hp g62 help disable DSC vga
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    hello fellas
    recently i acqouired hp G62-b63eg xf235ea# with no backlight problem (it has backloght untill windows is loaded, then dim)
    another lcd did NOT solved the problem, so i did reflow and it worked
    its i5 + onboard intel + descrete vga
    motherboard foxconn star federer
    pn: 01013Y000-575-G
    PM_I_HPC_S_MV_MB_V3
    BY FOXCONN
    E253117
    two days ago VGA stopped working again, caps lock blink... since i do not need performance and i do not own rework station, i was wondering could you help me disable discrete ati vga on this motherboard and switch only to intel uma vga and like youve done with that dell
    https://www.badcaps.net/forum/showth...ghlight=n50%2A
    here is a schematics
    any guidance wold be helpfull
    this is my personal laptop, not work
    Im Back... sort of...
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: hp g62 help disable DSC vga
    does anyone have board-view?
    tracing components with magnifier is kinda slow... :/
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      https://www.badcaps.net/forum/showpo...21&postcount=2
      link photo HD:
      http://rusfolder.com/30340730
      the boardview, open it with asus tsic
      • highpulse
        i hate HP
        • May 2013
        • 1488
        • portugal
        hey Donald , remove the main mosfet that feed the discrete grafic , like this is will only work with intel grafic card
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          ive done some work, placed some components (pics will come later), flashed bios and laptop came back to life... but i still see ATI DSC vga in device manager... :/
          moded bios with unlocked features and menus (it was working before), now does not work, caps lock blinks
          i had to restore bios by eeprom tool (not problem for me...)
          now comes testing
          @highpulse
          did not remove mosfet, my solution worked before you post, so... in future i will test your method as well, seems simpler
          • dj_ricoh
            • 2073
            • uk
            so you leave the coil there and remove only the FET?
            and if they are 2 there?
            • highpulse
              i hate HP
              • May 2013
              • 1488
              • portugal
              if you kill the main line , it will disapear and no longer bug you
              chek pic
              • teknikbursa
                • Sep 2014
                • 64
                • turkey
                now comes testing
                @highpulse
                Waiting pics
                • ala_borbe
                  aka Donald
                  • 1625
                  • Malta
                  chek pic
                  tnx for help, yep your solution worked as a charm.. you are true magician, hope i will learn this stuff too.. temps go down as i disabled desc ati, it no longer appears in device manager
                  its nice to have a toy to play
                  i managed to upgrade ME frimware and unlock hidden menus in bios... so far so good.... (other moded bios did not work for me cos i dont have second vga, machine did not boot with them so i unlocked it myself )
                  next i will try to put me7 (insted factory me6) to see will it have any advantages or will it work at all
                  i will post results as usual
                  • rs232killer
                    • Feb 2015
                    • 89
                    • Portugal
                    wondering if anyone found Acer 5xxx and toshiba l850 c850 ati disable
                    • rs232killer
                      • Feb 2015
                      • 89
                      • Portugal
                      ----- Samsung RC530 RC530-S02
                      Remove Nvidia Chip --- works with intel HD
                      HDMI port disable
                      • dj_ricoh
                        • 2073
                        • uk
                        Can I only take the coil out?
                        Or I need to take fets out instead of coil?
                        • ala_borbe
                          aka Donald
                          • 1625
                          • Malta
                          if we are talking about this hp only remove PU320
                          • highpulse
                            i hate HP
                            • May 2013
                            • 1488
                            • portugal
                            dj ricoh i was wrong , not the fet , you must remove DGPU output ic , usually pu320
                            donald im happy i helped you out , you helped me a lot as well my friend
                            thk in advance
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1488
                              • portugal
                              well anyone have this boardview , having big issues with a bloody white screen .
                              so if someone can share this boardview i apreciate it
                              thk in advance
                              • highpulse
                                i hate HP
                                • May 2013
                                • 1488
                                • portugal
                                well this , one its a bitch ..
                                machine was giving image after a short grafic reflow , my coworker replaced chip and he noticed that machine started to give white screen only .. so we have removed pu320 to disable discrete , but STILL SAME with ibtel grafic .
                                So therefor we tought some problems with mux or cpu or pch , possible problem , before replaced does cheked pin 40 39 38 , -19 volts ok pins 1 and 2 vccLCd 3.3 , +3.3vs as well present , so all voltafges are present on the lvds connecctor.
                                so replaced both mux , same issue white screen , replaced cpu and ram , same issue . replaced pch same issue . replaced screen assembly same issue ... got always white screen .
                                cheked bios , same issue ... even replaced the amount of transistor from Backlight to lcd enable all the 13 transistors were relaced just in case , even the good ones that i tested. stlll same issue .
