Supermicro curse strikes again
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Yup, I had another supermicro die... this time it's my X5DAL-TG2.
    What happened was I on a SLIC 2.1 mod streak and like some other units (Including my Tyan Thunder K8WE) I flashed a modded bios I rolled my self.
    What happened was the BIOS installed correctly but then on reboot it froze during the really slow first boot (before optimizing settings)... I hard resetted, now it spins fans.
    I suspect it's a faulty BIOS chip, as in the past it's:
    -randomly reset settings, even on a known good (brand new) CMOS battery
    -radomly died for a few hours, fixed after time (or reseating memory)
    Would ebaying a replacement (pre-programmed) for $16 be the way to go, or is there a low cost (<$50) programmer out there for such PLCC chips (I have dead boards to source chips)? Or does this not even sound like a bad flash chip?
    sigpic
    (Insert witty quote here)
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: Supermicro curse strikes again
    SuperMicro are a curse - a company that -claim- to be server oriented, yet their own production BIOS release stuffs a previously working board https://www.badcaps.net/forum/showthread.php?t=36190 and effective BIOS recovery is non-existent
    At least you have a removable BIOS chip
    If you're going to flash home-grown BIOSes regularly, and using PLCC BIOS chip technology for a while, I reckon you're better off putting your $16 towards something like http://www.ebay.com/itm/NEWEST-PCB6-.../291149206554? so salvation is in your own hands
    BTW, I'm skeptical about bad flash chips - if you have your own programmer, and it can program and verify a chip, that chip's unlikely to be faulty
    • RJARRRPCGP
      • Jul 2004
      • 6304
      May be a faulty CPU or a bad solder joint.....
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • mockingbird
        • Dec 2008
        • 5484
        I think it's possible to flash those chips yourself with a PCI NIC that has the same socket. Don't know any specifics, as I've never tried it myself.
          • 31195
          no, the pci trick only really works on parallel-flash and upto 64k
          most mobo's use hub-flash or lpc-bus
          given that these chips were in the xbox, i'd be surprised if there arent home-brew programmers on the net though.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            I wasn't doing assembly level hacks... just using the phoenix mod tool.
            yeah, I'd kill to have a proper programmer (mainly so i could flash my own AVR chips) but from what i was seeing if i want plcc I'll have to pay at least $75... $75 I frankly don't have.
            I don't think a CPU went as it had been running for 8 days straight w/o crashing before I rebooted to install the BIOS update... given the stability leading up, my guess is either I had a corrupted file (not likely) or the chip itself died due to the flashing (hard to conceive).
            sigpic
              • 31195
              you want to flash AVR?
              well look at this link.
              and if you want to go 100% self make then i can post stripboard layouts.
              because i built one!
              http://www.fischl.de/usbasp/
                • 31195
                oh - if you want to flash PIC 8/16bit,
                the official pickit 2 has it's binary's and schematic on microchip's homepage so you can build your own.
                and tbh if your going down the pic route you want a pickit2 or 3 because it works with the official mplab-x software.
                • brethin
                  • Dec 2008
                  • 1907
                  Why not just flash the non mod bios back to the board? This board supports Recovery Flash so you don't need a programmer or have to remove the bios chip.
                  To recover BIOS: a recovery flash requires an update key over the COM
                  port as follows: hardwire Pin4 wires to Pin8 and Pin9, Pin7 wires to Pin6,
                  Pin3 wires to Pin2 and leave Pin 1 and Pin 5 open. Use the Supermicro CD
                  to make a “Phoenix BIOS Crisis Disk for Supermicro Mainboard”. This disk
                  includes a BIOS file named “bios.rom”. Please note, this BIOS file can be
                  changed to a different Phoenix BIOS file as long as it’s named “bios.rom”.
                  Connect the serial key to the COM port, insert the recovery disk into floppy
                  drive and power on the system. When the system starts to read the disk,
                  remove the serial key immediately. When the system is done with the BIOS
                  recovery, it will automatically reboot.
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16958
                    that'll teach ya to mess with with what wasn't broken.... Kinda hard to blame SM for that!!
                    <--- Badcaps.net Founder
                    Badcaps.net Services:
                    Motherboard Repair Services
                    http://folding.stanford.edu/
                    Team : 49813
                    Join in!!
                    Team Stats
                      • 31195
                      Originally posted by Topcat
                      that'll teach ya to mess with what wasn't broken....
                      hey, that's what we do!
                      • cheapie
                        null
                        • Jul 2010
                        • 849
                        Makes me wonder if there's a reason that they didn't just use a switch...
                        I have an MSI board that can boot using a ROM file on a USB flash drive, even if the firmware on the board gets corrupted. I've never had to use it, but I tested it and it works.
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Did I blame SM? No. I just seem to have a personal curse with SM...
