Dell Latitude E6540 LA-9411P
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Problem: Turns on, no display.
    I suspect BIOS but I did not find any dumps that were confirmed working.
    ME region cleaning tool did not let me pick correct ME version aswell.
    Could somebody fix this dump for me?
    Or are there any other ideas what to check?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Dell Latitude E6540 LA-9411P
    Try this bios for LA-9412p. This is tested ok. Please take note that bios for Latitude is same for all boards eg LA-9411/9412/9413.
    Post result
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      Thanks for the information!
      Will try that soon. First I will try my own dump which I might have managed to fix.
      • RethoricalCheese
        • Mar 2013
        • 1519
        • Estonia
        Not sure if your bios dump was the reason but I got it posting now.
        After programming, it didn't seem to work. Did a test with D + power and Fn + power and after that, it worked.
        Strange is that it takes about 25 seconds to get to the Dell logo. I'll try updating it to see if it gets fixed aswell.
        Thank you for the dump!
        By the way, original fault seems to be a broken HDD which did not let the computer POST for some odd reason.
        • RethoricalCheese
          • Mar 2013
          • 1519
          • Estonia
          I heard Nutribullets have blown up in some cases.
          Anyway, back on the laptop topic.
          Somehow I am unable to update bios to latest version. Doesn't matter if I do it in Windows 10, DOS or directly using BIOS utility, it just prepares the update and then restarts. Does not update.
            • 22030
            Heres a bios to try,your backup bios was corrupt,and ive changed a few settings in the ME bios from @mcplslg123 .
            • RethoricalCheese
              • Mar 2013
              • 1519
              • Estonia
              Will try later today. I guessed faulty ME was the cause of this slow start, am I right?
              And looks like A09 and A11 BIOS versions are faulty. Unable to upgrade to newer version or just bricks laptops. Dell has removed these versions from their page aswell.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Well you are right that its me region issue. Me region is married to that particular board one you power it on, so simply copy paste dont work and thats why we need to clean that region. Getting dell logo after 25s is definitely me region issue which hopefully smdflea's updated bios with clean me will fix.
                • RethoricalCheese
                  • Mar 2013
                  • 1519
                  • Estonia
                  Nicely done, SMDFlea! Post time was much much faster and it allowed to update to a newer version aswell. Are there any materials online to learn about it so I can do it myself and help others aswell?
                  Updated BIOS to A24, next boot after POST I got an "ME invocation flow error" but that seemed to be a one time thing.
                  Thus far works like a charm.
                    • 22030
                    "Are there any materials online to learn about it so I can do it myself and help others aswell?"
                    Yes,theres a guide: https://winraid.level1techs.com/t/gu...lization/31277
                    All credit goes to plutomaniac for the great guide, without it ,many laptop repairs would not be possible .
                    • RethoricalCheese
                      • Mar 2013
                      • 1519
                      • Estonia
                      Thank you very much! Will try to learn it for sure.
                      • hezareh2000
                        • Jan 2019
                        • 32
                        • Iran
                        Hi, i want bios dell e6540 la-9414p rev 1.0 with ec file (4mg) please help me
                        system slowly boot
                          • 22030
                          system slowly boot
                          Flash BOTH files from post #6 .
                          • hezareh2000
                            • Jan 2019
                            • 32
                            • Iran
                            thanks but main board number is la-9414p
                              • 22030
                              Quote: @mcplslg Please take note that bios for Latitude is same for all boards eg LA-9411/9412/9413
                              We can add the la-9414p to that list. The bios is the same,there`s only 1 bios update at dell for the E6540 ,not seperate ones for each board revision .
                              Try the bios at post #6 or #2 .
                              • hezareh2000
                                • Jan 2019
                                • 32
                                • Iran
                                hi i flashing bios in post#6 but show logo dell after 20 secounds and not charging,please help me.
                                  • 22030
                                  You did flash both ? ,8MB + 4MB
                                  • hezareh2000
                                    • Jan 2019
                                    • 32
                                    • Iran
                                    yes, both flash 8mg+4mg but not charging in bios adapter is unkonwed
                                      • 22030
                                      Try a genuine dell adapter or another power jack, the middle pin ID is where your problem is, not the bios.
                                      • nsilvang
                                        • Mar 2017
                                        • 26
                                        • mexico
                                        SMDflea it working this dump thanks
                                          DELL Latitude E6540 Notebook 6000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude E6540 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E6540 boardview and E6540 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                                          09-06-2024, 04:40 PM
                                          09-06-2024, 04:10 PM
                                          09-06-2024, 04:00 PM
