Capacitive dropper supplies not lasting
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    I've noticed a trend of capacitive dropper supplies not lasting.
    This supply is super simple: you use a capacitor in series with the load to limit the current and voltage the device can consume.
    I have fixed several such power supplies now where the only problem is that the safety rated X2 capacitor used for the implementation has dropped in capacitance.
    This of course starves the circuit of power:
    In many implementations there is a relay being driven, and thus when the load of the relays coil is added the device simply turns off or rather resets.
    I have a question regarding the safety of actually using a X2 rated capacitor to begin with in such an implementation.
    X2 caps may fail shorted, that would mean the little MCU or whatever the dropper is powering sees full line voltage, 230VAC, not cool!
    The obvious solution is to use Y2 capacitors instead, but of course they are more expensive and not available in as large capacitance values generally.
    Maybe that problem is academic at best, I don't suppose using inrush limiting with an NTC would help either.
    If they can even be found in so small values, since these devices are generally never switched off.
    But then any type of non-polarized capacitor could be used, if we anyway do not care about the safety of the failure mode...
    So the problem is the capacitor itself, the "self healing" properties they have mostly just means when the layers get damaged they automatically burn off an area in a safe way:
    A better name for them would be capacitors with a controlled failure mode.
    I have even seen some datasheets now specifically mention to not use certain X2 capacitors for capacitive dropper implementations.
    EPCOS / TDK has a new model that is branded as ok for this use: B3293 (305VAC) and also an older model called B3292*H/J (305VAC)
    They also have models B3265* MKP and B3267*L MKP but they are without safety approvals.
    Vishay has models F1772 and F339X1
    Do you know of any others? I got tired of looking myself...
    Or maybe some other solution to make the capacitors last longer?
  • redwire
    • Dec 2010
    • 3912
    Re: Capacitive dropper supplies not lasting
    Vishay calls it (capacitive dropper) "series impedance applications" and attributes the stress due to overvoltage spikes, 2.5kV for Cat. II. Safety is not so much an issue because a circuit has a fuse/fusible resistor present.
    App note AC Film Capacitors in Connection with the Mains
    X-capacitors have a series-plate construction. Example F1772-2 series is "extended" metalized film with internal series design:
    Ripple current is extremely high which is why I think the caps age fast. There is no datasheet spec for this. The aluminium deposition is only 0.02-0.1 µm thick and I imagine it cracks, giving low capacitance.
    I get long life if I have a series resistor say 100R with the cap, it lowers ripple current (and lowers cap transient voltage according to Vishay) but this resistor sees very high peak power pulses, and tends to burn up before a fuse blows.
    Some film cap failures were corrosion and the end-connections going bad: https://www.semlab.com/services/ecfa...ilmcapacitors/
      • 31304
      i have seen film caps intended for solar psu's that have very high current handling,
      but the whole point of a capacitive dropper is to make it dirt cheap.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        ... or even cheaper than dirt!
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          redwire: The two devices I have on my bench are both made by the Norwegian company ELKO.
          They are thermostats for electric floor heating systems.
          The older one of the two has a thermal fuse for protection, quite nice solution, and a 470Ω 3W resistor in series with the X2 capacitor.
          The newer model has a digital display, but the dropper circuit is very similar.
          They removed the fuse, and lowered the resistor to 56Ω
          There is a bi-directional TVS diode on the primary side, this will conduct if the X2 capacitor fails.
          That means the 3W resistor would be dissipating close to 1kW I guess it will not have much choice but become a fusible resistor
          stj & CapLeaker: Exactly: they are too cheap to go for a transformer solution, so instead this.
          But of course the proper Y2 capacitor is too expensive.
          And the proper X2 capacitor that I and redwire linked above are also too expensive.
          Basically a "proper" X2 cap for this job usually internally is an Y2 capacitor...
          And the problem for me is to find a "better" X2 capacitor that can still fit inside the case, it seems almost like mission impossible...
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8716
            I'd just say screw the X caps, just either use Y caps if you have money or use regular high voltage film caps... but that fuse or fuseable resistor is critical.
            • redwire
              • Dec 2010
              • 3912
              What's the original cap rating, as in X1 or X2 and VAC? over 2.2uF? Size?
              X-caps have thicker dielectric for higher withstand voltage on mains transients. So they are naturally huge. If there is a MOV upstream to lower the spikes- then you can use a smaller ordinary film capacitor. Perhaps this technique was used by ELKO? The TVS I did not quite understand and wonder if has gone open.
              The (fusible) resistor limits current the cap and zener will see. 1uF is 120mApk at 240VAC.
              Overvoltage aside, I still suspect something going on with the metallization causing the low value with age.
              Recently I saw chinese shielded cable and the aluminum flaked off the mylar shield, so it could be a quality problem.
              EPCOS B3293* "heavy duty" X2 with no mention what they are better spec'd for.
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                There is a picture of it in this thread I created.
                I've had failures on other units too though, I also have another thermostat with a different X2 cap but same failure mode.
                Bigclive mentions it in this video too, seems to be pretty common.
                https://www.youtube.com/watch?v=qGc9-ToEiIQ
                • redwire
                  • Dec 2010
                  • 3912
                  Response from Vishay Film Capacitors Division:
                  "It is because of Corona effect.
                  Corona effect is electrical discharge (partial breakdown) which results from ionization of air on the surface or between the capacitor plates in AC voltage applications or in rapid changing DC voltages (pulses). However, film capacitor has the feature called self-healing. After one discharge, one self-healing. As a result, loss increase and capacitance decrease.
