Before I Tear Into This Panel...
  • mmartell
    • Oct 2013
    • 3189
    Is there a way to tell if the LED driver circuits are working properly ?
    It's a Samsung UN46D7000 which works (when it's not rebooting) because the bottom quarter of the screen is darker than the rest of the panel. Of course I suspect bad led(s) but would like to be prudent before cracking this thing open.
    So what measurements and how to take them ?
  • mmartell
    • Oct 2013
    • 3189
    Re: Before I Tear Into This Panel...
    Sorry, pic of the led connectors coming shortly, have to get my son off the bus
    • mmartell
      • Oct 2013
      • 3189
      Some pics...
      • mmartell
        • Oct 2013
        • 3189
        I've measured the voltages at the four long electrolytic caps in the first pic while the set was on and stable. The top three had about 147v on them and stable. The bottom one (as seen on the pic) was fluctuating around 295v! plus or minus 5v.
        Any input on what I'm seeing here ?
        • freakaftr8
          • Oct 2012
          • 3743
          This may be because its connected to the output of the dead string of leds so there is no load on the circuit.
          May be normal.
            Originally posted by freakaftr8
            this may be because its connected to the output of the dead string of leds so there is no load on the circuit.
            May be normal.
            +1, more likely open LED string.
            • mmartell
              • Oct 2013
              • 3189
              Ok guys that's good enough for me. Next step is to open it up and try to be gentle
              • mmartell
                • Oct 2013
                • 3189
                Okay so after a few hours this one is repaired. How ?
                This is what they mean by "Labour" as in Parts and Labour. After getting the back off and peeling the last panel (diffuser?) back slightly to see the led connector it seemed a little crooked. Sure enough when I pushed in on the one side it "clicked". I plugged it in right away and was presented with solid even lighting.
                The connector pic is after it was seated and just for documentation. The connector in question is for the right side strip. One vertical strip per side, and I will note it is a different assembly than those used in the D6000 I disassembled previously.
                • freakaftr8
                  • Oct 2012
                  • 3743
                  That's awesome when its a happy ending. Lol
                    Great! So the picture of the connector, is it located inside the panel?
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      This setup is identical to the UN40ES6100 I repaired a few months ago. That one had a bad led driver but I got into the panel too have a look anyway.
                      • mmartell
                        • Oct 2013
                        • 3189
                        Yes bud, required a complete teardown. The backlight assembly had the diffuser or reflector glued to it so it needed to be peeled back slightly to gain access to the led strip connector behind it.
                        • mmartell
                          • Oct 2013
                          • 3189
                          Hah you are very adventurous, I would only do this as a last resort. Aside from breaking the lcd panel itself I'm worried about marking up the layers so fingerprints and dust etc is visible after reassembly. I used two fresh garbage bags to cover assembly while I was working on the backlight.
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            THats a good idea! I use the same thing. Lol
                            • howardc64
                              LG 49UJ6500 LCD panel lighter band that goes away
                              by howardc64
                              49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                              Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                              02-19-2023, 12:13 AM
                            • triplefour
                              SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                              by triplefour
                              TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                              tcon is built into mainboard.
                              Only one cable goes to panel boards.
                              there is a cable from one panel board to the other that links them.
                              cost cutting measure that results in us having harder time to diagnose.
                              removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                              used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                              07-28-2022, 07:59 PM
                            • Storyteller12
                              QN55Q60R Service Menu Panel Help
                              by Storyteller12
                              I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                              I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                              I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                              the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                              01-13-2024, 01:57 PM
                            • maneatingmonkey
                              Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                              by maneatingmonkey
                              I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                              There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                              03-27-2024, 07:17 AM
                            • howardc64
                              Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                              by howardc64
                              • Prior owner tried a replacement main board. No difference.
                              • Samsung 2x red blinking standby LED = panel fault
                              • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                              • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                              • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                              07-19-2025, 10:54 PM
