's ccfls one by one. To do this I had to place the LCD on top of the partally dismantled scanner, in brief it was fun.
                                  And it worked! Apparently those things are tolerant enough or I was lucky but it worked. With the help of the scanner's borrowed inverter I singled out one of the four ccfls which was completely used up. It lights very pinkish and turns off seconds later. All other three lamps appear ok.
                                  So I googled and found this very informative thread and went to my bench to find a suitable resistor but I had none so I put 4 x 1.5MΩ/1W in parallel to form a 375 KΩ resistor to start with as low current as possible.
                                  It worked again and the missing lamp is making very little difference on the display, it is bright enough and fairly uniformly lit. One could not easily tell if he did not know the mod.
                                  So I wrote this post to reconfirm that it is possible to fire three lamps on a 4 lamp inverter with a simple resistor as the missing lamp. Furthermore in my case it worked with higher resistance and thus much less current than anticipated. Fyi this inverter uses an OZ960 controller chip.
                                  As a footnote I have some doubts and maybe someone in this forum can answer them:
                                  First will the amperage imbalance created by the decreased current in half of the output stage of the inverter create a problem in the long run?
                                  And is it mandatory that the other 3 lamps will follow to their doom shortly or the failed ccfl could have been a weak one from the beginning?
                                  Hope my confirmation will help other fellows to resolve their issues.
                                  Thanks for reading!
                                    The fault detector circuit will shutdown if:
                                    1) The lamp is fired up by the start-up voltage (around 1500~2000V) but does not conduct the current, which will be the same as no lamp connected, it will shutdown.
                                    2) The lamp draws too much current.
                                    It will only take one bad lamp to shutdown the whole circuits. So in the first 3 seconds after the inverter is commanded to run, if it detects any of the fault in first 3 seconds, the unit will shutdown.
                                    Instead of using pure resistor as the load, you can take the advantage of the Capacitor's Xc (Capacitance Reactance) as the current limiter and lower the resistor value so you will not dissipate so much heat on the resistor, the main key is that you will need to know the frequency the inverter circuit is running at so you can pick the correct cap with the the required Xc.
                                    You will not damage anything with your setup right, just need to take care of the heat from the resistor.
                                    You can use old CFL for testing the inverter circuits.
                                    Here is the manufacture uses for testing their inverter:
                                    http://s807.photobucket.com/albums/y...t=DSCF0614.jpg
                                    Bad lamps:
                                    http://s807.photobucket.com/albums/y...klight%20lamp/
                                    • Chungalin
                                      • Jul 2014
                                      • 423
                                      • Spain
                                      I was thinking about a different approach, instead of the resistor solution.
                                      I have one bad lamp (out of six). Since every lamp output has two feedback lines (HV & LV) going back to the inverter controller, I've thought that I could cut the feedback from the bad lamp (now unplugged) and connect them to the same lines from a working lamp. This way, a working lamp would provide feedback for two lamps. Is it safe to do this experiment or better not even try? Am I missing anything?
                                      • Chungalin
                                        • Jul 2014
                                        • 423
                                        • Spain
                                        Sorry, can't edit my previous message to update.
                                        I've tried my idea and it seems to work. I've dessoldered a blue, high voltage capacitor from the output of the high voltage transformer. Then made two bridges between two SMD diodes and two SMD capacitors. These were the first feedback checking components connected to the lamp output connectors.
                                        Once powered on I notice a yellowish corner on the screen. I guess the bad lamp got hot for a long time before failing completely. Anyway, the screen is usable.
                                        • jinu_j
                                          Dell 2209WA - power supply - Fusible Resistor replacement
                                          by jinu_j
                                          Hi
                                          I am trying to repair an ancient Dell 2209WA Monitor which suddenly shut off with a pop sound. On investigation found that one of the fusible resistors had blown. Further investigation identified multiple components as faulty because of which the fusible resistor blew. Please refer the attached circuit diagram showing the components that were found to be damaged.
                                          1. FR950 - blown fusible resistor - 0.2 Ohm 1W
                                          2. Q950 - shorted Q950 MOSFET - 650V 10A N Channel Mosfet
                                          3. R835 - Blown Resistor - 20KOhm SMD resistor
                                          4. D930 - Shorted Schottkey Diode...
                                          05-03-2025, 10:51 PM
                                        • mikey5791
                                          Need help to replace burned resistor in 350w atx psu
                                          by mikey5791
                                          Hi to all forum members,
                                          Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                          The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                          Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                          Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                          12-26-2024, 04:55 AM
                                        • ttmi100x
                                          HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                          by ttmi100x
                                          Greetings everyone,
                                          I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                          The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                          Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                          Upon closer inspection...
                                          07-31-2024, 06:36 PM
                                        • MidnightRoller
                                          Can a resistor lose resistance after hot air?
                                          by MidnightRoller
                                          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                          02-02-2022, 11:46 PM
                                        • artvandalai
                                          What resistor ohm will work better to repair this waterpik?
                                          by artvandalai
                                          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                          01-05-2025, 04:10 PM