                  When there is too many corona effect accumulated, the capacitor will be failed.
                  Therefore, if we make internal 'series construction', we can make the voltage between capacitor plates half. It will be much lower than corona start voltage, in order to avoid corona effect.
                  F1772 is internal series construction.
                  At last, I suggest you also read our attached application note.
                  Please note two tables in it.
                  We recommend that for continuous across line application and in series with the mains application, internal series construction capacitor should be used."
                  *Notice the X-cap's standard has a +/-10% over 1,000hours - much shorter than continuous use and I would say X-caps are also degrading/aging the same way but it's not noticed.
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    Yes, this is the document I based my initial post on.
                    Sorry I forgot to attach it then.
                    I think I agree with budm from my other thread:
                    Originally posted by budm
                    Seems to me that it will lose it capacitance even if you use it as X cap.
                    I think this is 100% true, nobody really cared for the longevity in X caps before they started being used in critical areas for device function...
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      I found two really good capacitor series now:
                      Kemet F862 is a special series, directly quoting from the datasheet:
                      "Typical applications include connection in series with the mains, capacitive power supplies and energy meters, with special emphasis in automotive applications for severe ambient conditions."
                      Kemet F862 is physically larger than the old Kemet R46 series, therefore they have later introduced the F863 which has the same physical dimensions as R46 and cheaper then F862.
                      The capacitance change at a specific relative humidity test is 50% worse for this series, however if space is important in an existing application it is an obvious choice.
                      This is not communicated very well in the datasheets (you can't admit that your old series was crap) but here are two sources:
                      https://www.digikey.com/en/product-h...ion-capacitors
                      https://www.codico.com/en/News/long-...from-kemet.htm
                      Codico news article linked above:
                      Long-term stable X2 film capacitors from KEMET Newly introduced by KEMET: The F863 Series!
                      Rapid loss of capacitance at X2-certified film capacitors especially occurs under the usage in harsh environmental conditions. This leads to an early failure of power supplies as well as a loss of reliable EMI-suppression.
                      Two X2 film capacitors series
                      In the range of long-term stable X2 film capacitors KEMET provides two series, F862 and F863. F862 has been tested 85°C/85% r.h./240Vac for 1,000 hours and available on the marked for some time already. Recently KEMET has introduced a new series F863, which is a cheaper and partly smaller alternative to F862. So this special treated X2-capacitor has the same dimensions like the standard-X2 of R46-series. F863 has been tested 85°C/85% r.h./240Vac for 500 hours.
                      Last edited by Per Hansson; 11-01-2019, 11:42 AM. Reason: Fixed mistake pointed out by mockingbird
                      • mockingbird
                        • Dec 2008
                        • 5488
                        Very informative and constructive post Per! Just to make a small correction the cap you reference is Kemet, not EPCOS.
                        • hikomalek
                          SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
                          by hikomalek
                          Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
                          When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
                          Transformer:
                          |Info| Primary | Aux | AB | CD|
                          |Ratio|1|25|40|12|
                          |Voltage AC|230V|9.2V|5.8V|19V|
                          |Voltage DC (*1.41)|230V|13V|8.1V|27V|
                          I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
                          09-19-2025, 03:30 AM
                        • iMic
                          Vintage AT Power Supplies - Selecting Capacitors
                          by iMic
                          Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
                          The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
                          02-19-2023, 06:45 PM
                        • fadi90
                          PILZ PNOZ X4 Safety Relay
                          by fadi90
                          Hi everyone,
                          I'm working on repairing a Pilz PNOZ X4 safety relay module. When I opened it up, I found some of the connector pins detached from their pads. I replaced the connector with individual wires, but the issue remains.
                          The module is set to dual-channel mode with manual start. In this mode:
                          • Y36-Y37 and Y1-Y2 are bridged.
                          • 24VDC is applied across A1-A2.
                          • It monitors two emergency circuits (S11→S12 and S11→S52).
                          • When both are closed (24V present on S12 and S52) and the start button is pressed (S33 connected to S34), the NO contacts (13-14, 23-24, 33-34)
                          06-07-2025, 01:21 AM
                        • SolomonMan
                          HP Docking Stations Power Supplies...?
                          by SolomonMan
                          All,
                          I recently purchased for a colleague and myself two used HP Docking Stations. They are for home use and are exact model as the ones we use at work for our laptops. We are both Software Developers.
                          Anyways these docks are HP Model 5TW10UT#ABA.
                          Unfortunately they did not come with there Power supplies (PSU) and I got them reasonable from eBay.
                          I purchased 2 new from Amazon After Market Power Supplies(PSU). Same Voltage and Same Amperage and in fact it mentions on the Amazon page they are supported for these docks as well.
                          h...
                          05-09-2023, 08:04 AM
                        • Cappy Oligan
                          Newbie about to dive in with the leads. Safety advice please.
                          by Cappy Oligan
                          I'm new to electronic repair. Trying to troubleshoot a Dell monitor that only has an AC port for power. I'm concerned about safety and not getting shocked. Should I order an isolation transformer and plug in the monitor into that and proceed with testing the board inside? Or should I get a DC power supply and limit the amps and connect the voltage to a pin somewhere inside where 19V DC is first expected? Or both? Thanks.
                          08-30-2024, 05:40 PM
