Old 10-19-2016, 08:19 AM   #1
mehatronic
City & State: Croatia
My Country: Croatia
Line Voltage: 220VAc 50Hz
I'm a: Hobbyist Tech
Smile LG Flatron W1946 wiring inverter AIP-0198
my problem:
I need schema inverter to monitor.
Flatron W1946
Power chip -3BR1765JZ
CCFL inverter -MP10072ES
Mosfet -APM4511GED
inverter no voltage on the output of the lamp
Power works and have all the necessary voltage connector.
I can not find a scheme inverter chip MP10072ES
I looked at the service manual "LG" for this model but in the scheme only for VGA module-inverter for no
would be very grateful if anyone has Schema or advice chip is compatible with MP10072
thank you
mehatronic is offline   Reply With Quote
Old 10-19-2016, 09:17 AM   #2
dick_barton
dick_barton's Avatar
City & State: Cardiff
My Country: Wales
Line Voltage: 230V AC, 50Hz
Default Re: LG Flatron W1946 wiring inverter AIP-0198
There's a video on a similar model
https://www.youtube.com/watch?v=l-Ge0qIlabI
dick_barton is offline   Reply With Quote
Old 10-19-2016, 11:21 AM   #3
mehatronic
My Country: Croatia
ok,
thank you for web address
I know about it and all I tried
capacitors are tested on capacity and% damage
still need Schema inverter with chip MP10072
regards
Old 10-19-2016, 01:41 PM   #4
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
Are you getting the INVER-ON (or BL-ON) command signal from the Main logic board to turn on the backlights inverter circuit?
Old 10-19-2016, 04:59 PM   #5
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
Are the backlights totally dead or do they flash on for a second when you turn on the TV?
Old 10-25-2016, 10:40 AM   #6
mehatronic
My Country: Croatia
CapLeaker:
sorry I did not for some time now (forum)
flash a second
I solved it with a new pipe By changing CCFL
but still has a problem
I get a picture on the screen, raise the Windovs all ok
turn off the PC and turn on again when you can not pick up the image windowsa-
flashed lights, logo appears, "LG", and the fit-not hold up a picture of the PC Windovs
when you disconnect the flat cable with a VGA module on the LCD screen has a bright screen
