Panasonic Viera TX-L32E3B won't power up, green LED flashing
  • lamlash
    • Aug 2019
    • 26
    • United Kingdom
    I am attempting to repair a Panasonic Viera TX-L32E3B, chassis GLP26 for a friend.
    There is no sound or picture. When switched on the green LED flashes rapidly about 44 times then goes solid. Pressing any button on the TV or remote causes the green LED to go out. The red LED never comes on.
    My friend said that the TV recently started doing this and would sometimes work if powered off and on again. Now it doesn't work at all.
    I carefully inspected the power board and there's no obvious damaged components or bad soldered joints. With the board powered up and all connections left plugged in, I measured the following on the two connectors:
    P2
    1 5.74V
    2 5.74V
    3 0V
    4 15.99V
    5 15.99V
    6 15.99V
    7 0V
    8 2.49V
    9 5.74V
    10 1.3V
    11 3.28V
    12 3.27V
    13 0V
    14 0V
    15 0V
    16 0V
    P4
    1 0V
    2 0V
    3 0V
    4 3.26V
    5 0V
    6 0V
    7 0V
    8 0V
    9 0V
    10 24.6V
    11 24.6V
    12 24.6V
    13 24.6V
    14 24.6V
    I found a service manual for this chassis on another badcaps thread and it lists test-point voltages for the power board. With 2.5V on TV_SUB_ON on P2 pin 8, I measured the following voltages on the P Board:
    TP7514/TP7515 (24V, PANEL) : MEASURED 0V (should be 24V +/-1.2V)
    TP7503/TP7504 (16V) : MEASURED 0V (should be 16.1V / +/- 0.7V)
    TP7502/TP7501 (TUNER5V8): MEASURED 0V (should be 5.7V +/- 0.3V)
    TP7201/TP7203 (PFC): MEASURED 388V (in spec - should be 400V +/-15V)
    Could someone suggest next steps?
  • nomoresonys
    • 12206
    • U.S.
    Re: Panasonic Viera TX-L32E3B won't power up, green LED flashing
    Heat up the powerboard with a hairdryer be sure and heat the capacitors, then see if tv comes on or changes if not then heat the mainboard same way, see if anything changes. That little test works with certain conditions including raising the esr on a cap that is bad or marginal enough to make the tv work for a very short time.
    • lamlash
      • Aug 2019
      • 26
      • United Kingdom
      Thanks, I'll give that a try tonight (I'm in the UK here). Any follow-up tests you can suggest? Is it worth unplugging the LED driver board from the power board to see if I can get a red standby LED to come on?
      • diif
        • Feb 2014
        • 6978
        • England
        It helps if we can see the boards and how they are connected together although looking at your voltages I'd investigate the backlights and circuitry as pin 4/12 is BL_SOS.
        • lamlash
          • Aug 2019
          • 26
          • United Kingdom
          I've uploaded an image in case that helps
          • lamlash
            • Aug 2019
            • 26
            • United Kingdom
            My information shows that Pin12 on P2 and Pin4 on P4 are the BL_SOS signals. Mine are at 3.3V so does that mean the LED board is asserting a BL_SOS signal?
            • Diah
              • Feb 2013
              • 6399
              the sickness of Panasonic always the LED back light sockets. they choice such kind with heating get out from it place. start to take screen apart and inspect LED back light.
              • lamlash
                • Aug 2019
                • 26
                • United Kingdom
                OK thanks. I stripped the screen apart (lots of screws, lots of pieces!!) and have the LED strips out. This is an edge lit TV with 2 strips of small surface mount LEDs on a thin aluminium PCB. Each strip has 42 LEDs. Have you any advice about testing the LED strips?
                The part numbers of the left side LED strip is 010312-L4 / 110616A-0312. The connectors look absolutely fine. Does your advice about the connectors apply to these edge lit LED panels?
                Many thanks by the way!
                • Diah
                  • Feb 2013
                  • 6399
                  Panasonic can work and LED back light too with out screen in place.. so keep the screen at safe place till you have done .
                  yes the edge one had this sickness.. the mother socket which soldered at the strip
                  try to turn it on and keep eyes on the LED if they blink some how
                  • lamlash
                    • Aug 2019
                    • 26
                    • United Kingdom
                    OK thanks. I have dismantled too many parts to test the LED strips using the TV power supply. Do you know approximately what the I-V operating point of each LED should be? I could connect each LED to a current limited bench top power supply. Does 3V limited to 10mA seem reasonable to light up each LED without damaging it?
                    Here's a photo of the connector - I can't see any problem with them.
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      Around 200mA to test the LEDs properly.
                      • Diah
                        • Feb 2013
                        • 6399
                        NO, you can use your DM in Diode mode. ( peep ton ) and test each one. the reading will be if - + correct it will light on a little depend on your DM battery. and when you exchange the red and black at opposite place it should read Diod round 0.75ß-0.540. if one not goes on but read correct Diode it mean its OPEN. if one powered on but no Diode reading or it peep mean its shorted. and this most case.
