Vizio E370VT no longer turns on
  • jason424
    • Dec 2015
    • 187
    Tv did work but next day it won't turn on with remote nor button on side. Amber standby light is on but does nothing when pushing the power button.
    I don't see any bad caps and do have 5v standby (which I assumed since the standby light is on in the front.
    What other voltages/items should I be checking?
  • bwilliams60
    • Aug 2014
    • 109
    Re: Vizio E370VT no longer turns on
    I had one of these with a bad optoisolator. It would shut off when it got warm. Usually pretty quick. Location in your picture is top of board in middle. Just a thought.
    • jason424
      • Dec 2015
      • 187
      Thanks for the response. Is the optoisolator the device that is below the 3 capacitors in the middle? I googled testing an optoisolator and it shows 4 pins that's why I ask: http://www.antimath.info/electro/how...n-optocoupler/
      • bwilliams60
        • Aug 2014
        • 109
        The optoisolators are the four pin IC's above the transformer.ead correctly they are IC906 and IC9x07 ????
        Follow the checker divider between the hot and the cold side at the top. Second and third components down. Try freeze spray perhaps and see if it comes on.
          So are you getting any commands signals for the main board feeding the power supply board when you activate the power switch?
          The connector's pins are labeled so report the DCV reading of each pin of the connector that goes to the main board, make sure to put down the pin name follow by the DCV reading. We need to know what are missing.
          You should also resolder those transformer legs and parts that are soldered to the through hole rivets on that power supply board.
          • jason424
            • Dec 2015
            • 187
            On/Off: 0.00
            Dim: .1
            +12v: .1
            +12v: .1
            Gnd: 0.00
            Gnd: 0.00
            Gnd: 0.00
            +24: 0.00
            +24: 0.00
            PS_ON: 4.8
            5v+ 5.2
            5v: 5.2
            NC: 0.00
            • jason424
              • Dec 2015
              • 187
              When testing IC906 with 200k set on meter
              Pin 1red/2black: starts in 50's and steadily increases
              Pin 1black/2red: nothing
              IC9302
              IC9302
              Pin 1red/2black: 3.3
              Pin 1/black/2red: 3.3
              For pins 3 and 4 on both IC's, when testing both ways I get a large number in the hundreds steadily going up and past 200k
              • jason424
                • Dec 2015
                • 187
                I should also add I re-soldered the transformer legs and other thru hole items on the board.
                • jason424
                  • Dec 2015
                  • 187
                  Any additional items to check? I'm stumped as to where to go from my tests and resoldering the transformer legs.
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    What DC voltage do you have across the two legs of the long capacitors?
                    • jason424
                      • Dec 2015
                      • 187
                      C9803 - fluctuates between 170.7 to 170.9
                      C9802 - fluctuates between 170.9 to 171.1
                      C9801 - fluctuates between 171.0 to 171.3
                      EDIT: There's another long capacitor (not as long as the 3 grouped together) on the left of the board in the pic attached above, and I get 0.00 on my meter when testing that one.
                      • jason424
                        • Dec 2015
                        • 187
                        I also noticed that on this TV when I plug in the power cord the power light is amber for a split second then turns to white. Previously I thought it was just always amber. I've tried pressing the power button on the side and it doesn't affect it.
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          What is the voltage written on the side of the capacitors
                          What is the number written on the 8 pin IC on the top of the board and on the 8 pin IC on the bottom of the board.
                            So the PS-ON (4.8 Vdc per your report) is present but the DCV on the main filter caps are only 170VDC, that means the PFC Voltage booster circuit is not working, the DCV on the filter caps should be >380 VDC when PS-ON is present.
                            Vizio ADTVA2414AB9 Power Supply
                            http://www.shopjimmy.com/vizio-adtva...upply-unit.htm
                            Pictures provided by shopjimmy
                            • jason424
                              • Dec 2015
                              • 187
                              The 3 long caps are 47uF 450v.
                              I'm not seeing 8 pin IC's. I see 3 4-pins (IC9102, IC9302 and IC908) and a 7-pin (IC9301) in the center of the board.
                              • jason424
                                • Dec 2015
                                • 187
                                That's correct, 4.8....just checked again. Are there items to test in the PFC voltage booster circuit that can isolate issue and correct? Or am I looking at trying to find a replacement board?
                                • dick_barton
                                  • Aug 2015
                                  • 6642
                                  • Wales
                                  Can you give me the part number of the 8 pin IC on the bottom of the board and also the 7 pin IC on the top of the board.
                                  • jason424
                                    • Dec 2015
                                    • 187
                                    The only 7-pin I see is in the middle of the board in the attached pic. It has printed on it:
                                    A6069H
                                    SK163
                                    24630D
                                    The only other ICs I see are in the checkerboard pattern running across the upper third (left since pic rotated upon upload) of the board and they have 4 legs each. Can you point out which is the 8 pin you are wanting me to check please?
                                    • dick_barton
                                      • Aug 2015
                                      • 6642
                                      • Wales
                                      Bottom of board IC
                                      • dick_barton
                                        • Aug 2015
                                        • 6642
                                        • Wales
                                        Using your meter set to DC volts, black lead on point "A" and red on point "B" what voltage do you read. It should be a minimum of 13.8V
                                        STR-A6069H
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • Super360
                                          Vizio E701i-A3 Vizio logo flashing then turns off
                                          by Super360
                                          Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                                          07-25-2024, 07:06 PM
                                        • p-top
                                          Vizio, E60u-D3, no standby light, no ps_on
                                          by p-top
                                          Have vizio E60u-D3. No standby light. Have searched and read all D??u-D3 posts. posts with same symtoms fixed by new power supply, one guy needed back lights also.
                                          main boards are kinda spendy and, out of stock alot of places. i would like to fix my board.
                                          PS voltages
                                          1 VSNS -2mV
                                          2-5 LED-OUT -2mV
                                          6-10 GND -2mV
                                          11 +16VS 16.29V
                                          12 AC-DET 3.929V
                                          13PS-ON -3mV
                                          14 +16VS 16.29V
                                          15 +16VS 16.29V...
                                          11-27-2023, 10:44 AM
                                        • x_orange90_x
                                          Vizio E550i-A0 no power, no standby light
                                          by x_orange90_x
                                          I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                                          11-20-2023, 09:49 AM
