Identify The Chip??? Vizio E480i-B2
  • Michale32086
    • Nov 2011
    • 1453
    Got in a Vizio Smart... Dead as a doornail.. Fuse checks out..
    Inspection of power board shows this problem..
    Any idea what that chip might be?? IC901???
  • R_J
    • Jun 2012
    • 9535
    Re: Identify The Chip??? Vizio E480i-B2
    Ld7913 , R915 is likely open as well
    • Michale32086
      • Nov 2011
      • 1453
      Like this??
      https://www.ebay.com/itm/5PCS-LD7913...gAAOSwJwpajh~N
      • R_J
        • Jun 2012
        • 9535
        Looks like it, LD7913JGM6 there are some sellers selling for less
        • Michale32086
          • Nov 2011
          • 1453
          Thanx
          • Michale32086
            • Nov 2011
            • 1453
            It's probably a stoopid question, but what other voltage regulator ICs would be compatible??
            • R_J
              • Jun 2012
              • 9535
              Its not a voltage regulator ic, it is a pwm controller, here is the datasheet
              • Michale32086
                • Nov 2011
                • 1453
                Followup on this, as I just got another Vizio in with the exact same problem..
                Replaced the IC but still dead as a doornail..
                RJ, you mentioned R915... Could you elaborate??
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  does r915 test ok? 4.7 ohm i think maybe its a fusible resistor that feeds that ic?
                  • Michale32086
                    • Nov 2011
                    • 1453
                    I can't seem to locate R915...
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      i can see it in post one i guess that isnt your board i cant see it fitted in post 10 picture of the psu
                      • Michale32086
                        • Nov 2011
                        • 1453
                        Aww crap... OK my mistake...
                        You are correct, these are two different boards..
                        I saw the exact same chip issue and conflated that with them being the exact same board..
                        My bust...
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          are all the voltages correct as per the data sheet in post 7
                          • Michale32086
                            • Nov 2011
                            • 1453
                            Dunno how to read the specs ( am just a knuckle dragging ground pounder type tech ) but the voltages off the chip are all over the place.. Negative and positive...
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              im still learning too but pin 5 of the recommended ic vcc voltage in looks like it should between 11v and 25v
                              • Michale32086
                                • Nov 2011
                                • 1453
                                No Just flits around between .1 and -.1
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  lets hope budm/r_j etc see this thread im sure someone with more experience will advise of more tests
                                  • Michale32086
                                    • Nov 2011
                                    • 1453
                                    Thanx for the replies.. A replacement board is only $20... But it would be nice to fix this one..
                                      1) What did you use for GND ref. for the meter?
                                      2) Which board are you working on, the one on post 1 or post 10?
                                      3) If it is the board is post 10, then check the Source resistor R601 to make sure it still show <1 Ohm.
                                      • Michale32086
                                        • Nov 2011
                                        • 1453
                                        See Pic
                                        Post #10...
                                        Probably should start a new thread, eh??
