Vizio SV470M IR sensor problem
  • sansonet
    • Nov 2013
    • 236
    • US
    My TV was working fine, but lately I noticed that sometimes it doesn't respond to remote, which didn't bother me much because I mostly just need turn it on and off because I'm using it with player only. Lately it got worse, now I hardly can get remote to work with it at all. Tested batteries on remote, programmed universal remote - problem still exists. I had similar sensor board from 42" Vizio so I tried to replace - it still the same. Right now if I'll turn it on manually, and would press volume button on remote continuously, sometimes I'm getting response, but it stops and starts responding in random. It does the same with both sensor boards. Solder joints looks OK and tested OK with continuity tester. I'm adding pics of sensor boards - only difference between them is that board from another TV had ZDR1 component and original does not. They little different in size, but that board respond to remote sometimes too, so I think they pretty much the same. Anything else I should look at?
    Added pic of main board too, part where sensor connects to it.
  • sansonet
    • Nov 2013
    • 236
    • US
    Re: Vizio SV470M IR sensor problem
    Looks like nobody in this forum experienced such problem or knows solution...
    I have little more info, maybe this will help. In the last couple days was trying to locate problem and found few more things. I tried factory reset to see if it will help - it didn't, but turned out that not only IR sensor malfunctioning, but control buttons on TV too. After resetting it, I was using it to set TV to my preferences again. At first buttons was working, but then "menu", "ch up/ down" and "power" on TV stopped responding too. Volume and Input seems to be always working fine. Buttons are soldered directly to main board and there is no problem in soldering joints. I'll attach pic of main board - this one from internet, the same one like in my TV. I also did thing that Vizio site suggests - unplugging and holding power button, and resetting remote the same way too. Unplugging TV helps to restore functions, but only for short time - 5-15 minutes, seems less if remote or buttons are used. After that remote and power/ menu becoming unresponsive, but it might start working again in few minutes, then stops again.
    Right now I plugged TV using wireless switch that I programmed to work with TV remote and I just keep it unpowered when not in use. I use it to shut TV down if I can't do it with remote.
    I wonder if this is bad for TV to do it on regular basic?
    Replacement main board is hard to find and ones that are available are way overpriced - over $100--200. I can find repair kit on ebay for this board, but not sure what in there and whatever it can fix problem. They also selling Eeproms for this board.
    I could live with it like it is now because i use only one input for player, I don't change channels, volume can be controlled on player and I just need turn it on /off. But sometimes I need change settings - resolution, brightness, etc and don't want to loose this function completely.
    • sansonet
      • Nov 2013
      • 236
      • US
      I just realized that Vizio logo on front always stays orange, even with TV on and working. It was like that for while, but I missed it somehow - thought it should be this way. Now I think it might be connected to the problem. Hope somebody could respond with some ideas...
      • sansonet
        • Nov 2013
        • 236
        • US
        I really hope I will get some response here...
        Any way, my TV stopped responding to remote completely, but I managed to get similar model with cracked screen not long ago. Cracked TV is 42" SV420M, but boards are compatible. I switched main boards and confirmed that main is culprit here. After reading some topics in here about voltage regulators in Vizio TVs, I measured all regulators on both main boards. All voltages are similar, but not on U4 (its marked L275 G9117) Also, bad board have U9, but I can't find it on good board.
        This is link for good board http://www.shopjimmy.com/vizio-3642-...main-board.htm
        Link for od faulty board http://www.shopjimmy.com/vizio-3642-...for-sv420m.htm
        Here are readings:
        Good Board
        U2
        PIN1 2.02V
        PIN2 3.26V
        PIN3 5.07V
        U3
        PIN1 2.02V
        PIN2 3.23V
        PIN3 5.03V
        U4
        PIN1 2.04V
        PIN2 3.29V
        PIN3 5.03V
        U5
        PIN1 1.99V
        PIN2 3.23V
        PIN3 5.03V
        U6
        PIN1 12.00V
        PIN2 8.08V
        PIN3 6.83V
        U7
        PIN1 2.04V
        PIN2 3.29V
        PIN3 5.02V
        Bad board
        U2
        PIN1 2.01V
        PIN2 3.28V
        PIN3 5.07V
        U3
        PIN1 2.02V
        PIN2 3.26V
        PIN3 5.04V
        U4
        PIN1 0.0V
        PIN2 1.24V
        PIN3 3.26V
        U5
        PIN1 2.03V
        PIN2 3.27V
        PIN3 5.03V
        U6
        PIN1 12.00V
        PIN2 8.00V
        PIN3 6.75V
        U7
        PIN1 2.07V
        PIN2 3.31V
        PIN3 5.03V
        U9
        PIN1 0.54V
        PIN2 1.78V
        PIN3 3.26V
        J6 IR connector
        Good board:
        Black wire 3.88V
        brown wire 5.08V
        red - 0V
        Bad board:
        Black wire 1.57V
        brown wire 5.0V
        red - 0V
        I still would like to find out what is wrong with old board and possibly fix it. I might keep it as backup in this case.
