Panasonic TH-P50X20
  • Neelix
    • Oct 2013
    • 145
    • South Africa
    Panasonic TH-P50X20
    I have TH-P50X20 TV that turns off with 7 flashes. I did the isolation test and measured resistances of the SD and SU boards. The resistances seem fine and with the SD and SU boards disconnected and SC50 shorted out, TV still turns off with 7 flashes. I turn TV on and measure voltages - VSUS is 191V, VAD is -0.8V, VSCN is 93V, P15 is 15V and P5 is 5V. After few seconds all voltages to SC board start to go down, relays click off and light flashes 7 times. With VAD being only -0.8V, that's where the fault must be. I measure all the transistors and diodes mounted against the heatsinks and don't measure any shorts. I look at the circuit diagram for the VAD voltage generator and it's mind boggling Any help with finding faulty parts in VAD circuit would be welcome. Partnumber of SC board is TNPA5063/2
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TH-P50X20
    How are you checking for shorts? diode and/or resistance?
    • tw2005
      • Oct 2011
      • 6458
      I saw a repair kit for 7/10 blinks. says 22 parts, some as below
      Panasonic Repair Kit contain 22pcs components.
      Q401 Q402 Q421 Q422 Q660 Q661 Q452
      D482 D422 D8XX D7XX? Q7XX AND Q7XX?
      IC521 IC7XX IC7XX? PLUS SURFACE MOUNT DIODE AND RESISTORS.
      Symtom; power LED blinks 7 & 10.
      • tw2005
        • Oct 2011
        • 6458
        also Vscn is out of range too, 125 - 166V, outside of that also triggers 7 blink
          VSCN is usually wrt to VAD, low VAD can cause low VSCN.
          • tw2005
            • Oct 2011
            • 6458
            have you had a poke and checked any of these diodes for short
            • tw2005
              • Oct 2011
              • 6458
              Can you measure TP82-gnd resitance, resistance across C561, resistance at the pins marked IC771, SC2 resistance. If you can measure twice , once for each polarity of the probes.
              Just looking for any clues of normal Sc failure, the SS in these also shorts although I 'd expect 4 or 10 blink
              • Neelix
                • Oct 2013
                • 145
                • South Africa
                Thanks tw2005. I'll do those measurements and reply with my findings when I'm done. I only tested the transistors and diodes using the diode function of my meter. I should have mentioned it, but there was actually transistors and diodes shorted on the SS board, which I replaced. One of the two boards must have caused parts to go faulty on the other one as well. I have a working SS board that I use for testing at the moment in the TV. I just hope the faulty SC board don't mess up my working SS board
                • tw2005
                  • Oct 2011
                  • 6458
                  bad SS can take out the SC because of the ERC cct . The 42" has a SN board, but the cct will be pretty much the same. I expect there are some DG501 transistors and the SMD diodes associated with them short. I had a SS blow(after repair) which i repaired originally and i did something a bit daft , disconnected ss11 and left the SC3-SS3 connected, powered it up and blew the crap out of the SN.
                  D441, D451 come to mind
                  • Neelix
                    • Oct 2013
                    • 145
                    • South Africa
                    I measured all diodes and transistors mounted to the heatsinks again as well as the diodes you encircled. The next ones measure short, but they are still soldered onto the board
                    D16481
                    Q16451
                    D16451
                    D16503
                    Q16661
                    D16672
                    D16670
                    So there's a short in the VRL circuit and a short between VAD and VFG. Next is the resistance measurements you wanted me to make:
                    TP82
                    3.79K - black probe GND and red probe TP82
                    1.57K - black probe TP82 and red probe GND
                    C56
                    5.6K - both directions
                    SC2
                    1.65M - black probe GND and red probe VSUS
                    -1.24M - black probe VSUS and red probe GND
                    IC771
                    Resistance starts in the Mohms range and then just continously drops
                    • tw2005
                      • Oct 2011
                      • 6458
                      D16481
                      Q16451
                      D16451
                      D16503
                      Q16661
                      D16672
                      D16670
                      TP82
                      C56
                      SC2
                      IC771
                      "I measure all the transistors and diodes mounted against the heatsinks and don't measure any shorts. "
                      Does not match up now second time around?
                      TP82
                      This seems normal, that's the 15v line and feed the FET driver IC521
                      C56
                      This is the 5V line and is what I expected
                      SC2
                      This I get over 3 meg, the negative you have is because the cct charged, you'd have to short those pins then measure reversed but I'm calling this lower than normal but I have a fluke meter and so hard to judge but I feel this is sus which ypou'd expet if part of the cct is shorted out.
                      IC771
                      This one is strange, this is the 5v reg that powers IC773, normally with a shorted Q661, IC773 and surrounding parts(look at the schematic) are bad and you'd see low ohm short, say 3-5ohms.
                      But what you quote also seems wrong as 5.7-6.1k would be expected in cct.
                      i don't have time at the moment to analyse the rest till I get home from work.
                      If you could associate parts with the locations to help me out get a feel of what's fitted. I'll have to check that the TNPA5066 cct and 5063 are the same(or very close before I can be 100% about IC771, I think it's sus at this stage.