                          sigpic
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            changed to a different Phoenix BIOS file as long as it's named “bios.rom”.
                            Will try... I do have some serial adapters and the original CD (thanks topcat!).
                            sigpic
                            • Mad_Professor
                              A Mech Warrior
                              • Feb 2011
                              • 1587
                              My supermirco board x9scm does weird shit as well, I only bought it on the recommendation of the brand by topcat.
                              Sometimes on a reboot the board forgets it's boot device/priority. The supermicro chirp is different on every reboot. The Fan on the CPU doesn't spin for the first 5 seconds. When running a pair of usb tuners on two different usb slots on the board, running digital on one and analog on the other, when running the analog, it causes the digital tuner to go all laggy and has video corruption. Doesn't matter what tuner brand, have no idea what causes it.
                              The two nics after sometime stop working no kernel panic, nothing, just stops working, it has to be up for a long time for it to happen.
                              Other than that board is pretty solid.
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16958
                                It came across that way, as per your thread title name which very much implies that you're blaming SM: " Supermicro curse strikes again "
                                The fitting title should be " Ratdude can't leave well enough alone curse strikes again"
                                No clue on that one..... They've always been such amazingly solid in the 15+ years I've used them.... As a matter of fact, all my big boy systems are SM boards, no quirks or abnormalities at all. RD's would still be alive if he wasn't using our government's motto on it....which is "If it aint broke, fix it till it is". I tend not to mod BIOS's unless there's an update for a major bug fix, or a major firmware update for an onboard device...
                                Is the BIOS ROM hard soldered on these boards or is it socketed? I really don't remember. I still have a working board in a system here that I use for my shipping desk. In all my years, I don't ever recall a BIOS ROM 'going bad' that wasn't a man-made failure, IE: bad flash or some silly twit putting it in backward.
                                *EDIT*
                                How did I miss this one, as I knew someone would say it!! Guilty as charged when it comes to messing around with hardware....
                                Team : 49813
                                Join in!!
                                Team Stats
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  Mainly because my specialty is AVR in C. My arduino mega knockoff will work for now (codevision AVR has an arduino upload function), it was more of a "it would be nice" to be able to program any chip.
                                  sigpic
                                    • 31195
                                    look at the site - he sells a pcb & controller for 12euro.
                                    he didnt when i built mine or i would have just paid for the board!
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16958
                                      Isn't anyone crafty enough to hotflash anymore? That was always a fun adventure and usually quite entertaining!
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        I was trying to free up some 7 upgrade copies I had... this was my last personal system (one of two in the house) still using one... The mod had worked on everything else in the house (minus two Insyde BIOS machines, one I may retry later). Even my weirdass MPC AIW (with a Blazing pentium D no less) accepted... it's the first failure I've had.
                                        I always update because I feel that if an update was made, there was a damn good reason for it. I'm also smart about when I update (I.E. not during a thunderstorm when I may lose power).
                                        Socketed. As it should be.
                                        /thread
                                        Made the Serial dongle (grabbed the parts at ratshack and soldered away). The floppy (which took some work to produce, I had the wrong CD in the box) is going as I type... If this doesn't take, can I take an identical chip from a dead board (different model/brand) and use the recovery to flash that?
                                        sigpic
                                        • ugamazing
                                          Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                                          by ugamazing
                                          I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                                          08-31-2022, 07:34 AM
                                        • feherhollo
                                          WSON8 NEW Bios Chips READ, ERROR, ETC.
                                          by feherhollo
                                          I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
                                          I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
                                          For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
                                          11-26-2023, 09:33 AM
                                        • Prott
                                          [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
                                          by Prott
                                          Hello dear badcappers!
                                          The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
                                          Backstory:
                                          After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
                                          If there is a way to narrow down which memory module is faulty it would make my life much...
                                          06-03-2024, 12:05 PM
                                        • LukeDavis
                                          Is there a list of known dodgy ATI Radeon chips?
                                          by LukeDavis
                                          Hello again! (People are likely going to get tired of seeing posts from me lol)
                                          I'd like to try and compile a list of known bad AMD/ATI Chipsets and graphics processors.
                                          While I do not possess the knowledge of some of the brilliant minds on this forum, I can at least mention a few chips I've encountered as being troublesome.
                                          1. ATI 216-0752001 (RS880M/RX280M) found inside 2 HP laptops, one I've since deemed screwed, and swapped the board to an intel one, the other HP seems to be less hateful and runs fine.
                                          2. ATI Mobility Radeon X1600 and the...
                                          02-16-2024, 04:34 PM
                                        • piernov
                                          NVidia bumpgate
                                          by piernov
                                          Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                                          Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                                          May complete this post at a later date with more details.
                                          Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                                          03-27-2021, 10:34 AM
