this is why enermax liberty and noisetakers blow up!
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    this glue is conductive once it cooks on hot parts.
    the result is leakage to the gates of these mosfets.
    result..BANG!
  • zandrax
    Hit and miss
    • Dec 2007
    • 1157
    • Italy
    Re: this is why enermax liberty and noisetakers blow up!
    Dammit! Glue can't be easily removed, I suppose: these psus are doomed to death ...
    Zandrax
    Have an happy life.
    • i4004
      • Oct 2006
      • 2029
      well..i understand them: without those small chokes the damn thing just wouldn't work...hehe...
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        just scrape it off and tack the beads with rtv.
        just had a proliant ml370 psu go with a bang due to the same glue.
        gotta rebuild it and clean out the other one in the chassis.
        hey a $20 dual xeon server is gonna need work!
        • gonzo0815
          • Feb 2006
          • 1600
          They probably wanted to glue the ferrite beads to avoid any vibration noise. Good idea, bad practice.
          • Wizard
            • Mar 2008
            • 2296
            A good design include the bead on the wire soldered to the PCB instead on the transistor's leads. Otherwise silicon RTV on these beads on the component leads.
            Nasty to see this tan-colored glue still used to this day. NASTY.
            I had a monitor, I pulled components and scraped the areas clean of this. It was in use for awhile so it was more easier to chip off brown/black stuff instead of trying to tear up monitor because that damned tan glue is stronger than krazy glue!?
            Cheers, Wizard
            • Latoof
              • May 2008
              • 22
              @ kc8adu
              If for any reason you decide not to repair the Enermax, I'm looking for a PS223 monitor IC for my Enermax.
              E8400 8G Kingston PC6400 RAM
              GA-EP35-DS3R mobo
              HD4850 512M GA, 2x 1T WD SATA drives
              CoolerMaster case/Seasonic 850w PSU
              • mutant
                • Mar 2006
                • 123
                Good to know that that the problem has been found. Now I know why mine blew up.
                Thanks.
                • FernandoBayard
                  • Mar 2011
                  • 1
                  Actually blew up ?
                  senuke x | p90x
                  • mutant
                    • Mar 2006
                    • 123
                    Originally posted by FernandoBayard
                    Actually blew up ?
                    A loud pop, sparks and lots of smoke. I did take it out of the pc after it tripped the circuit breaker. I plugged in an ATX power supply tester and as soon as I turned it on - Poof!
                    • Philly Cheese Steak
                      • Mar 2011
                      • 114
                      Damn I got two Galaxy's, I'm wondering if I should examine them? I'd hate to have this happen to me. They are good with warranty work, they have done the same PSU for me about four times.
                      X99 5930K
                      X99-gaming 9
                      EVGA 1080 Vanilla
                      Gskill 16GBRip JAWS@2400
                      SSD'S
                      Corsair AX1200
                      • 370forlife
                        Large Marge
                        • Aug 2008
                        • 3113
                        These are older enermax's, new ones do not suffer from the same conductive glue.
                        • japlytic
                          • Oct 2005
                          • 2086
                          I don't like that glue at all. It takes a lot of effort to remove completely.
                          • Ramjet
                            • Jul 2014
                            • 1
                            • US
                            Hi all, just ran into a 620 watt Liberty that tests ok with a power supply tester, but fails to boot the PC. Debating if it's worth trying to fix before the sparks fly or just scrap it. A new Corsair CX600 is only $40 after rebate, any thoughts if cleaning off the glue and recapping would make it trustworthy again?
                            • Latoof
                              • May 2008
                              • 22
                              The tester puts a hard short on the PSU pin /PS_ON (14 or 16 depending on 20 or 24 pin connector) to ground which pulls the +5V down low enough to cause the power on. If you measure this pin during the power up you will likely see that the voltage does not drop far enough - needs to go below 0.8V to power up. I'm guessing but I suspect that there is a resistor in the PSU that is between the /PS_ON pin and the actual input to the switching device, and that it is out or spec (high resistance) causing the sense voltage to be too high... but that's just a theory in the absence of a circuit diagram
                              THIS LINK may be worth a read..
                              I have seen this with certain MoBo before and in fact my Enermax and MoBo combo intermittently suffer this.... I have just replaced the PSU with a new Seasonic 850W
                              GA-EP35-DS3R mobo
                              • Behemot
                                • 4845
                                • CZ
                                I have yet another of the units with clicking primary. I've replaced the film cap, the MOV, the input cap and the PFC choke from similar scrapped Enermax unit, still does it. And I am not sure if this is quite normal, but there is 136 volts on the primary heatsink against earth ground.
                                There is almost no glue at all in this unit and most of it is on secondary. Nothing really on primary silicon. Maybe some of the primary silicon is bad, or insulation tab between them and the heatsink?
                                • Behemot
                                  • 4845
                                  • CZ
                                  Been also thinking whether it may be some leaking ceramic cap or something. The ground behind rdectifier may be somewhat flotaing over the earth ground because of that and have higher potential. Bu I guess I will have to start with removing the heatsink and cheking all the silicon and insulation tabs/O rings…?
                                    Enermax Liberty ECO 400W [ELT400AWT] - from scraped to serviced
                                    by momaka
                                    Remember this pile of junk electronics I got last year? Well, that's where this Enermax Liberty ECO 400 Watt PSU came from. Like I mentioned, it had cut cables and many bulged caps on the DC output side. I stripped a few cables and did a quick temporary recap with whatever junk (but still reading OK) caps I could find, then performed a basic power test – the PSU passed. Thus, I knew I'd eventually go around to repairing it. One year later and we're here.
                                    First shown is the label below, so anyone reading can see what PSU we're dealing with here.
                                    02-15-2021, 01:05 AM
                                  • acedogblast
                                    by acedogblast
                                    11-02-2024, 05:13 PM
                                  • mitsu2k
                                    The Real Dangers of conductive glue.
                                    by mitsu2k
                                    I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
                                    Here is an experience I...
                                    04-16-2023, 06:29 PM
                                  • socketa
                                    Bestec ATX0300F5WA - fast,or slow blow, fuse?
                                    by socketa
                                    I bought a dead motherboard, and connected it to this PSU,
                                    Was checking the standby voltages on the motherboard, and, whilst doing so, the PSU made a loud bang with a flash of light.
                                    So now i truly got a bang for my bucks, and something else to try and fix.
                                    The fuse was blowen, and the top was blowen off of a TNY276PN chip
                                    The glass fuse didn't have any marking to say if it was fast or slow blow
                                    So i checked the marking on the PCB thinking that that would tell me,
                                    but it 's got a T/F8A printed on the board
                                    So should i get a fast blow fuse, or should...
                                    05-17-2022, 01:22 AM
                                  • ohren
                                    Why did my MOSFET blow up?
                                    by ohren
                                    I had a switching transistor and PWM IC blow up as part of a repair, where a big chunk of each went missing. Now I would like to understand the likely turn of events, and maybe determine if I did something stupid. If nothing else, I should at least extract some lessons from it.
                                    "IC10" can be found on page 169 in the service manual:
                                    https://www.manualslib.com/download/...n-Mas-101.html
                                    The entirety of the repair is basically:
                                    1. Device doesn't power on (IC10 supply voltage unstable)
                                    2. Replaced C18 and C66
                                    3. Device works...
                                    04-30-2023, 06:59 AM
