Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Old 04-13-2018, 11:38 PM   #121
Spork Schivago
Your Awesomeness
City & State: Corning, New York
My Country: United States of America
Line Voltage: 120VAC 60Hz
Default Re: CH341a SPI / IC programmer
Originally Posted by mockingbird View Post
That's a good point... Indeed, the SB Live connector is a much shorter connector. But I think you should be ok since the crimp end of the Dupont connector probably goes all the way down to the pin hole.
The ones Stj linked me too appear to the be the same ones I have, and the connector does NOT go all the way down to the pin hole. I got mine off SparkFun, and then a bunch off eBay, and I think AliExpress. I got I think like 500 different types, male to male, male to female, female to female, etc. I use them when I need to access a JTAG port. Gotta learn a lot more about JTAG and OpenOCD and GDB.
I can dump RAM if OpenOCD supports it, and flash, if it supports it, but that's about it, and there's soooo many options, I think I'm gonna need to learn JTAG and OpenOCD and GDB real well if my business is going to succeed.
Spork Schivago is offline   Reply With Quote
Old 04-14-2018, 05:52 AM   #122
stj
stj's Avatar
City & State: Europe
what is the pin spacing you need (in mm) ??
comon sizes are 2.54 and 2.00
Old 04-14-2018, 11:26 AM   #123
Spork Schivago
Your Awesomeness
Give me a few days and I'll tell ya. We're swamped right now. Never went to bed till 4:30 last night and right back to work.
Blah!
Old 05-10-2018, 10:25 AM   #124
thiagottjv
City & State: Recife
My Country: Brasil
Hi, does anyone have the programmer version 1.31 or up?
I`m trying to use it with a mx25u12873f (its a 1.8v chip) without success.
It reads, but when I verify it says:
"Chip Main Memory with the contents are in disagreement"
Or when I try to detect it says:
"Access violation at address 0097EA42. Read of address 0097EA42."
Does anyone could give me any light?
thiagottjv is offline   Reply With Quote
Old 05-10-2018, 02:17 PM   #125
stj
stj's Avatar
you cant read 1.8v chips without a convertor.
do you have one?
Old 05-10-2018, 06:55 PM   #126
thiagottjv
My Country: Brasil
Hi guys, I finally did it.
STJ, what I used was this:
You just need to put a 68OHm resistor in every pin expept on GND (pin 4).
This lower the voltage from 3.3 to 1.8.
About the programmer...
I was using the version 1.29 and 1.30 (witch support 1.8v chips), but I was probably doing the step-by-step wrong (watched lots of videos on how to use the software on youtube).
What I was doing was:
- Run the software in compatibility mode (Win XP SP3) and as admin;
- Detect (reads the info but with all Unknown);
- Selecting some chip with some specs like my chip;
- Read;
- Backup;
- Erase;
- Read (witch already gave me the "Chip Main Memory with the contents are in disagreement" error after Verify).
I even tried to Program after this steps, but without success.
What I end up using (witch worked) was the version 1.18
And I did these steps:
- DONT Run the software in compatibility mode (Win XP SP3) and as admin;
- Selecting some chip with some specs like my chip (The only one MXIC 16Mb was the MX25L12805D);
- Blank (instead of Erase - after this the Verify stoped showing the error and all run smoothly);
- Verify;
- Program;
- Verify (all worked out ).
After this my motherboard was live again (an Asrock after a "successful" bios upgrade ).
The version (and drivers) I used:
Old 05-10-2018, 09:10 PM   #127
megaraider
City & State: Porto
My Country: Portugal
I'm a: Hobbyist Tech
As reported here "shared" versions higher than v1.27 are known to give inconsistent results
Alternative software is suggested here by stj
megaraider is offline   Reply With Quote
Old 05-11-2018, 04:03 AM   #128
stj
stj's Avatar
that "adapter" is not reliable.
it may drop the voltage to the flash, but it wont boost it back up in the other direction.
there are adapters on ebay for beer money that use a voltage convertor chip.
