Samsung LNT5265FX/XAC Vertical Line
  • henryvrensburg
    • Oct 2018
    • 104
    Hi guys
    I have a Samsung 52" TV with a vertical Color Line from Top to Bottom. It looks like rainbow colours starting from the right with Yellow ending with blue or purple on the left.
    Do you have any ideas or is the panel bad. It is such a nice TV, would really like to have it fixed.
    Thank you
    Henry
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Samsung LNT5265FX/XAC Vertical Line
    Bad panel, had several like this. You can try cleaning the ldvs cable on both ends. Maybe you'll get lucky.
    • henryvrensburg
      • Oct 2018
      • 104
      Thank you tvtimmy. I was hoping for a better diagnosis, but that was what I expected. Thanks for your time reading the posting.
      • igor tsybuch
        • Jun 2019
        • 6
        • Украина
        Помогите телевизор toshiba 48L1433DB такая же проблема мигает индикатор и не включается до етого помогало только витянуть с розетки и включить заново,7 месяцев телевизор в ремонте и никто не может починить,в чем причина?
        • nomoresonys
          • 12151
          • U.S.
          May be able to shim the bad tab bond if that's the problem, youtube has many videos on the subject.
          • nomoresonys
            • 12151
            • U.S.
            Example of confirming: https://www.youtube.com/watch?v=vCExlSnG4yY
            • nomoresonys
              • 12151
              • U.S.
              Example of shimming, might find some that go into greater detail but it's a pretty simple procedure: https://www.youtube.com/watch?v=8l5ORKjQF5U
              • mrsith
                Samsung UE58TU7100K - no picture, vertical line
                by mrsith
                Hi.
                Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
                This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
                Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
                02-07-2023, 11:18 AM
                09-07-2024, 05:50 AM
              • sputnikoff
                samsung un58tu7050 single vertical line.
                by sputnikoff
                Had a friend drop this tv off and initial issue was no power.I could see faint glow when powered up .Lamps all fired up fine.I removed flat lvds cable and reseated it,then tv screen came on.After i reassembled it now has single line pretty well dead center of screen.Is there ongoing display issues anyone is aware of.Any input welcome.
                02-25-2023, 09:42 AM
              • TrueSword88
                Kogan - KALED65XU9220STB - Blue Vertical Line
                by TrueSword88
                Hi all.
                I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                The line just happens to coincide with the end of COF and start of the next COF (attached).
                The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                Hoping to fix...
                05-05-2023, 04:28 PM
              • cubytus
                Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                by cubytus
                Hi to all,
                I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                01-10-2024, 01:26 AM