                        • lamlash
                          • Aug 2019
                          • 26
                          • United Kingdom
                          Thanks.
                          Each strip has 42 LEDs. The circuit arrangement is 3 parallel sets of 14 series-connected LEDs.
                          When you say 200mA, is that for the complete strip (so each LED would have a drive current of 66mA)? I'll got and try it!
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            Try each set of 14 at a time. 42v at 200mA
                              Can I see good clear straight shot of the LED power supply?
                              This panel has 6 LED strings, the two brown wires are the Anode of the 6 LED strings are tied together and connected to the LED Boosted Voltage power supply, the Blue wires are the Cathode return for each one of the 6 LED strings, each return wire is connected to the PWM controlled MOSFET for maintaining the constant current, there 3 Dual-MOSFET 8-pin chip right next to the LED connector. You need to keep black probe of the meter on the chassis and red probe on one of the Blue wire then turn on the TV to see what you get, then turn off the TV and repeat ehe same test on the other 5 blue wires.
                              • lamlash
                                • Aug 2019
                                • 26
                                • United Kingdom
                                Here's the LED driver.
                                Returning to the LED strips themselves, my bench top power supply only goes up to about 30V so I cannot test each string of 14 LEDs using 42V limited to 200mA. However I have tested each individual LED and they all work but the IV characteristic of the individual LEDs was very strange. I had to bias them with at least 5.1V forward voltage before they light up individually (with the power supply leads directly across each LED one at a time). The the current has to be limited to about 2mA otherwise they go dangerously bright.
                                Help! what's going on with these LEDs! I checked the voltage with a second meter and it's definitely correct.
                                  They are dual LED per package.
                                  • Diah
                                    • Feb 2013
                                    • 6399
                                    SMT LED testing not about lighting or not.. i write before the critical point when the built in Opposite Diode for FW currents shorted or open..
                                    • lamlash
                                      • Aug 2019
                                      • 26
                                      • United Kingdom
                                      I tried this and the blue wires all seem to be at a floating voltage. There isn't any distinct change in the meter reading when the power is switched on. I did this with the LED panels wired up but the TV screen panel disconnected. Everything else was connected.
                                      • lamlash
                                        • Aug 2019
                                        • 26
                                        • United Kingdom
                                        I need to learn more about this - could you send me a link to that post please?
                                        • mostachio
                                          Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
                                          by mostachio
                                          Hi Badcaps,
                                          I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
                                          TV Details:
                                          Model # - TH-65DX700Z
                                          Symptoms:
                                          The television turns on and displays a picture then makes a clicking sound and turns off.
                                          I haven't opened it up yet but...
                                          09-04-2024, 02:32 AM
                                        • jimjoe123
                                          LCD TV Green/Pink screen problem
                                          by jimjoe123
                                          I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                          Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                          Then each time...
                                          02-23-2020, 01:29 AM
                                        • Ama Chur
                                          Panasonic Viera LC470EUN (SE)(M2) T-Con issue?
                                          by Ama Chur
                                          After watching some youtube videos and checking some forums, I'm at a loss. With both ribbon cables connected, we have no image. With the left one pulled out, the screen is black and white, split down the middle. With the right cable removed, it is all black. Backlight is working fine and we have sound and can open applications. We are strapped for money right now and are hoping to repair whatever the issue may be. I think the TV was manufactured in 2012, so I'm aware that may not be possible. Edit: Found a single vertical line of blue pixels on the left side of the screen with one of the ribbon...
                                          02-21-2025, 08:12 PM
                                        • fixxy88
                                          Panasonic 55DX600u repair help - no display fast green then slow red led flash
                                          by fixxy88
                                          Hi everyone. I've been given a dead Pana 55DX600u that I hope to save from landfill. I suspect the tcon board or UC1 on that board.
                                          Set will flash green led and attempt to start, backlight gives a brief flash then set shuts down and red led flashes slowly. Voltages out of PSU look ok. TCon board gets 12v at fuse when attempting to start and 3.3v on L1 but main IC gets warm very quickly (heatsink/cover removed, felt with back of hand) during the second or two the 12v is applied before PSU shuts down. TVS diodes on lvds input lines are not shorted, no caps appear to be shorted. ...
                                          02-22-2023, 09:14 PM
                                        • ItepK
                                          Panasonic TX-P42G30E green light blinking, no video, no audio
                                          by ItepK
                                          Hey everyone!
                                          I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
                                          This post describes my entire troubleshooting process of this TV.
                                          When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
                                          I've taken the unit apart, and I've started to check some voltages:
                                          • On the P11 connector, there is 15V DC only for a brief moment, then it goes
                                          12-22-2023, 05:06 AM
