Need data scheet I/O KB9022Q D (ENE)
  • erazor047
    • Nov 2015
    • 4
    • الجزائر
    HI please i need data scheet or Pin out super I/O KB9022Q D (ENE)
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Need data scheet I/O KB9022Q D (ENE)
    Datasheet not available. Pinout should be same as 9012 though i'm not 100% sure. Anyway having difficulties in read/write kb9022 with RT809F as well as svod.
    • missonadhikari
      • Aug 2017
      • 3
      • nepal
      Yes I tried same as kb9012 but can't read and write successfully
      • zolomen
        • Apr 2017
        • 4
        • Ha Noi
        đây
        • viftegalskap
          • Mar 2019
          • 2
          • Norge
          Would anyone have a register description for the EC in I/O KB9022Q D? Or have any info about which registers are involved in controlling the fan speed? I'm trying to make a configuration file for notebook fan control...
          • giya
            • Apr 2020
            • 47
            • indonesia
            Originally posted by zolomen
            đây
            thankssss
            • dreamflowers09
              • Feb 2012
              • 31
              thank you for kb9022q datasheet.
              • manana2019
                • Apr 2019
                • 32
                • malaysia
                thanksyou very much .
                • casquimano
                  • Feb 2017
                  • 9
                  • MX
                  Thanks a lot! ��
                  • harshadcpalace
                    • Jul 2019
                    • 35
                    • bahrain
                    hi anybody know which is the compatible IO suitable with kb9022?
                    • shaon_kof
                      • Feb 2014
                      • 40
                      • Bangladesh
                      Thanks bro.
                      • fathym20041
                        Fathy
                        • Dec 2015
                        • 4
                        • egypt
                        that is not datasheet
                        • mohamed.abdulkader
                          • Dec 2018
                          • 6
                          • Lebanon
                          thank you
                          • beduu
                            • Dec 2020
                            • 1
                            • italy
                            I'm trying to do the same. Have you managed to create the config file?
                            • ARIELITO
                              • Feb 2021
                              • 1
                              • Paraguay
                              đây
                              thanks a lot
                              • kalisko
                                • May 2016
                                • 45
                                • Serbia
                                Thanks bro.
                                • erdemiri
                                  • Nov 2020
                                  • 1
                                  • turkey
                                  I have an Acer a515 51g model laptop. It uses the same motherboard. If anyone can manage to make a fan control file, can they send me the config file?
                                  • alterr333
                                    • May 2019
                                    • 43
                                    • México
                                    đây
                                    you rock!
                                    • lzeta
                                      • Aug 2020
                                      • 30
                                      • Italy
                                      đây
                                      Thank you, do you know witch pins I must use to program it with a CH341A?
                                      • luckyfahad79
                                        • Oct 2020
                                        • 6
                                        • United Kingdom
                                        Kb9022Q D error at Blank check with SVOD anybody has done it yet ?
                                        Blank Check False
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • vbogoev
                                          Lenovo S6000 won't turn on. Data recovery needed.
                                          by vbogoev
                                          Here I have the mentioned tablet with motherboard s6000-mb-h401. The tablet won't turn on, no display, charging normally. I manage to connect to UART port and got this output when I try to start it:
                                          Code:
                                          [PWRAP] pwrap_init_preloader
                                          [PWRAP] pwrap_init
                                          [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=0 rdata=5AA5
                                          [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=1 rdata=5AA5
                                          [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=2 rdata=5AA5
                                          [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=3 rdata=5AA5
                                          [PMIC_WRAP]wrap_init pass,the return
                                          06-20-2023, 06:36 AM
                                        • mscottdoran@gmail.com
                                          Can anyone identify the classification of this data signal?
                                          by mscottdoran@gmail.com
                                          Hi, I'm an elevator technician. The attached oscilloscope display picture is from a digital elevator hall arrival lantern data signal. We have been having problems with “ghost signals” causing intermittent hall arrival lanterns to illuminate randomly when the elevator is not actually due to arrive at the floor.
                                          The tech support of the hall arrival board manufacturer (CE Electronics) is blaming the elevator controller manufacturer (MCE), and the tech support of the elevator controller blames the hall arrival board manufacturer.
                                          The boards are powered by a ground referenced...
                                          02-08-2025, 11:31 AM
                                        • Joe24
                                          Maytag Whirlpool Kenmore clothes dryer data bus
                                          by Joe24
                                          Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
                                          Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
                                          I've been over the board looking for...
                                          01-13-2025, 06:50 PM
                                        • DoOm86
                                          Swap nand flash smartphone for data recovery
                                          by DoOm86
                                          Hello everyone.
                                          I would like to know more about the following topic:
                                          Nand flash on smartphone for data recovery.
                                          I have been reading of people swapping nand flash from a faulty mainboard to another in order to save the data.
                                          But I also read about encrypted data which to be read must been swap also cpu, or nfc or something else where is located the key to make the data being readable.
                                          How does it works? How do I know if data are encrypted or where is the key?
                                          I know there are also very expensive external socket where you can put the nand flash in...
                                          08-20-2023, 07:10 AM
