hp pavilion g6 schematic
  • aanan
    • Dec 2010
    • 222
    • India
    hp pavilion g6 dead some part u307 u518 u517 allready removed u513 damege
    board 6050A2450801-MB-A02
    need schematic.
    Thanks.
  • aanan
    • Dec 2010
    • 222
    • India
    Re: hp pavilion g6
    anyone please.
    • sparker1
      • Sep 2011
      • 343
      Re: hp pavilion g6
      Is it this one?
      • Compute
        Master
        • Oct 2014
        • 97
        • Russia
        Re: hp pavilion g6
        Originally posted by sparker1
        Is it this one?
        У него плата от Inventec а не Quanta
        • aanan
          • Dec 2010
          • 222
          • India
          Re: hp pavilion g6
          sparker1 board & schematic no maching anyway Thanks .
          processer i3 370m
          chipset sl6zs
          kbc it8572e
          • sparker1
            • Sep 2011
            • 343
            Re: hp pavilion g6
            Here's some more but I haven't looked at them. One of them is an inventec board.
            • Compute
              Master
              • Oct 2014
              • 97
              • Russia
              Re: hp pavilion g6
              So a sense upload all of them?
              Now I will upload the scheme and boardview
              • Compute
                Master
                • Oct 2014
                • 97
                • Russia
                Re: hp pavilion g6
                Inventec RKY15CP (6050A2450801-MB-A02) Docs
                Schematic
                Boardview
                • Compute
                  Master
                  • Oct 2014
                  • 97
                  • Russia
                  Re: hp pavilion g6
                  Brought me the same in repair, after the water, has found documents and remembered that here, too, was asked, I decided to download.
                  Good luck in the repair
                  • sparker1
                    • Sep 2011
                    • 343
                    Re: hp pavilion g6
                    Somebody else may want one of the others. Boardview is good. Thanks.
                    • Compute
                      Master
                      • Oct 2014
                      • 97
                      • Russia
                      Re: hp pavilion g6
                      I got it.
                      Well if you need any schematics and boardview , create threads as possible if any, I will upload .
                      • aanan
                        • Dec 2010
                        • 222
                        • India
                        Re: hp pavilion g6
                        Many many thanks Compute for sch & boardview fiel currently i need bios fiel.
                        Best wishes from india to Russia.
                        Thanks sparker1
                        • KennethK
                          • May 2018
                          • 6
                          • South Africa
                          Re: hp pavilion g6
                          Hi Guys,
                          I'm new here and finding it difficult to find what I need.
                          I have a HP Pavilion G6 laptop, the screen ribbon cable broke and I replaced it with a new one, as I turned it on I realized that the screen works but the backlight doesn't work.
                          After searching the net I found Badcaps.net and saw a thread mentioning the same problem, Apparently it's the fuse that's faulty on the motherboard, I then tried to locate it on the board to test but that was not very successful and while the board was on one of the other components sparked and now the board seems completely dead.
                          I need to Identify the components and find out if it is possible to replace and get my laptop up and running. May I ask assistance over here?
                          See pics below, I have marked out what I think was busted. I don't know much about technical names of the components, Please help me out.
                          • piernov
                            • Jan 2016
                            • 4439
                            • France
                            Re: hp pavilion g6
                            Those are capacitors, if they are not shorted they are usually fine.
                            What's the motherboard model number?
                            Can you post high resolution pictures of both sides of the board?
                            • KennethK
                              • May 2018
                              • 6
                              • South Africa
                              Re: hp pavilion g6
                              Hi, Thanks for the quick reply.
                              I think those did short cause there was a spark there.
                              I'm having trouble attaching more photos, so I added it to google photos... I hope that's ok and I hope the resolution is good enough. Please see link below.
                              https://photos.app.goo.gl/941SvoRrREX9zkDd2
                              battling with the internet this side, will upload more photos as soon as I can.
                              The serial number on the board is: (R33 DA0R33MB6F1 REF:F)
                              Ken.
                              • piernov
                                • Jan 2016
                                • 4439
                                • France
                                Re: hp pavilion g6
                                Quanta R33 motherboard, schematics and boardview attached. OpenBoardView can be used to open the boardview.
                                C22 and C6 look bad, not sure about C11.
                                You should remove at least C22 and C6, and check if +VIN_BLIGHT is shorted to ground. They will need to be replaced later, but for now for testing they can be left off.
                                Also L5 and L63 just above (this last one is not present on the schematics or boardview, and on your board they are resistors so you may have a different revision) may be bad. Check the resistance across them, should be 0.
                                • KennethK
                                  • May 2018
                                  • 6
                                  • South Africa
                                  Re: hp pavilion g6
                                  Thank you very much Piernov... I'm gonna play around with this over the weekend. Will let you know what I can accomplish.
                                  • KennethK
                                    • May 2018
                                    • 6
                                    • South Africa
                                    Re: hp pavilion g6
                                    Piernov....
                                    YOU ARE A GENIUS!!! Thank you so much for the help... I removed C22 and C6. Tested it and then replaced them with the same components from another board that was blown. After that, I bridged L5.
                                    And now my PC is like a monster again. I am super grateful for your help. So thorough, quick and speedy.
                                    This is by far the best forum I have ever joined.
                                    Have a fantastic week.
                                    • piernov
                                      • Jan 2016
                                      • 4439
                                      • France
                                      Re: hp pavilion g6
                                      Great to see that you found the issue. But I would recommend you to replace L5 rather than bridging it. It somewhat acts as a fuse in this circuit so replacing it will help with preventing the damage to go furhter up the line if ever something goes wrong again.
                                      You can replace it with another 0ohm resistor of the same size or a fuse (something like 3A 32V).
                                      • KennethK
                                        • May 2018
                                        • 6
                                        • South Africa
                                        Re: hp pavilion g6
                                        I will be doing that. I must say... This was the first time ever that I have soldered something so small. I think I have found a new addiction. I'm looking for more things to fix, people are so easy to throwing things out instead of just thinking a bit further and just try fixing the problem. Thanks again.
                                          HP Pavilion Pavilion Desktop - 570-a079w Pavilion 570 J4205 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-a079w can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-a079w boardview and Pavilion Pavilion Desktop - 570-a079w schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 03:44 PM
                                          HP Pavilion Pavilion Desktop - 570-p030na Pavilion 570 i3-7100 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-p030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p030na boardview and Pavilion Pavilion Desktop - 570-p030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          HP Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) Pavilion 550 i5-6400 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) boardview and Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          HP Pavilion Pavilion Desktop - 570-p056 Pavilion 570 i7-7700 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-p056 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p056 boardview and Pavilion Pavilion Desktop - 570-p056 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          HP Pavilion Pavilion p6560be-m Desktop PC Bundle Pavilion p6500 E6600 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion p6560be-m Desktop PC Bundle can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion p6560be-m Desktop PC Bundle boardview and Pavilion Pavilion p6560be-m Desktop PC Bundle schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
