ELKO Thermostat D3200 Schematic
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    As I was looking at capacitive dropper supplies I drew up a literal "back of the envelope" schematic of this thing.
    To not let it go to waste I'm uploading it here.
    In this thermostat the problem was twofold: the X2 capacitors capacitance had dropped from the rated 330nF to 165nF
    I had a slightly larger 330nF yellow X2 cap that measured 215nF, it was able to switch the relay when I put this in its place.
    However that showed another problem: The NPN transistor that drives the relay was shorted so it was always on.
    I scavenged one from another board and then the device works fine.
    The NPN transistor is marked 1GW and is probably a BC847C this is underrated to drive a relay that will present a dead short for a few ms before the coil energizes fully.
    A sensible replacement would state that it is rated for inductive load usage in relays, like PBSS4160T for example.
    As for the X2 capacitor that is a larger subject, but a nice replacement could be Epcos / TDK B32932A3334K
    Re: ELKO Thermostat D3200 Schematic
    https://www.badcaps.net/forum/attach...9&d=1571846138
    No snubber diode for the relay coil?
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      There is a component in parallel with the relay coil.
      It is the one on the far left on the PCB in this picture:
      https://www.badcaps.net/forum/attach...6&d=1571846138
      I don't know how to decode the value so I left it out.
      • redwire
        • Dec 2010
        • 3910
        Must have been hit by mains transient to kill the transistor. What is the relay voltage.
        It's a cheapola Carli X-cap? MPXGMF40/100/21 is CBB62.
        0.33uF has two thicknesses 7 or 8.5mm, P=22.5mm, 26.5mm width, 17mm H.
        I would just put in a better part.
        TVS 1.5SMCJ18CA bi-dir marking code BET, date code 4AA (2014) ~20V breakdown voltage.
        BC847CW 45V 100mA. A better relay driver is BC817 45V 500mA.
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          The relay is 24VDC
          The yellow X2 cap is not the original one, the original is pictured here in the OP.
          I scavenged it from a PSU to test with it, as I mentioned in the OP.
          • redwire
            • Dec 2010
            • 3910
            OK I 'm paying more attention now
            Kemet R46 series PP film cap X2 "Not for use in 'series with mains' type applications."
            We've got Kemet and Vishay advising against using some film caps in capacitive-dropper applications, and it's nothing to do with voltage as across the line X2 experience the same voltage transients. Still a mystery as to why.
            The relay driver transistor failure, I have seen them heat up if their hFE is low or they aren't driven into saturation. I thought a transient hit it but the TVS should look after that, and the coil has a back EMF diode? That MELF part might be just a resistor for the LDO input.
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              Super thanks redwire, I never managed to find the manufacturer of the X2 cap!
              I did a deep dive now, as I thought maybe Kemet added that warning to not use this X2 cap in series with the mains at some later date to their datasheets.
              But I found a datasheet from 2014 (attached) that said the same exact thing back then!
              So for sure ELKO has done a mistake here, I will send them an e-mail, be interesting to see what their reply is.
              The capacitor is dated July 2014 and the end-user of this thermostat says it has been in use for only ca 4 years.
              He had another thermostat that I mentioned in the other thread.
              It uses a Vishay MKP339 X2 capacitor, and as you noted Vishay does not recommend it for use in capacitive droppers either, and it has the same failure mode.
                Seems to me that it will lose it capacitance even if you use it as X cap.
                • redwire
                  • Dec 2010
                  • 3910
                  ELKO has no room really in that tiny box for a "real" X-cap, which is thicker. The choice might be driven by size.
                  It's strange Vishay says to contact their field application engineers on a case-by-case basis, to see if a vanilla X-cap could work.
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    Well, there is some space in there.
                    And a strange thing is the mechanical switch: it is huge!
                    Without it there would be allot of free space inside...
                    But anyway the yellow capacitor is larger but it does seems to fit.
                    I was bored this evening and started drawing the schematic in Kicad, still WIP.
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      I desoldered the little MELF that sits across the relay coil pads.
                      It is a diode that measures a 650mV drop on my transistor tester and 550mV on my Fluke 28-II
                      So probably it is a regular diode.
                      Attached the KiCad WIP schematic.
                      MCU_CONN is a ribbon cable that goes to a secondary board with the MCU, I will not make a schematic of it.
                      But on it of course is just the MCU that reads the temperature sensor and control the relay on or off state.
                      There is also the "setback" function via an optocoupler, that reduces the set temp by the MCU -4°C, controlled via an external switch if installed.
                      Don't be too harsh: it is only my second or third CAD schematic ever
                      • SolomonMan
                        Nest Thermostat Discussion...
                        by SolomonMan
                        All,
                        I was over my sons place helping him with projects today. (Broken Dryer Belt, a Couple leaking pipes (One cracked - that got me over there),and Thermostat swap.
                        The Energy company offered a Rebate on the Nest Thermostat System (Not the Learning One) last year and we picked it up and its sat in the shipped box for about a year now.
                        Anyways I was thinking it would be a quick job as I currently have a Nest Learning Thermostat at my place and it was not a problem to install. (Old Rheem 90 Furnace)
                        At my boy's place he has a York Stellar...
                        12-11-2022, 10:54 PM
                        Alexia thermostat is this a good idea for for controlling your air conditioning system feedback wanted
                        by sam_sam_sam
                        My wife is asking me about getting one because our electric bill was that it has ever been even more than last year at this time nothing has really changed since last year last month unless the electric company has done some fuel adjustment charges I have not done any investigation into yet but I might have to but there was a time back a few years ago that I use to set the temperature warm during the day when we were not home but when we got wooden floors in our house and you have to keep the humidity down to keep it from warping I just set to a temperature to 75*F to keep the humidity down but...
                        06-22-2025, 10:23 AM
                      • jm1234
                        9V relay temperature 40C
                        by jm1234
                        Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                        I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                        05-09-2024, 03:03 AM
                      • TinkerTron
                        Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                        by TinkerTron
                        Hey everyone,
                        I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                        Instead, here's what's been bugging me so far:
                        The schematic...
                        03-06-2025, 02:03 PM
                      • atunguyd
                        Acer x163w Monitor PSU schematic
                        by atunguyd
                        Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                        The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                        03-05-2025, 02:08 PM
