Share: T-Con training manual from LG
  • yoritomo
    • Sep 2012
    • 155
    • Belgium
    Hello all
    I want to share this excellent manual to better understand, troubleshoot and fix t-con boards which still be difficult to diagnose by missing informations usually
    Please read carefully especially the page 29 to understand how precious is this manual, it describes how to activate the internal self test pattern of the T-CON board to clear if T-Con and panel are in trouble or not. This test is working without a mainboard, only a 12v power supply and working (forced on) backlight are necessary.
    There is the doc in PDF format.
    http://www.lcdrepairguide.com/screen...28/LG-TCON.pdf
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Share: T-Con training manual from LG
    Thanks for sharing.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      +1
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        Thanks for sharing.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8321
          Nice share! Thanks!
          • dskall
            • Oct 2016
            • 2905
            • usa
            Should go in the TV Repair Reference Library
            • CBS
              • Dec 2014
              • 7
              Thanks.It's hard to find information about tcon.
                I put that info in earlier this month.
                https://www.badcaps.net/forum/showpo...&postcount=302
                • yoritomo
                  • Sep 2012
                  • 155
                  • Belgium
                  Hello
                  I am glad if it may help you , i learnt a lot of things about it too using this doc.
                  Sorry budm, i did not see you posted it already, so it will be double visibility ;-)
                  • chocoyito
                    • Sep 2016
                    • 16
                    • peru
                    Thanks bro!!
                    • anfsujee
                      • Mar 2019
                      • 2
                      • Srilanka
                      Thanks brother ��
                      • kca
                        by kca
                        Hello all ~
                        08-31-2025, 06:38 AM
                      • x_orange90_x
                        TCL 50S535 bad tcon or panel issue?
                        by x_orange90_x
                        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                        03-29-2025, 11:02 PM
                      • advant
                        by advant
                        02-03-2020, 12:25 AM
                      • Hakuu
                        by Hakuu
                        Hi There,
                        More Details
                        TV Model - LG OLED77G1PUA
                        07-12-2023, 02:37 PM
                      • netgearnetgear
                        TCL 43S423 TCON OR PANEL FAULTY???
                        by netgearnetgear
                        Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                        08-20-2025, 06:04 PM
