Another Vizio SV421XVT that won't power up
  • Pauls72
    • Nov 2012
    • 5
    I have a 42" Visio SVT421XVT that suddenly won't power up a few months ago. The orange logo is on the front is lit and never changes to white.
    I've used an Ohm meter, Capacitance meter and ESR meter to check all the can type cap's. I have replaced a number of cap's that where bad or questionable on both the power inverter and main board. Still no difference. From what I'm seeing, I believe the problem is on the main board.
    These are the chip part numbers and the current voltage readings. All these readings are with the power on/off button being held on.
    Connectors on the power inverter board:
    INV ON/OFF = 0.00v
    DIM2 = 0.00v
    DIM1 = 0.00v
    12V = 1.18v
    ST/+5V = 5.18v
    18V = 0.19v
    Main Board - p/n 3642-0722-0150 (5E)
    U1
    49530M or 49536M (I can't tell if the last digit is a 0 or 6)
    924034
    pin 5 5.11v
    pin 6 5.11v
    pin 7 5.11v
    pin 8 5.11v
    U2
    L163
    G9117
    pin 1 2.07v
    pin 2 3.31v
    pin 3 5.12v
    U3
    L312
    G1084
    pin 1 2.07v
    pin 2 3.31v
    pin 3 5.11v
    U4
    L163
    G9117
    pin 1 0.02v
    pin 2 1.261v
    pin 3 3.318v
    U5
    L312
    G1084
    pin 1 2.06v
    pin 2 3.31v
    pin 3 5.08v
    U6
    L163
    G9117
    pin 1 0.00v
    pin 2 0.00v
    pin 3 0.01v
    U7
    L163
    G9117
    pin 1 2.07v
    pin 2 3.31v
    pin 3 5.11v
    U8
    AZ7805T-E1
    920019
    pin 1 0.01v
    pin 2 0.02v
    pin 3 0.01v
    U9
    L312
    G1084
    pin 1 0.57v
    pin 2 1.83v
    pin 3 3.31v
    U10
    L204
    G5627
    pin 1 5.07v
    pin 2 0.80v
    pin 3 0.01v
    pin 4 0.81v
    pin 5 3.90v
    pin 6 0.00v
    pin 7 0.74v
    pin 8 5.08v
    I looked at the Vizio DC-DC trouble shouting workflow and it is basically useless.
    I'm open to any suggestions.of where to go next.
    Thanks,
    Paul
    Re: Another Vizio SV421XVT that won't power up
    The LDO voltages look OK, the one with 0V (U8, U6) input is due to the power supply is not turn on by the main board. You need to look at the PS_ON pin from the main to see if it is present.
    Main board right now is not sending PS_ON, BL_ON (INV ON/OFF), or DIM signals.
    • johnboy1313
      • Nov 2012
      • 1959
      Check for any surface mount fuses on the main board as well.
      • Pauls72
        • Nov 2012
        • 5
        Been trying to work on the TV, but it's been sporadically.
        The fuses are all OK.
        I looked at this other thread which was basically the same problem as me and did some of the same troubleshooting.
        https://www.badcaps.net/forum/showth...v421xvt&page=3
        Leaving the Main Board (pin1)
        INV ON/OFF = 1.07v (off) - 1.19v (on)
        At the output pin of the regulators
        _____off____on
        Q1 = 5.00v 0.00v
        Q2 = 0.00v 0.70v
        Q5 = 0.00v 3.30v
        Q7 = 0.67v 0.72v after about 3 seconds it goes to 0.03v
        Q8 = 0.00v 3.21v
        R1 = 1.07v (off) - 1.19v (on) - other end of R1 = 1.09V (off) - 1.22v (on)
        R11 = 1.09V (off) - 1.22v (on) - other end of R1 = 0.00V always
        I also replace these (2) 220uf @ 25V cap's.
        I pulled pin 1 (INV ON/OFF) from the connector.
        I took a 330 ohm and jumper-ed the INV ON/OFF wire to the output of Q5 through the resistor.
        The power supply comes on and so does the display.
        So at this point in time, on the main board R1 which normally feeds the INV ON/OFF pin.
        R1 = 1.09v (off) - 1.21v (on) the INV ON/OFF
        A couple hundredths of a volt higher with no load.
        I guess this is some progress.
        • Pauls72
          • Nov 2012
          • 5
          Well I screwed up, I was looking at U5 instead of Q5
          _____off____on
          Q1 = 5.00v 0.00v
          Q2 = 0.00v 0.70v
          U5 = 0.00v 3.30v
          Q8 = 0.00v 3.21v
          I pulled the board and then took the one cap off and took a lot of pictures so I could accurately trace what goes where. I even metered out from this via pass through to all the transistors and could not find a direct connect to any of them. Not only the ones nearby, I went to every transistor on the board.
