When to replace KBC?
  • MDY
    • Jan 2014
    • 75
    • Spain
    Normally when you replace KBC? Which case?
    If I have 3V and 5V and laptop doesnot run and doesnot try to run, should be bios or KBC, right?
  • highpulse
    i hate HP
    • May 2013
    • 1490
    • portugal
    Re: When to replace KBC?
    not only , if KBC detects something abnormal in some hardware part its suficient to not start . usually you must make some measures on bios and KBC to know if all feeds and signal are present to make the board work . in any case here is a simple turorial
    0. When BIOS & EC-firmware 100% are working
    1. When EC power is present, his quartz working and EC reading the bios data (look data exchange on BIOS chip an oscilloscope)
    2. When ACIN = 3.3V
    3. When LID_SW# = 3.3V
    4. When EC drop RESET from SouthBridge, т.е. EC_RSMRST# = 3.3V
    5. When by pressing of the power button the signal ON/OFFBTN# falls to zero and the same signal is broadcast in PBTN_OUT#
    6. When from the SouthBridge signals PM_SLP_S3# and SLP_S5# are drop, i.e. voltage on them will be 3.3V
    Under these conditions EC should give command for start.
    i hope it helps but there are as well more usefull things to chek , this is a simple chekout
    • MDY
      • Jan 2014
      • 75
      • Spain
      Do you make measure on bios? In Bios only I measure 3V. Can I measure something more?
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3634
        • slovakia
        u can measure the bios loading with osciloscope
        • highpulse
          i hate HP
          • May 2013
          • 1490
          • portugal
          pin 1 spi , but for that like KTM only with microscope , with VM you can notice very
          small oscillation on votlage , but that cannot confirm you much .
          • MDY
            • Jan 2014
            • 75
            • Spain
            Measure the bios loading with osciloscope is good idea? Should I get a osciloscope only for this?
            What do you mean with KTM?
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3634
              • slovakia
              digital osciloscope ffor usb cost about 100e.
              if u r not technician it is useless for u
              • MDY
                • Jan 2014
                • 75
                • Spain
                can you give me sime link to see on ebay or internet?
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • cr4zychriss
                  [Problem/ Request] Bricked TongFang GK7MRFR BIOS
                  by cr4zychriss
                  I am requesting urgent assistance to unbrick my laptop, a rebranded TongFang GK7MRFR chassis. The laptop is completely dead following a faulty in-OS EC flash attempt.
                  I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details
                  • Barebone / Chassis: TongFang GK7MRFR
                  • MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
                  • Rebrand: PC Specialist
                  11-14-2025, 04:04 PM
                • pirati
                  by pirati
                  10-27-2025, 04:20 PM
                • Vesko356
                  by Vesko356
                  08-11-2023, 03:27 AM
                • istvanszasz99
                  Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                  by istvanszasz99
                  Product Name: Razer Blade 15 (2022)
                  Product ID: RZ09-0421
                  Motherboard: CH580
                  BIOS Versions I work with: 2.02 & 2.06
                  Bios File Size: 32,768 KB
                  Dear Forum Readers!
                  I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                  I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                  The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                  !!! MY RAZER BLADE...
                  11-24-2025, 05:52 PM
