Samsung PN50b550T2FXZA Y Sus BN96-09744A
    Please help me trouble shooting this BN96-09744A , BOARD NUMBERS: LJ41-06153A, LJ92-01611A, 611A on sticker . I have sound after replacing the main board with supposedly brand new boar ordered directly from Samsung parts .. Vscan show the correct voltage .That's all i know how to test ..
    Thank you
    Re: Samsung PN50b550T2FXZA Y Sus BN96-09744A
    you need to post clear pictures of the board layout of each individual board
      New Main
      Logic
      SMPS
      X sus
      Y sus
      Buffer
        Short out pins 3 and 4 of the little black square located here:
        Disconnect the LVDS cable (the one that connects the control Board to the main board.
        Power on the tv.
        Do you get test patterns?
          Power on the tv.
          I will check when i get home .Just curious What will the result proof
            Control board, in the centre of the Tv has lots of white ribbon cables coming out of it going to the panel and sustain boards.
              I disconnected the Ribbon cable that connect the Main to logic
              Shorted Pin 3 and 4 on the Logic board
              Powered Set on and still received Black screen no test pattern ..What that mean
                It means that there's a good chance that the mainboard is working.
                If you got test patterns then your new mainboard would be faulty.
                In a dark room, Does the panel glow?
                  Is there a LED on the control board?
                  If so Does it blink every second or every 6 seconds?
                    The Panel Does not glow .. Total Black out to say
                      Yes there is a green LED and blinks every second
                        Was i suppose to connect the main board back after jumping pin 3 and 4 .
                        https://www.badcaps.net/forum/showthread.php?t=26790
                        Mentioning that on post #2 ...
                          Any one have other test suggestion to determine which board / component the cause of my problem .
                            what voltage do you have for
                            VSCAN
                            VSCH
                            (located y-sus)
                            VE
                            {located on x-main)
                              I will tackle it when I get back in town and post the reading
                              It's good to take a break
                                VSCAN
                                VSCH
                                (located y-sus)
                                VE
                                {located on x-main)
                                Here is the result With the Set On
                                Vscan =-199 to -201 V
                                VSCH = ???? Could not find it
                                VE= 84 V
                                Also i have a q on previous test i performed DO i need to keep the main disconnected when i power the set during shorting pin 3&4 on the logic
                                  Any One ....!
                                    Originally posted by R1racer View Post
                                    Any One ....!
                                    bump
                                      I repaired a Samsung PS50B430 TV that internally looks almost identical to this.
                                      Same symptoms, good vs va vsc and ve.
                                      Luckily though I had a spare control board from a PS42B430 lying about.
                                      Changing the control board fixed the problem.
                                      Basically you will need a scope to troubleshoot this further,
                                      or take a chance and buy a control board.
                                        So what you saying is there a good chance that My Logic board is gone even with the Green LED flashing .?
                                        I am trying to understand is the VSCAN voltage is the only way to tell if the Y main is bad ?
                                        I also have access to scope but what should i do or test , Simply not sure what to look for
                                        I found this video as well and done all the steps except at Minute 3:26 where i was suppose to get test pic i did not see any thing displayed on the screen at all ,
                                        https://www.youtube.com/watch?v=JjrwTZC5nVg
