Insignia 39" led tv, NS-39D240A13 - no video
  • jackal68
    • Mar 2014
    • 91
    I am trying to diagnose this led tv as the backlight turns on, all the voltages coming out of the power board are there but no video is being shown on the screen.
    The tcon is part of the screen, so I'm wondering if there is a way to check whether it is the main board or the tcon/screen.
    thanks
    Re: Insignia 39" led tv, NS-39D240A13 - no video
    You need to find out if there is 12VDC feeding the integrated T-CON board or not, the LVDS cable on the main board to goes to the T-CON should have 12Vdc on at least one of the pin.
    There is also SMD fuse on the T-CON board and a bunch of switching power supplies on the T-CON board.
    • Shane711
      • Dec 2014
      • 493
      I got this TV ( Insignia NS-39D240A13 ) and it works but the screen flashes through these colors. Like a color test pattern. Pushing exit on the remote fixes it sometimes for 5 seconds and sometimes for 10 minutes, so annoying. I am guessing the EEPROM is bad but I can not find any where to buy one.
      Cycling Colors
      Does anyone have any idea how to fix this? I have even thought of replacing the board from another TV that will fit. If I replace it with an original used part it will only do it again. I have read online about this TV and it seems everyone has the same problem and there seems to be no way to fix it.
      I am hoping someone knows how to hack this or bypass this problem.
      Please help me save this TV, Thank you.
      • Shane711
        • Dec 2014
        • 493
        Update: I have purchased an EEPROM for a 32L121A13 hoping that it will work because it is of the same board but it did not work. I can turn the TV on and off but nothing displays on the screen, it just lights up. So my next step is to buy a main board for the 32L121A13 and change the panel connector. If this does not work then the TV seems to be unfixable. Or if there is someone out there that can read and reprogram an EEPROM that may work as well. The color test would have to be disabled.
        • jackal68
          • Mar 2014
          • 91
          Hi Budm
          I finally got a chance to check the cable coming out of the main board to the integrated tcon and there is 12v coming from the main board. If the main board seems to be working, how do I go about checking the fuses and power switches on the tcon board?
          Another weird thing is that, as soon as I plug the a/c cord to the outlet, the tv panel will turn on by itself (I don't need to press power at all). However, once it is on, I can turn the tv off and on with the power button. Could this be a symptom of the problem?
            You will have to remove the metal frame of the LCD panel to get to the circuit board so yo can locate the fuse.
            • jackal68
              • Mar 2014
              • 91
              It has been awhile but I am finally trying to tackle this tv again. I checked the ps board and pins 10 and 11 have a voltage of 13.5v coming out of them (it is supposed to be 12v)....is that too high or within specs? The rest of the pins have good reading.
              I am trying to first figure out if the turning on by itself issue (when first plugged into the electrical outlet) is the root of the problem. What would cause the tv to turn on by itself when plugged in?
              • Hakuu
                by Hakuu
                Hi There,
                More Details
                TV Model - LG OLED77G1PUA
                07-12-2023, 02:37 PM
              • advant
                by advant
                02-03-2020, 12:25 AM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • Aimbit
                JBL Flip Essentials - Bluetooth not connecting after a fall - video of board
                by Aimbit
                video: https://www.youtube.com/watch?v=S-xBu7m6SwE
                Hi all. I was given this JBL Flip Essential speaker that 'fell from about 8 feet' and then the bluetooth would no longer function. It seems to power on normally and responds to button presses, but it will not showup on bluetooth for any device I try to connect to it.
                The bluetooth daughter board has a 26mhz oscillator that I could not get to read the proper frequency so I tried replacing that to no avail. Thought maybe something was wrong with the bluetooth IC it's connected to, so I tried replacing that as well. None...
                10-28-2024, 09:29 PM
