xbox ultimate solid-mod
    • 31191
    previously, others have put polymers in xboxes,
    but usually not replaced the smd electrolytics or the vrm smoothing.
    the main failing caps!!
    and often they used oversize caps that dont fit well.
    so here is one done right, i call it the XXX-BOX because it's hardcore!
  • diif
    • Feb 2014
    • 6978
    • England
    Re: xbox ultimate solid-mod
    Looking good, are they the poly caps you got from Ali?
      • 31191
      everything other than vrm was ali,
      vrm came from RS.
      but only because i got those first - future boxes will be 100% ali sourced.
      btw, while doing this i discovered something usefull.
      any FOXLINK psu's - check the 1200uf caps!!!!
      • Stefan Payne
        • 1267
        are that two totally different PCB revisions with some major changes?
        Especially the CPU area and Power connector...
          • 31191
          there is very little changed between v1 and v1.5
          almost exactly the same caplist.
          v1.0 has a usb hub on a riser card,
          v1.1 and higher has it on the main board.
          v1.0-1.1 uses a different power connector to 1.2-1.5
          other than that there are 2 or 3 different video encoders used.
          but if you compare them the differences are very minor.
          • Blag
            • Oct 2019
            • 9
            • DE
            Great work but why did you use tantal caps instead of polys in some places?
            Also do you've plans to do the same for the psu as well?
              • 31191
              the board has pads on it for tantalum caps, but m$ cheaped out during production and only used tants on the underside.
              i wont poly the psu - that usually wont work.
              • Blag
                • Oct 2019
                • 9
                • DE
                Ah alright. Because of the far lower esr of polys? Is this only true for higher wattage psus (xbox and newer) or basically for all psus? I was thinking about replacing the psu caps on some retro consoles, so that would be a real downer.
                  • 31191
                  it's true for all psu's,
                  the most common problem is the psu see's the caps as a short-circuit at power-on and shuts down or goes into a startup-shutdown loop.
                  • Blag
                    • Oct 2019
                    • 9
                    • DE
                    Thanks I'll keep that in mind. Many retro consoles have a external psu and only a small internal power board so that could be fine.
                      • 31191
                      yea, anything older than playstation/saturn uses external AND usually not switching but traditional transformer design.
                      • RoroX
                        • Feb 2020
                        • 7
                        • United Kingdom
                        Noooooice, did you change 10v 3300μF caps to 6.3v 1500μF
                          • 31191
                          yes,
                          but notice i fitted more of them.
                          where m$ used 3300uf they left spaces because they had originally fitted 1500 or 1800uf caps.
                          so the total capacitance is actually similar - but the esr is much lower!
                          • RoroX
                            • Feb 2020
                            • 7
                            • United Kingdom
                            Awesome, can tell me the paramets of your tantalum caps?
                              • 31191
                              https://www.aliexpress.com/item/32370177546.html
                              https://www.aliexpress.com/item/32372832101.html
                              https://www.aliexpress.com/item/32983008282.html
                              https://www.aliexpress.com/item/32951610902.html
                              • RoroX
                                • Feb 2020
                                • 7
                                • United Kingdom
                                Sorry for bothering you, but what are the ESRs of your 25v 22uF / 100uF caps?
                                  • 31191
                                  i have no idea.
                                  lets just say that they have to be better than the original general purpose crap i removed.
                                  it's not critical there anyway - only for the 1500uf caps because they are smoothing power circuits.
                                  • danielu
                                    • Dec 2015
                                    • 16
                                    • Romania
                                    Just revisting this after a long time.
                                    That poly mode(with oversized caps) is mine and yes is not done well, pro level. Did not have the experience(not that i have it now) or the tools. I ordered the wrong size also. Lost my patience and just wanted to be done already.
                                    @stj electrolytics were replaced with 'new' ones. I did that because i have found caps with the right values atm. Also didnt want to risk it too much. The info was scarce.
                                    I have thought to replace the smd ones too but they were ok .
                                    Completed Forza Motorsport and Splinter cell on that xbox board.
                                    100h+ i have played, i think.
                                    It doesnt look nice but it works right even now , in 2020. (wow).PC PSU mod also.
                                    Anyway glad someone did the right and full job. Hope it helps others.
                                    Stay healthy.
                                      • 31191
                                      thanks,
                                      • KnightNZ
                                        • Apr 2020
                                        • 3
                                        • New Zealand
                                        Looking at ordering a bunch of those caps off Ali as per the links above as it looks like a really nice solution. No gotchas that you can think of?
                                        Thankfully there's nothing anywhere near where the modchip sits to have to deal with!
                                        • TMTGTR
                                          An Xbox One PSU Odyssey
                                          by TMTGTR
                                          Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
                                          =>Background:
                                          I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
                                          06-17-2022, 05:40 PM
                                          HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                          09-12-2024, 02:00 PM
                                          ASUS ROG GX501VI-Ultimate-01 Notebook Zephyrus Specification for Upgrade or Repair
                                          This specification for the ASUS ROG GX501VI-Ultimate-01 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GX501VI-Ultimate-01 boardview and GX501VI-Ultimate-01 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 05:46 AM
                                        • Stevedb
                                          Boardview xbox 360 , xbox fat , xbox one x and xbox one s
                                          by Stevedb
                                          Hi all
                                          I will share the boardviews i found internet from the xbox 360 , xbox fat and xbox one x and xbox one s
                                          Pasw netcomchetumal.
                                          Enjoy it.
                                          Greetings Steve
                                          From Belgium...
                                          04-04-2023, 12:42 AM
                                        • grimacelord
                                          Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                                          by grimacelord
                                          Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                                          After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                                          I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                                          10-24-2024, 12:31 PM