                      Could you recheck this and /or go to IC773 and measure pin 5-3
                      • Neelix
                        • Oct 2013
                        • 145
                        • South Africa
                        I noticed that the tips of my meter probes don't seem to make contact so well anymore. I replaced the probes and measured everything over again
                        D16481, Q16451, D16451, D16503, Q16661, D16672 and D16670 still measure short
                        Resistances of TP82 and C56 same as before
                        SC2 - I shorted out the two pins before measuring in the reverse direction
                        2.02M - black probe GND and red probe VSUS
                        -1.4m - black probe VSUS and red probe GND
                        IC771 - I misunderstood the first time and measured the resistance between the pins you encircled and GND, instead of the resistance between the two pins
                        2.9K - black probe pin 1 and red probe pin 2
                        3.7K - black probe pin 2 and red probe pin 1
                        • tw2005
                          • Oct 2011
                          • 6458
                          Well you're going to have to remove parts to figure out what's bad. IC771 is wrong.
                          Check Q818,701,702. Personally i would replace IC773,Q701,702,818,661, check D702 then recheck Vout -gnd IC771
                          Watch out for low resistance on the IGBTs, some don't go dead short may be in hundreds of ohms, like 30F125, I think this board has that one.
                          D16481, D16503, Q16661, D16672 and D16670 - probably just pull these out and check
                          Q16451, D16451, - I would remove D451, check it and recheck the transistor
                          have you repaired a Sc before?
                          • Neelix
                            • Oct 2013
                            • 145
                            • South Africa
                            Thanks very much tw2005 for all your advice I'll start to remove the parts that measured short and measure them again out of circuit, measure other parts and see what I get. Would have been nice though if I had a working board to compare with. I repaired a few SC boards before, but the SC boards in the later models I'm not having much success with
                            • tw2005
                              • Oct 2011
                              • 6458
                              Yeah, can be frustrating but from what I see a TNPA5066 is equivalent cct so I'll have that to reference to.
                              I know on that one(I've done 2) and it took me a couple of goes I can see I've replaced
                              Q661 RJP63F3A
                              Q401,402 RJP56F4A
                              Q621 , 30F125
                              Q421, RJP43F4A
                              D641, ? Replaced but I used FN25TM4SW
                              D481, ? Replaced but I used FN25TM4SW
                              Q451, DG501RP
                              D451,441
                              ic501,521 not touched but not a bad idea to replace them
                              PC561 opto, I have had to replace but after I blew this board up
                              Q701,702,818 I've replaced
                              IC773
                              R707 I've replaced looks like another casualty of my first failed repair
                              IC771 , I've either pulled it for testing or rplaced, can't tell which.
                              • MOSFET606
                                • Dec 2014
                                • 17
                                Hi, I'v been working on the Sanyo variant of this TV, I'v found a few shorted chips and replaced them,
                                But now the D451 smt diode that says K606 on it, is shorted...
                                I cant find this part anywhere, Does anyone know the part number to this diode, Or a schematic for the actual SS board...
                                All i can find is service manuals with main board schematics...
                                D451 - ?
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  Marking is K6, D1FK60-5073 600V 0.8 amp , super fast recovery diode
                                  http://au.mouser.com/ProductDetail/S...xWMMsAxA%3D%3D
                                  • MOSFET606
                                    • Dec 2014
                                    • 17
                                    And you 100% certain this is the exact one?
                                    just want to be sure
                                    • MOSFET606
                                      • Dec 2014
                                      • 17
                                      Nvm thats good enough, i appreciate the fast reply
                                      I got it now, K6 is type, 06 is date code..
                                      Awesome i tried finding this information but wasnt easy or clear as this datasheet
                                      Thank you!
                                      • MOSFET606
                                        • Dec 2014
                                        • 17
                                        Is there a substitute on mouser for the
                                        Q661 - RJP63F3A On SC board
                                        Ebay says its a mosfet, and rens... data sheet says its an IGBT which it is an IGBT
                                        The shipping on mouser is killing me already at $30... and if im going to order from them i might as well get aleast $5-10 in parts ...
                                        I did some filtering and didnt find any that were rated 630V Collector to emitter voltage
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • AquaMan Ua
                                          Problem with PANASONIC CF53 laptop after changing BIOS settings
                                          by AquaMan Ua
                                          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                          05-17-2025, 09:40 AM
                                        • odie34
                                          Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                                          by odie34
                                          I am a hobbyist (not a professional) so please be gentle...
                                          I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                                          I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                                          02-18-2024, 09:11 AM
                                        • reset1986
                                          acer extensa 15 it works but doesn't charge main la-k093p
                                          by reset1986
                                          Hi everyone, I have this laptop which arrived turned off, the KBC ene IC was short, replaced with an already programmed one, the PC works but doesn't charge, I replaced the BQ24800 IC with BQ24780S now it sees the battery but the orange light flashes and the percentage doesn't increase of the battery which stops at 55%
                                          all mosfets are good, there are no shorts, resistances in their values, what can I measure? I attach the diagram and board
                                          thanks...
                                          11-08-2024, 09:02 PM
                                        • Paft
                                          Panasonic Viera TX-P42S21B - 7 Red Flashes
                                          by Paft
                                          My Panasonic Viera TX-P42S21B 42" 1080p HD Plasma developed a fault a few days ago.
                                          It looks like it's going to come on, makes that click sound but then goes off. Doesn't turn on via remote.
                                          So, obviously it's likely one or more of the components/boards. I don’t see any results for my model or a service manual anywhere, but I’ve briefly looked into it with similar models and apparently it is the SC and or SM board(s.)
                                          How accurate are the fault blink codes? I don’t see any glaringly obvious damage on the SC/SM boards but the power supply has some markings....
                                          10-21-2020, 07:58 AM