Old 05-11-2018, 07:36 AM   #129
mockingbird
mockingbird's Avatar
The shorter connectors with the fine pitch are also common in LCDs, and are often used as interconnects. I reckon a USB3 header cable would also be suitable.
You can also either take the leads out of the header alltogether or just cut off the longer part of the plastic.
"...I suppose he wants to be free of youthful associations, as most of us do."
-Robertson Davies
"...don't say oh my god, your god is far away from you. I give you massage. I am your god now."
-Luo Dong
mockingbird is offline   Reply With Quote
Old 05-11-2018, 08:49 AM   #130
thiagottjv
My Country: Brasil
I didn`t know about that. Thanks!
STJ, I know that, and even if the resistors put the voltage exactly on 1.8v the data input can be unreliable.
In a forum from my country lots (LOTS) of people are using this method for years.
Since this was a one time only and I needed to do it fast (I wasnt working since the BIOS got corrupted) I had to do try it.
And here in Brazil these adapters aren`t as cheap. The price of the adaptor is almost the price of the programmer.
Old 05-16-2018, 09:20 PM   #131
ride_bmx_mhell
City & State: makati
My Country: Philippines
version 1.30 ch341a.exe have a virus?maybe not?
ride_bmx_mhell is offline   Reply With Quote
Old 05-17-2018, 12:20 PM   #132
Spork Schivago
Your Awesomeness
Are you still looking for the higher version or no?
Old 05-17-2018, 12:23 PM   #133
Spork Schivago
Your Awesomeness
I know v1.31 didn't clear Norton's personal inspection, but it's not the program, per say, but some sort of bundled package that comes with it (I couldn't figure out the purpose of the external program, it had something to do with drivers, but I had no need for them). Norton detected it as a Virus.
I'll get on my Linux box and upload the latest free version for you guys, that's clean.
Old 05-17-2018, 01:44 PM   #134
stj
stj's Avatar
the hack runs in a vm shell that spoofs the pc hardware a bit to fit the license.
Old 06-14-2018, 06:41 AM   #135
CeeEee4
City & State: London
My Country: UK
Hi
Can CH341A program MX25L6473F bios chip?
I try Black edition, 1.30,1.18 and none have chip when i click "detect"
CeeEee4 is offline   Reply With Quote
Old 07-28-2018, 09:43 PM   #136
lukepro
City & State: Campo Grande
My Country: Brasil
Hey guys, I have an MSI H97 GAMING 3 with a bad flash bios.
So I got myself a CH341a with a SOIC 8 clip, and it's being a nightmare trying to flash a MX25L12873F chip.
The software can read the chip content, however can't erase/write and detect chip automaticaly.
I got an old mobo of mine and reflashed a Winbond chip for test pourposes, it detects, erase, write, normally.
Does anyone have problems with the MX25L12873F too? Am I doing anything wrong?
I'm using the miniprogrammer V1.30 which in theory has the 25L12873F support and the asProgrammer also has support but same problem as well.
I'm glad if anyone could help me.
lukepro is offline   Reply With Quote
Old 07-29-2018, 06:18 AM   #137
stj
stj's Avatar
do you have a datasheet?
the letter "L" in the number often indicates a low voltage part.
Old 07-29-2018, 06:56 AM   #138
vinceroger69
City & State: Nuneaton Warwickshire
My Country: uk
data sheet
vinceroger69 is offline   Reply With Quote
Old 07-29-2018, 08:23 AM   #139
lukepro
My Country: Brasil
By the small research I did usually the 1.8V are the "U" chips
[QUOTE=stj;841918data sheet.[/QUOTE]
thank you
Old 07-29-2018, 08:24 AM   #140
stj
stj's Avatar
well there it is, 2.7 - 3.6v
the programmer should handle 3.3v but i'm not 100% convinced of that.