                                so it only can be a signal issue .. but who send the signal to LVDS is pch among with the mux ..and both replaced and still same issue !!!!!
                                really dont know what else to go !! if someone have an idea that want to share , im all hears !
                                • highpulse
                                  i hate HP
                                  • May 2013
                                  • 1488
                                  • portugal
                                  well thats what i call bad luck after all , if you remember i mentioned i had replaced screen assembly 2 times , but after all both assemblys were wth dmaged panels .....
                                  somethimes the fix is just there ,but we trust to much in stupid basic instincts , ehhe
                                  fixed
                                  • ala_borbe
                                    aka Donald
                                    • 1625
                                    • Malta
                                    to fully convert form DSC to UMA either remove PU320 or disconnect PJ19
                                    then switch resistors like in pic
                                    RI53 RI56 and RI51 RI55. -> SKU ID UMA
                                    works 100%
                                    sometimes you need to reflash bios after conversion
                                    • highpulse
                                      i hate HP
                                      • May 2013
                                      • 1488
                                      • portugal
                                      hehe nice , thk anyway mate
                                      • abbas_govani
                                        • Jul 2013
                                        • 89
                                        • India
                                        hey guys can this work on da0ax1mb6h1 board this is hp62-361tx.
                                        there is no pu320. i had locates ic but not sure for that am sharing the photo below. in this board i think that ic is pu11. and m also not having schemantic. too
                                        • brotank
                                          Lenovo C861 Ryzen 5 disable 4GB samsung onboard ram
                                          by brotank
                                          I quiet struggling with board lenovo c681 to disable 4gb samsung onboard ram because they're faulty, I followed the instruction on the schematic to disable them with resistor codes but still not detecting the ram on the slot.
                                          can someone disable onboard ram from my dumped bios, please 🙏
                                          I tried the other bios on this forum with disabled onboard ram, but no success
                                          my final try is to find someone that can help disable onboard ram in my dumped bios attached in this post.
                                          after that I officially give up 😂
                                          thanks for awesome jobs 😊...
                                          03-16-2025, 12:51 PM
                                        • b-slayer
                                          Acer A317-53 need help to disable faulty onboard ram
                                          by b-slayer
                                          Hello.
                                          I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
                                          - first one is to modify le bios to disable the onboard ram.
                                          - second one is to disable the onboard ram by desoldering some components on the mainboard.
                                          so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
                                          so i found that my motherboard...
                                          10-12-2024, 03:46 AM
                                        • Mr.Ultimate
                                          Alienware 13R3 bios mod request - to disable dedicated graphics (dgpu failure)
                                          by Mr.Ultimate
                                          Hi everyone, hope to get someone to help and modify bios rom for me.
                                          I need to disable dedicated nvidia graphics chip permanently.
                                          GPU chip had failed(cracked silicon DIE) and I can only use laptop without failing if I disable nvidia graphics in dev manager (but it still draws power from battery and generates thermal signature.
                                          Ideally if it was disabled from bios at preboot.
                                          I believe it is possible, because if I attatch external alienware graphics amplifier , laptop at boot will disable dedicated graphics #1 (failed one) and will only boot with AGA...
                                          08-06-2024, 05:15 AM
                                        • mat2k
                                          Disable faulty soldered RAM on Acer A315-22
                                          by mat2k
                                          Hello, I've been googling for some pointers on this but couldn't find anything that applies to this board. I have an Acer A315-22 (board NB8607) with faulty RAM between 142 and 174mb. I just wanted to disable the onboard RAM altogether, but this one doesn't seem to have any memory down ID resistors or strap in order to disable it. I'm attaching the schematic I found, the boardview for it also seems to be available somewhere in this forum but I still don't have a use for it lol.
                                          How would I disable the RAM on this PC? Thanks for the help.
                                          [MOD EDIT] LINK to boardview + schem...
                                          06-02-2024, 11:26 AM
                                        • bbenalmadena
                                          Old Sony VAIO da0hk5mb SVE1512E1E disable Radeon video card
                                          by bbenalmadena
                                          I have a Sony VAIO SVE1512E1E (motherboard da0hk5mb) video card is broken, has artifacts, I want to disable it, the processor is an I3-3110M that supposedly has an integrated Intel GPU and I want to disable the onboard Radeon so that can be used.
                                          I download some schematics, and tried to remove VPL1, but then the laptop starts some leds, and shut off. Should I try to lift VPL1 and VPR47 and pass a cable to one tip of VPR47 and the other back to VPU1 to see if that works or it is pointless?
                                          That seems to be some feedback to VPU1 and I guess if it does not detect voltage, laptop...
                                          08-30-2025, 10:40 AM
