Safety X/Y capacitors
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    What are the good brand/models of safety capacitors?
    What are the bad ones?
    I just have a bad history with Rifa X2 capacitors as pretty much all of the cracked X2's I've ever seen are Rifas; and most people on random websites have horror stories about them...
    I need to get a few 0.068uF X2 capacitors to replace ones that had their plastic crack...
    • 31165
    Re: Safety X/Y capacitors
    new rifa's are fine - it was just the older resin that cracked with age. (a lot of age)
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Kemet now owns Rifa right?
      I guess I've seen so many Rifas that have cracked cases... The cracked Rifas I need to replace have are about 22 years old...
        • 31165
        i know the ones - no case, just in a block of yellowed resin that was obviously cast in a mould.
        the newer ones are a plastic box filed with an opaque white resin.
          I use PANASONIC ECQUL series.
          • japlytic
            • Oct 2005
            • 2086
            My favourite brand of ceramic capacitor (including safety Y-class units) is Murata, but I have yet to decide on a favourite brand for X-class units.
            I've seen a number of Rifa/Miniprint X-class units go bad, especially the clear encapsulated units where the encapsulation can crack allowing moisture to enter.
              • 31165
              we are talking about film caps
              • rhomanski
                nowhere man
                • 5157
                • U S of A
                Let's talk about electrolytics. The Dual CS-5000 has two Frako filter capacitors that are notorious for going bad. One of mine shorted about 8 years ago. That's what got me started on the road to here.
                sigpicThe Sky Is Falling
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Hmm... I've not seen many electrolytics used as line filters...
                  But anyway, should paper be avoided like the plague or have they gotten 'good enough' that the catastrophic failures no longer happen? Or should we just stick with poly dielectric?
                  Yes, the resin ones I'm scared of. I have a crack in at least one of them my 2440.
                  • PeteS in CA
                    • Aug 2005
                    • 3581
                    • USA, Unsure of Planet
                    I've been out of the commercial P/S "world" for quite a while - ~15 years of jobs in motor control and military power supplies - but Rifa's PME271 X and Y caps used to be top end in the world of safety caps. back in the late 80s or early 90s Evox and Rifa merged, but it looks like they've been bought by Kemet.
                    Before labeling an established vendor's products as intrinsically bad, I'd consider the age and operating environment. Even the best parts can fail with age and stresses. A 10 year old safety cap operated in an environment with lots of thunderstorms and/or inductive surges (due to other electrical equipment) is likely to be in pretty poor shape.
                    PeteS in CA
                      • 31165
                      that's not the issue,
                      the resin shrinks over the decades until it cracks - then you get moisture in the film layers
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        I'm still really surprised all of the X caps I've seen from late 70s to late 80s equipment that I've bothered to look at those caps are all RIFAs - which blows my mind how it got to be pretty much a virtual monopoly on these safety caps. And every single bad X cap I've seen was a RIFA. This is hinting at a bad sample but I would have figured that I've seen some other manufacturers also suffer blowouts if each of them have are subjected to similar conditions. It is indeed strange, unless as stj mentions there's a problem with the plastic.
                        Currently I'm eyeing Panasonic safety caps as they're...cheap... at least compared to the modern RIFAs.
                          • 31165
                          old rifa's are epoxy resin,
                          i know a shop with a whole box of original unsold caps from the early 80's - all are now cracked!
                          they probably work fine because they have been dry-stored, but get them in a normal enviroment, and then put mains through them and i bet the layers will arc.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            I've been putting off swapping the cracked X caps in my 2440 because the humidity isn't so bad around here. Technically speaking I have two scavenged 0.1uF X2 caps I could use to swap out the cracked 0.068uF's but choose not to ... at least for now. If they go up in flame before I get the new 0.068uF's I guess the 0.1uF's will go in.
                            Looking at the scavenged caps that I have, I have 5 X2 caps. They look like they all have 90s datecodes and none are RIFAs. Unfortunately I don't recognize any of the manufacturers "ERO"? "TC"? but they all have markings on them like Underwriters Labs Recognized Component marking (only two of them have Canadian Standards Association marking). Unfortunately I don't recognize other countries' safety markings, and I don't see TÜV (Germany) which I've seen before...
                            Ahh found another X2 cap, this one has Matsushita's logo on it. Can't discern a date code from it, and didn't see it as a safety cap initially as it was only dipped, but not potted in a plastic case.
                            • mpwdhc
                              RIFA safety cap PME277 - x or y?
                              by mpwdhc
                              Hi guys, new member here, trying to fix an 80s B&O TV which suffered a failure of the 0.1uf safety cap up by the power switch/fuse. This is clearly marked as x2. The replacements are half the size, but have the same rating.
                              Having read about RIFA failure, I also ordered replacements for the other two caps. Now that they've arrived, I'm not sure they are correct. The originals are rated 4700pf, and are marked as follows
                              40/085/21 GPF
                              PME277 MB447
                              CT5
                              250V ~ MP
                              LD2
                              VDE reg nr 5201.212222
                              Is this an X or Y cap?...
                              11-14-2022, 12:50 AM
                            • dragon3x
                              After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                              by dragon3x
                              Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                              power on.
                              Here are some examples :
                              (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                              switching supply area).
                              (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                              than 6.3 V.)
                              1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                              I replaced capacitors with aluminum-polymer.
                              3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                              03-21-2025, 02:46 PM
                            • slybunda
                              AA and AAA battery charger capacitors?
                              by slybunda
                              hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                              it has inside:
                              2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                              2 x 470uf 16v LZ105c branded as G.Luxon
                              not heard of these brands are they any good?
                              iv attached photos of the charger and the board inside for an idea on the type of...
                              12-24-2023, 04:41 AM
                              Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
                              by sam_sam_sam
                              I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
                              This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
                              After all of...
                              07-13-2024, 08:14 PM
                            • Cama
                              Solar Inverter - SMH-II - 2 missing capacitors
                              by Cama
                              I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                              My model is : EASUN SMH-II 7 KW
                              Mother Board : P/N 18947-002401250250
                              Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                              Thank you...
                              09-12-2025, 02:50 AM
