ZD-915/ 917 Display Controller Brand New Replacements EBay
    • Jul 2011
    • 6046
    Here is the link to where you can can find replacement controller for the ZD-915 to ZD-917
    https://www.ebay.com/itm/NEW-LCD-Dis...53.m2749.l2649
    I just bought 2 sets
    I have a couple of displays that the back LED module have gone bad so I am glad to find replacements
    One thing that I noticed is that when a seller has replacement parts for these units when they sell out they do have the parts anymore
    • Jul 2011
    • 6046
    Re: ZD-915/ 917 Display Controller Brand New Replacements EBay
    UpDate
    I did get the ZD-917 controller board in Friday
    They were packed very good and got to me in one piece
    Now I can fix couple of Desoldiering Gun Stations that I need to repair
    One note about this seller if you send them a message you do not get any response from them and the tracking number information was not correct wrong tracking number
    • master3112
      ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
      by master3112
      I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
      When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
      10-29-2024, 09:32 PM
    • ronnygracias
      Help with freemotion incline trainer with controller comm error
      by ronnygracias
      The treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...
      11-04-2024, 01:32 PM
    • ezenia
      PS4 controller left stick potentiometer replacement issue
      by ezenia
      Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
      So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
      I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
      09-30-2023, 02:19 PM
      Tankless hot water heater controller board not powering up when power is applied
      by sam_sam_sam
      I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
      I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
      However I would like to know if I could figure what happened to this controller board if possible
      Tomorrow I will take some better pictures of both side of both boards
      The...
      12-09-2022, 09:14 PM
      Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
      by sam_sam_sam
      This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
      I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
      I am comparing them to a brand new one that I installed
      The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
      I going to let it run for several days before I remount back on the wall next to the...
      09-05-2024, 06:48 PM