          The INV ON/OFF signal goes through this via pass through.
          The INV ON/OFF signal then makes quite a trip around the bottom of the board and goes through this via pass through.
          Which unfortunately comes up through the board under this heat sink, approximately here.
          Not very promising.
          • Pauls72
            • Nov 2012
            • 5
            So I ended up taking the output of regulator U5 and running it through a 330 ohm resistor to the wire I pulled for the INV ON/OFF signal going back to the power supply. About 95% of the TV works, there are only 2 things that don't:
            1) The Power/Standby indicator always shows amber like it's in standby. No big deal.
            2) The 3 HDMI ports on the back of the TV are dead. However the 4th HDMI port on the side works great.
            The Tuner, all the AV and component jacks work just fine and all of the functionality of the TV works just fine.
            So for now I put the TV back together and am living with it. Some day I'll buy a Main board and put the pin back in the connector. Main boards for this set seem hard to come by, most places are out of stock and then they have a hefty core charge too.
              Yep, use it until it dies then the price of the board may come down in price by then, good job for not dumping the TV into the garbage yet.
              • football0062
                • Dec 2011
                • 98
                Just my recent experience with this i wanted to share. i was having the same issue with my set(wont turn on, vizio logo stay amber) took my measurments and noticed my STBY with is the power on signal was 230mv when turned on and 14mv when off. obviously 240mv isnt enough to turn the power supply on. traced back to R1 in the main board. 3.3k resistor. measured good but when in circuit it failed. 3.3v on one side and 240mv on the other. replaced R1 and unit fired right up!!
                CHECK R1
                  Acer Aspire A515-56-511V Notebook 5 Specification for Upgrade or Repair
                  This specification for the Acer Aspire A515-56-511V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-56-511V boardview and A515-56-511V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-06-2024, 11:20 PM
                • Neddsme
                  SANSUI SLEDSC-32HD TV not booting, No stand-by led
                  by Neddsme
                  I have a 32 inch Sansui android TV that stopped booting. i checked the motherboard for any power failures but it seemed OK to the best of my knowledge. The TV does not have a dedicated power supply board so i could not do any isolation but here is a list of all the things i think were relevant to test.
                  if i missed anything you let me know;
                  DDR (1.5V) = 1.484V
                  VDDC = 1.000V
                  VDDC_CPU = 1.151V
                  VDD1V2_DM = 0.000V
                  3V3_STB = 3.315V
                  3V3_M = 3.307V
                  1.8V_M = 1.803V
                  ALL KEYS = 3.310V
                  5V_STB = 5.142V
                  5V ...
                  11-02-2023, 01:33 PM
                • scn101
                  Samsung UN55FH6200 Intermittent Backlight
                  by scn101
                  Working on a neighbor's LCD TV with LED back lighting. I don't have a service manual but have watched a lot of videos and read posts here. Looking for suggestions on how to proceed.
                  Back light (BL) may or may not turn on when TV is powered on. BL will sometimes remain on anywhere from a few minutes to up to 20 mins. BL may or may not return.
                  All testing is with BL set at mid level illumination
                  BL voltage is specified at 331V (per PCB silkscreen)
                  BL voltage with LEDs disconnected 395V
                  BL voltage with LEDs connected 260V
                  When...
                  03-28-2020, 11:56 AM
                • electrocute
                  Lenovo Yoga 3 14 (NM-A381) not powering on
                  by electrocute
                  Laptop: Lenovo Yoga 3 14 (80JH)
                  Logic Board: BTUU1 NM-A381 REV:1.0 2014-11-17
                  Issues:
                  • not powering on
                  • bottom of the laptop getting hot
                  Background:
                  Laptop not turning on. On-board voltage from AC adapter was jumping between 3V (do not recall correctly) and 4.xV, and the fan spinning/stopping on its own.
                  Initial readings:
                  Code:
                  PL202=4.12V  10.5 Ω   .010V drop  Hot Area
                  PL201=1.06V  44.1 kΩ  .320V drop  Hot Area
                  PL401=0V    55.4 Ω   .143V drop
                  PL801=0.04V  71 Ω    .050V drop
                  PL301=0V    112 Ω
                  10-28-2021, 10:44 AM
                • jb_Bak
                  by jb_Bak
                  CN6401
                  Pin 01 NC
                  Pin 02 NC
                  Pin 03 "BL_ON": 0V
                  Pin 04 "N/C"
                  Pin 05 "STBY 3.3V": 3.5V
                  Pin 06 "GND": N/C
                  Pin 07 "AC_OFF"...
                  09-27-2021, 04:52 PM
