Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Old 12-12-2008, 06:47 PM   #1
krjune
Default Subsitute for Samxon GF 2200uf 10V
Any one know what and where I can find a substitute for Samxon 2200uf 10v GF (M) 105 C8? The replacement needs to be the same physical size.
thx
krjune is offline   Reply With Quote
Old 12-12-2008, 09:27 PM   #2
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
Line Voltage: 240V @ 60Hz
Default Re: Subsitute for Samxon GF 2200uf 10V
whats the diameter and height in MM?
<--- Badcaps.net Founder & Owner
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is online now   Reply With Quote
Old 12-12-2008, 10:13 PM   #3
krjune
10mm x 20mm
Old 12-13-2008, 05:12 PM   #4
Krankshaft
Krankshaft's Avatar
City & State: New Jersey, USA
Dang Panasonic FCs and FMs only have 12.5 X 20mm.
Do you have 2.5 mm of wiggle room for can width?
If so you could use caps from either of those series'.
I can give you the part numbers of the specific sizes if you want.
Learning to use the manufacturer's datasheets for proper sizing is essential in your case.
Krankshaft is offline   Reply With Quote
Old 12-17-2008, 10:16 AM   #5
Big Pope
Approved Vendor
Big Pope's Avatar
City & State: Hong Kong
thx
Would you mind tell me Samxon GF 2200uF 10V in what hardwares you get?
Would you consider to try Samxon GT?
My SAMXON Capacitors Database HERE!!
X-CON is a new brand for SAMXON's Polymer Capacitors.
Big Pope is offline   Reply With Quote
Old 01-19-2009, 06:44 PM   #6
Mike2501
Hate to thread jack, But I have the same samxon GF 2200uf 10v caps on a LG 42LB1DR power board.
Would those samxon GT caps be a sufficient replacement?
Mike2501 is offline   Reply With Quote
Old 11-13-2012, 09:43 PM   #7
c00kiemon5ter
City & State: Athens
My Country: Greece
hello all,
I know this thread is already 3 years old but ..
I own a psu - Chieftec CFT-650-14C 650W - which after a power failure it went dead.
So I opened it up and found a bad Samxon capacitor.
It is exactly the same as the one discussed in this topic - Samxon GF 2200μF 10V.
I see that GF 2200uf are not out there anymore and Big Pope suggested Samxon GT's.
I went to the local market and shops around here and all I could get were some Lelon and Trec caps. I got a Trec cap and replaced the samxon and the psu is now working again.
But .. I would like to replace it with a proper quality one.
So I would consider the Samxon GT if you believe that's a good replacement.
Should I go for it ? Are there any suggestions for some other cap ? and, uhm,
may I ask where I can find them (I do not see them on the samxon stock page) ?
c00kiemon5ter is offline   Reply With Quote
Old 11-14-2012, 06:59 AM   #8
c00kiemon5ter
My Country: Greece
alright, found the where to buy caps topic
edit: the first link for Greece (Caritato Supply) is not working anymore.
Old 11-15-2012, 06:15 AM   #9
c00kiemon5ter
My Country: Greece
I finally got a Chemi-con KZM series cap, 2200μF 10V
hopefully it will hold good inplace of the Samxon.
Old 02-18-2013, 04:05 PM   #10
pixelpadre
City & State: Eustis Florida
My Country: usa
My power board on my RCA 46" LCD has some bad caps. I cant figure out what to replace them with. The ONLY markings are as follows"
W2A 105DEGREES C8
Any ideas what this is?
Never mind I found a blind spot and it said 1000uF 35v
pixelpadre is offline   Reply With Quote
Old 02-18-2013, 04:23 PM   #11
selldoor
Slow Learner
selldoor's Avatar
City & State: Lancashire UK
W2A 105DEGREES C8
Not sure why you have posted in this thread but in any case a picture would be really helpful W2A can sometimes relate to a capacitor array.
Full TV model number would help and board number the cap is on and the board marking for the cap C???
selldoor is offline   Reply With Quote
Old 02-18-2013, 04:25 PM   #12
Topcat
The Boss Stooge
Topcat's Avatar
Give the model number of the TV as well, so I can split this off into a thread of its own. This is totally not on topic for this thread.
Badcaps.net Technical Forums © 2003 - 2023
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
