List of pin compatible pwm/supervisor PSU ICs
This is a sticky topic.
  • Quaddro
    Tukang Kentu
    • Nov 2010
    • 141
    • Indonesia
    This is my list of PSU ic pwm/supervisor pin to pin compatible. At least proven work for me..
    1. HY510N <=> WT7510 <=> ST9S313 <=> PS113 <=>RT7501
    2. TOP258 <=> TNY27x/TNY28x
    3. PS223 <=> WT7527 <=> DWA106
    4. PS229 <=> WT7525 DIP 14.
    5. WT7520 <=> EST7502
    6. TL494 <=> KA7500
    7. 2005AZ <=> ATE7520 <=> LPG899 <=> WT7520 <=> ATX2005 <=> SDC2005 <=> CG8010 <=> EST7502 <=> SR6110B
    8. WT7525 N161 <=> DWA105 N161
    I do hope anyone can add more in this list..
    i do need alot wt7525 n161, but i can't found it in my country. and if i ordered from ebay, it's so expensive. $10 each..
    i've read in forum, that wt7525 n161 is replaceable with DWA105 n161.
    That's great, because DWA105 is alot cheaper.
    but i confuse because there's no DWA series ic datasheet that i can find, so i cannot make sure this is really compatible.
    That anyone can find about DWA105 n161 datasheet?
    or anyone can suggest another ic that can replace wt7525 n161?
    Last edited by Per Hansson; 12-07-2019, 04:47 AM. Reason: Updating post with new models 6 > 8 and updated pos. 3
  • PeteS in CA
    • Aug 2005
    • 3583
    • USA, Unsure of Planet
    Re: List of pin compatible pwm/supervisor PSU ICs
    Tl494 <---> ka7500
    PeteS in CA
    • Quaddro
      Tukang Kentu
      • Nov 2010
      • 141
      • Indonesia
      some addition
      • Quaddro
        Tukang Kentu
        • Nov 2010
        • 141
        • Indonesia
        addition for number 3.
        Update:
        i found a DWA105 N161 from old delta psu, tested with xigmatek nrp502, and this little thing works flawlessly as replacement.
        so, as an addition..
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          I updated the OP with the new additions, very nice work!
          • mmartell
            • Oct 2013
            • 3189
            Know of anything compatible with a DNA1005A ?
            • Quaddro
              Tukang Kentu
              • Nov 2010
              • 141
              • Indonesia
              Unfortunately, i didn't not find any datasheet about it. so it must be done with trial and error. Maybe, just maybe, dwa105n161/wt7525n161 will work as replacement.
              • mmartell
                • Oct 2013
                • 3189
                Does this help ?
                • Quaddro
                  Tukang Kentu
                  • Nov 2010
                  • 141
                  • Indonesia
                  I'm very sorry, i can't precisely predict what is each pin function base on that schematic..
                  • mmartell
                    • Oct 2013
                    • 3189
                    k thanks for looking into it.
                    • PeteS in CA
                      • Aug 2005
                      • 3583
                      Back in 1998-2001 when I worked for Delta, DNA1001 and DNA1002 were proprietary custom ICs. DNA1005A may be as well.
                      PeteS in CA
                      • mmartell
                        • Oct 2013
                        • 3189
                        I believe you may be right about that.
                        • GNRFreak69
                          • Aug 2019
                          • 1
                          I know this post if pretty old, but has been helpful to me.
                          same as TPS3510, TPS3511, LP7510
                          • asmbin
                            • May 2015
                            • 2
                            • usa
                            Please help Can you replace top256pn by top258gn
                            • lotas
                              • Jan 2016
                              • 4811
                              • Russia
                              Yes, you can, the difference in power.
                              • goodpsusearch
                                • Oct 2009
                                • 2850
                                • Greece
                                Let's make this thread sticky
                                  • 22030
                                  Done
                                  • goodpsusearch
                                    • Oct 2009
                                    • 2850
                                    • Greece
                                    Thank you!
                                    • tartuf
                                      • Dec 2022
                                      • 20
                                      • Europe
                                      I don't know if these are completely same but I've noticed their datasheets are identical(copy-paste) - HY510N and EST7610. I have also compared HY510N and WT751002 datasheets and found that the only difference are PDON_N pin Voltages: 2.0V/0.8V on HY vs 2.4V/1.2V on WT.
                                      It looks to me like either companies behind these have some agreements or they literally steal from each other.
                                      https://z3d9b7u8.stackpathcdn.com/pd...0N-HawYang.pdf
                                      https://z3d9b7u8.stackpathcdn.com/pd...ST7610_EST.pdf
                                      • protocold
                                        • May 2019
                                        • 24
                                        what about WT7527V? seems like it is pin compatible with PS224? Can you experts shed some light on this?
                                        • Deby
                                          List of compatible laptop motherboards
                                          by Deby
                                          This is a list of compatible laptop motherboard information that I have been collecting for some time.
                                          And it's still ongoing.
                                          Every time I come across information that a board is compatible with another, I write it down.
                                          Anyone who wants to, can continue to expand the list.
                                          Packed in the rar, is an excel table that has additional information.
                                          Motherboards.rar...
                                          05-31-2024, 04:34 AM
                                        • AppleLover123
                                          Lenovo Yoga X380 22LH Supervisor Password removal
                                          by AppleLover123
                                          Hey guys,
                                          have a laptop here that has a supervisor Password (dump in Attachements).
                                          Before i write the Serial NR.etc i wanted to say that strangely after flashing with 3 different Bios dumps and one from lenovos site
                                          the laptop works but everytime it wants me to type a supervisor password i never set.
                                          I thought the supervisor password is stuck in the ec bios but no it isn't either because after replacing the ec chip from one of another board it still has the supervisor password.
                                          Anyway i wanted to ask what of the two chips is the ec bios because on the left...
                                          04-17-2025, 03:42 PM
                                        • Duranitron
                                          List of Compatible laptop LCD screen
                                          by Duranitron
                                          i dont know if this is the proper forum anyways
                                          do anyone have a list of compatible lcd screen so that we will have a guide specially for 30 pins and 40 pins lcd screen to prevent us from destroying the gpu chip for wrong pinouts..
                                          example for model 15.6 40 pins lcd BT156GW01
                                          these are the compatible lcd screen model..
                                          LTN156AT24
                                          B156XTN02
                                          B156XTN02.0
                                          B156XTN02.1
                                          B156XTN02.2
                                          B156XW02
                                          B156XW02 V.6
                                          B156XW02 V.7
                                          BT156GW01
                                          CLAA156WA11A
                                          LP156WH4
                                          LTN156AT02
                                          LTN156AT05 ...
                                          07-07-2020, 06:25 AM
                                        • NotEnough
                                          Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
                                          by NotEnough
                                          Hi everyone,
                                          I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
                                          What I've Tried So Far:
                                          • Reseated the cables.
                                          • Reinstalled AWCC and AlienFX services.
                                          • Attempted BIOS downgrade but no improvement.
                                          • Inspected ribbon cables for damage.
                                          • Explored the possibility of BIOS or
                                          10-19-2024, 01:34 AM
                                        • baaligoga
                                          Help needed in unlocking BIOS Supervisor password - Lenovo X1 Yoga 5th Gen
                                          by baaligoga
                                          Good day, everyone!
                                          I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
                                          I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...
                                          05-20-2023, 09:48 AM
