i need dell inspiron 17-3721 bios M/B VAW11 LA-9102P REV 1.0 (A00)
i need dell inspiron 17-3721 bios plz
Re: i need dell inspiron 17-3721 bios plz
here is your biosAttached Files -
Yes what they said and then some. It is always good to meet someone with skillz. I doubt there is much I can do for you but if I can let me know. I solder down to the size of this period. I have some experience with data recovery, very odd repairs to very odd size LCD panels, as well as repair of industrial controls and systems, logic boards, motherbords, PCBs and more. Lets just says I have been around the block. I am in Portland Oregon, but there is always tips and tricks to share anyway have a GREAT YEAR.Comment
I found.....
if he needs to
anyone ...
works 100%
tested on: inspiron 3721 mainboard VAW10 LA-9105P REV:1.0 (A00)Attached FilesLast edited by 3xdan; 08-26-2019, 10:09 AM.Comment
What is the type of ic must choose on programmer for flash bios?
Also can we flash it with wire clamp or must dessoldering from motherboard?
Thanks in advance!!!Comment
i need dell inspiron 17-3721 bios please
i have try one file but always ask password
Attached FilesComment
by zeniusHello, I have an old Dell G3 3579 (ST: 2WQ7LP2-8FC8) with a newer 8FC8 BIOS password. I have successfully attached to the flash chip (W25Q128JVSQ) on the motherboard with a CH341A programmer and made several modifications using Intel FIT (e.g., allow software SPI write) without bricking. I was also able to boot to a modified GRUB shell where I attempted to edit many BIOS security related options like BIOS Guard/Lock, Flash Signature Override, ME FW Image Re-Flash, etc.
Unfortunately, some of these modifications like to Intel BIOS Guard failed because it is fused into the PCH. Also,...-
Channel: BIOS Requests ONLY!
by sahamipoorhi...
i need bios of dell Inspiron 17 7000 2-in-1 p42e by chassis Jedi 15/17 cml-mb 18806-1.no display by bios issue.
i used and flashed ( dell Inspiron 17 7591) by same chassis and worked .but TMP not detect showing. and not enabling in bios(after each reset disable again). Most importantly the booting up display and startup bios (before windows loading) is too many slow!
i updated to latest version and try other version but not working!
service tag: HCQ3JW2
i need your kind....-
by zlr8rlooking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
cheers
Dell Inspiron 17 (7786) Laptop
Service Tag: 5J0NHT2
Bios: 1.9.0
MOBO: RO 15 17 WHL 2GB MB / 18706-2
Attached;
1. My saved bios using a programmer
2. Dells Bios updater .exe (v1.16)
3. Dells Bios recovery file
4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
5. Image of ME...-
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
Channel: General Computer & Tech Discussion
04-23-2025, 04:30 PM -
by GadgetsFixHi everyone,
I'm in need of a BIOS file for a Dell Inspiron 16 5630. Unfortunately, I don't have access to the original BIOS file as this is for a replacement BIOS chip installation.
- Model: Dell Inspiron 16 5630
- MainBoard Part Number: 4550SC01C004
- Laptop Serial No: GKH3JX3
- DP/N: 0303KM
- QUAKE N RPL UMA CS MB
- 213251-2
- TMN0H$KB
Thanks-
- Loading...
- No more items.
