Probook 470G3-Your system is not fully configured - contact your hp customer support
  • oliviu50
    • Apr 2018
    • 22
    • Romania
    When turn on me laptop,appear for a few seconds "Your system is not fully configured - contact your hp customer support" . I mentioned that after that it entered smoothly in Windows 10. The motherboard was replaced with a new one in authorized service, all the series of devices were inserted correctly. Bios is up to date.
    I have no other problem besides this warning.
    Please help me to not have this warning, without having to send it back in service. It's an HP Probook 470 G3 laptop.
    Thanks!
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Probook 470G3-Your system is not fully configured - contact your hp customer supp
    Can you enter bios setup?? If so, Is it showing model,serial etc correctly??To me seems like missing or incorrect dmi info in bios.It would have been better if posted old bios here
    • oliviu50
      • Apr 2018
      • 22
      • Romania
      Yeah, I can get into bios. All series are entered correctly (S / N; system board id; SKU number; UUID etc). It's all right, except that start-up warning appears, disappearing in a few seconds.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Post your bios here without which no one can understand the problem.
        • oliviu50
          • Apr 2018
          • 22
          • Romania
          N78_0123.bin
            • 21597
            Download HP Bios Configuration Utility,run it and set an admin password .
            http://ftp.hp.com/pub/caps-softpaq/cmit/HP_BCU.html
            • oliviu50
              • Apr 2018
              • 22
              • Romania
              Please, explain step by step how they can do this!
              Thanks!
                • 21597
                Thanks!
                • oliviu50
                  • Apr 2018
                  • 22
                  • Romania
                  What link has the bios password with the warning message???
                  • Stevie2001
                    • Apr 2018
                    • 183
                    • irland
                    It means all manufacture info is missing including serial and modle number.
                    This will help you
                    https://youtu.be/9VKwnKrGsl8
                      • 21597
                      This will help you
                      Post #3 He`s already got the serial etc .
                      • oliviu50
                        • Apr 2018
                        • 22
                        • Romania
                        This will help you
                        All series are entered correctly. The only problem is the warning message that appears immediately after turning on the laptop, then disappears and goes into windows 10 without any problems.
                        • oliviu50
                          • Apr 2018
                          • 22
                          • Romania
                          Yes, all series are entered correctly. Why password setting is needed ???
                          Read to pag. 34.
                            • 21597
                            What do you mean what link ? . Read the instructions, you have to run bios config utility from the command line.
                            Use the following sample command to create a setup
                            password on a system with no existing password:
                            BIOSConfigUtility.exe /nspwdfile:"new password.bin"
                            If you don`t know how to use the command line wait for some more suggestions from other members here or from the other places you`ve asked for help on, ******* ,vinafix, hp forums .
                            • oliviu50
                              • Apr 2018
                              • 22
                              • Romania
                              What is the reason for creating a password ??? This I do not understand!!
                              Please, read post #13
                                • 21597
                                Sometimes the cofig file has to be changed, youve already got serial,uuid etc.It might not work anyway, wait for for other ideas or send it back to service.
                                • Stevie2001
                                  • Apr 2018
                                  • 183
                                  • irland
                                  Follow all instruction in video its not fixed cause you did not follow
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    N78_0123.bin
                                    What you have posted is hp update file and not full bios backup. It should be 16mb file.
                                    Have you tried updating bios from hp update?? I stiil beleive that there is some mismatch in the dmi info though it is just filled. Can confirm once you post your backup dump.
                                    • oliviu50
                                      • Apr 2018
                                      • 22
                                      • Romania
                                      Yes, I made a bios update to the latest version. Attached is the bios update. I do not know how to do to get a backup dump.
                                        • 21597
                                        You have the option to save the current bios to a file .
                                        https://ftp.hp.com/pub/softpaq/sp845...00/sp84947.exe
                                          HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-07-2024, 07:12 AM
                                          09-07-2024, 06:40 AM
                                          HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                          This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                          09-07-2024, 05:50 AM
                                          HP ProBook Prenosni računalnik ProBook 445R G6 Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook Prenosni računalnik ProBook 445R G6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Prenosni računalnik ProBook 445R G6 boardview and Prenosni računalnik ProBook 445R G6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                          09-06-2024, 10:51 AM