        • kasfamily
          • Aug 2014
          • 774
          • Russia
          U4 possible different set on bad and good board. G9117 https://cdn.badcaps-static.com/pdfs/...79b822d535.pdf Check U8
          • sansonet
            • Nov 2013
            • 236
            • US
            OK, I see I missed U8 because it looks different -
            PIN1 12.00V
            PIN2 0.00V
            PIN3 4.98V
            It's marked AZ7805T-E1
            looks like this one http://pdf1.alldatasheet.com/datashe...Z7805T-E1.html
            Readings are from bad board
            • kasfamily
              • Aug 2014
              • 774
              • Russia
              Need a good photo U4 and U6
              • sansonet
                • Nov 2013
                • 236
                • US
                Here are pics of U4 and U6
                  "U6
                  PIN1 12.00V
                  PIN2 8.00V
                  PIN3 6.75V"
                  Are you sure you looking at the correct in/out/adj pins?
                  1 = adj
                  2= out
                  3 = in
                  U8 is fine, it is 5V regulator.
                  • sansonet
                    • Nov 2013
                    • 236
                    • US
                    Sorry, I posted it in reversed order, correct readings:
                    PIN1 6.75V
                    PIN2 8.00V
                    PIN3 12.0V"
                      1117 adjustable, the output voltage should always be = to 1.25V ref + V adjust, so for this case the out put should be 1.25 + 6.75 = 8V, so it is OK.
                      • kasfamily
                        • Aug 2014
                        • 774
                        • Russia
                        also U4
                        PIN1 0.0V
                        PIN2 1.24V
                        PIN3 3.26V Are you sure you looking at the correct in/out/adj pins?
                        1 = adj
                        2= out
                        3 = in
                        • sansonet
                          • Nov 2013
                          • 236
                          • US
                          Probably reversed too, one on top is 3.26V and bottom is 0V
                            https://www.badcaps.net/forum/attach...2&d=1412866335
                            Are you sure that pin 1 (bottom pin as shown in the picture) is 0V, that pin 1 is the adjust pin which has two resistors connected to it, one resistor (R39) is connected between pin 1 and Ground, the second resistor (R37) is connected between pin 1 and pin 2.
                            • sansonet
                              • Nov 2013
                              • 236
                              • US
                              Yes, that pin reads 0V, I tried few times because it got me suspicious, tried it again just now - the same result.
                              • Shane711
                                • Dec 2014
                                • 493
                                Long time with this post and no final answer as to the solution. Well I got one and I have the same problem. I been lazy these last few months but I got me a Sprinter Van now so I can get some of these fixed TVs out of my way and get some more fixed.
                                So I have this Vizio SV470M and the remote does not work and the volume does not work at all. I can still turn the TV on and off. Going to open it now and check the voltage regulators.
                                OK, so I do not think it is the regulators. I am going to suspect the EEPROM.
                                • sansonet
                                  • Nov 2013
                                  • 236
                                  • US
                                  I think it is EEPROM too, you can find them on ebay for ~$15 with free shipping.
                                  • Shane711
                                    • Dec 2014
                                    • 493
                                    I can program them myself. I already installed a new EEPROM but I need to test the TV more tomorrow. I was able to turn the volume up and down with the buttons but I need to connect a DVD player and test the remote. I will leave an update when the test is complete.
                                    So have you fixed your TV yet? Do you need an EEPROM?
                                    • sansonet
                                      • Nov 2013
                                      • 236
                                      • US
                                      In post #4 I mentioned that I bought cracked screen SV420M which has compatible mainboard, I spent $30 on it so it was not bad, sold stand on ebay so I compensated most of it anyway, still have that cracked TV in my barn - cant decide if I should sell rest parts from it or keep as backup for mine (power board, etc). Thought about replacing EEPROM on old board and sell it too since they are pricey, but never got to it (yet )
                                      My TV was working OK since mainboard swap and Im still using it.
                                      • Shane711
                                        • Dec 2014
                                        • 493
                                        Well I will let you know if the EEPROM fixed the TV by tomorrow night.
                                        • CapLeaker
                                          AcuRite 5 in 1 temperature sensor replacement repair
                                          by CapLeaker
                                          Got a new victim:
                                          AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
                                          A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
                                          B: stuck at some temperature and maybe updating once in 12 hrs or so.
                                          Easy solution is to go to AcuRite website and purchase the sensor. Right?...
                                          04-15-2025, 01:32 PM
                                        • rajbot
                                          No Power problem with Vizio E60-E3
                                          by rajbot
                                          Hi all:
                                          I have a Vizio E60-E3 I am trying to troubleshoot a no power problem with. Thanks to the help on this board and elsewhere, I was pretty sure I had narrowed it to a power board problem. The board in question is a 09-60CAP0D0-00. Image attached for reference, but not of my board (tv is put away at the moment). FWIW, no obvious looking issues with the board.
                                          I measured voltage at power in and on the fuse and saw 120V, so power is getting to the board.
                                          On the pins out to the main board, I got no voltage at all on any of the pins. I assumed this...
                                          03-22-2023, 08:09 AM
                                        • Jackching
                                          Hisense 65R6107 remote sensor
                                          by Jackching
                                          Does anyone know if there is a repair for the remote sensors for these televisions? It only seems to work when it wants to. I tried a different remote and also tried factory resetting the TV. I find if i go close to the sensor that it'll work but outside 2 feet it wont.
                                          10-30-2023, 11:35 AM
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • Zeonalbasta
                                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                          by Zeonalbasta
                                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                          09-13-2024, 01:17 PM
