Asus x542u clean me bios need
  • ay_bulut
    • Feb 2016
    • 114
    • turkey
    MODEL :ASUS X542U
    CASE CODE : X542UR-GQ277T
    MAİNBOARD MODEL : X542UQ MAIN BOARD REV 2.0
    Backup bios : https://www.badcaps.net/forum/attach...0&d=1566396900
  • peste
    • Dec 2016
    • 12734
    • ROMANIA
    Re: Asus x542u clean me bios need
    try..
    https://www.badcaps.net/forum/showthread.php?t=77618
    • peste
      • Dec 2016
      • 12734
      • ROMANIA
      try..
      • ay_bulut
        • Feb 2016
        • 114
        • turkey
        i tried these
        opening late
        • peste
          • Dec 2016
          • 12734
          • ROMANIA
          try..
          • ay_bulut
            • Feb 2016
            • 114
            • turkey
            Originally posted by peste
            try..
            not working
            • peste
              • Dec 2016
              • 12734
              • ROMANIA
              try this one
              • ay_bulut
                • Feb 2016
                • 114
                • turkey
                try this one
                cleaning the me region please
                  • 20787
                  That bios has got clean ME firmware. Don`t you have the original bios backup ? Did you make a backup before trying any other bios.The link you posted at post #1 isn`t your bios is it,it from another thread on badcaps.
                  • peste
                    • Dec 2016
                    • 12734
                    • ROMANIA
                    try again
                    • ay_bulut
                      • Feb 2016
                      • 114
                      • turkey
                      there is
                        • 20787
                        Try this one,if its still opening late run Flash programming tool from dos,uefi or windows from the command line with this switch -greset e.g. if you run the win64 version from the command line then run:
                        FPTW64.exe -greset
                        • ay_bulut
                          • Feb 2016
                          • 114
                          • turkey
                          FPTW64.exe -greset
                          I tried , it is opening fastly but closing slowly.
                            • 20787
                            If its starting up quickly the bios is fixed.Shutting down slowly is a problem with windows 10,drivers,hard drive or other hardware.
                            • String2016
                              • Nov 2015
                              • 2234
                              • philippines
                              shutting down slowly cause by a bad hard drive or windows problem
                              • ay_bulut
                                • Feb 2016
                                • 114
                                • turkey
                                I understand. Thank you very much for your attention.
                                • battery.12v
                                  • Dec 2014
                                  • 123
                                  • NW
                                  FPTW64.exe -greset
                                  You are the Savior !!!!
                                  Thank you a lot Bro
                                  • bilen
                                    • Aug 2014
                                    • 632
                                    • istanbul
                                    FPTW64.exe -greset
                                    i5 7th cpu and 930mx %100 working
                                    • razor_amd
                                      [TUTORIAL] fix asus bios with bios from asus web support (by razor_amd)
                                      by razor_amd
                                      With ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
                                      For example, you can have 3 similar ASUS motherboards, all being the same model, all of which will have different BIOS versions.
                                      I will give you an example and my version of preparing BIOS from ASUS website and in the process I am always cleaning Intel ME while doing it so you have fully cleaned BIOS, no DMI data, no password, nothing.
                                      This is the picture of 3 similar ASUS motherboards, all of them being X555LD...
                                      12-15-2020, 07:07 PM
                                    • grimacelord
                                      ASUS TUF GAMING Z790-PLUS WIFI - BIOS Help
                                      by grimacelord
                                      I have spent the last hour on this and I guess this is just over my head, so here I am.
                                      I have an ASUS TUF GAMING Z790-PLUS WIFI motherboard here that needs to have the BIOS updated in order to accept the latest CPUs.
                                      The BIOS chips seem to come as a set of two: GD25B64ESIG and GD25B128ESIG. My guess is one of them is a fail-safe for the main BIOS? I really don't know. Or one of them is ME and other is BIOS? I don't know.
                                      Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...
                                      07-10-2025, 02:52 PM
                                    • throwaway327
                                      Asus ROG Ally X -RC72LA - changed hidden bios settings with 'Smokeless-UMAF', won't get past boot logo
                                      by throwaway327
                                      ASUS ROG Ally X - (Handheld Gaming PC)
                                      Model No: RC72LA
                                      Serial No: SBNVKD001014459
                                      Hi all, I've spent the past week digging through the forums and guides to try correct my foolish mistake of changing hidden settings while tinkering around, and to be honest my heads overloaded so I'm hoping you'll be able to help.
                                      I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...
                                      06-18-2025, 05:52 PM
                                    • jbonavita
                                      by jbonavita
                                      Some issues
                                      Things I tried
                                      04-29-2025, 09:38 PM
                                    • lrouw84
                                      Asus vivobook s510ua bios changed to x510un
                                      by lrouw84
                                      Hi there,
                                      I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                                      I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                                      01-28-2023, 01:31 PM
