panasonic tx42-p42x20b
  • adamp91gvm
    • Jan 2014
    • 699
    • uk
    hi i have the above model tv witch has the 10 blinks of death it clicks and then clicks about 3 seconds later i have had a look on this site a man had the same problem he ended up changing the a board . I can not find a a board for this model any where would any other a board work with this set thanks
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: panasonic tx42-p42x20b
    wrong thread sorry
    • tw2005
      • Oct 2011
      • 6458
      Any pictures of it? is the A-board TNPH0829ME , TXN/A1LWUE?
      SOS 10 can be caused by other boards too. The SS board is a common failure on these, can you check SS11 for short cct with a meter?
      • tw2005
        • Oct 2011
        • 6458
        Shopjimmy
        Ebay
        FlatTvparts _ for part number confirmation
        • adamp91gvm
          • Jan 2014
          • 699
          • uk
          the board says tnph0829 on it not really clued up on how to test but really willing to learn
          • adamp91gvm
            • Jan 2014
            • 699
            • uk
            thats the board but im in the uk
            • tw2005
              • Oct 2011
              • 6458
              Is there a white sticker with a barcode, ME TXN/A1LWUE?
              • tw2005
                • Oct 2011
                • 6458
                well I guess it depends on how bad you want an A-board. both will deliver, not cheap which is why I'd try and fault find it a bit.
                Do you have a mutlimeter?
                • adamp91gvm
                  • Jan 2014
                  • 699
                  • uk
                  only white stickers say eng37f03kf and a smallone saying me-tp3
                  • adamp91gvm
                    • Jan 2014
                    • 699
                    • uk
                    i can get a multimeter tomorrow but dont know where to test it ? thanks for your help
                    • adamp91gvm
                      • Jan 2014
                      • 699
                      • uk
                      this is the page was reading on here
                      https://www.badcaps.net/forum/showthread.php?t=26584
                      • tw2005
                        • Oct 2011
                        • 6458
                        must be labelled different to the UK flat TV picture but the ME-TP3 could be the clue as the rev I was expecting was ME.
                        They can have white stickers with the number or a 2 letter suffix stamped on the PCB or a table printed into the board listing all the suffixes and some jumpers which indicate what suffix it is.
                        We have 3 sources listing an A for this model as the same including 1 UK source so it should be correct or upload some hi res shots of it top and bottom using advanced, manage attachments , max res is 2000 x 2000.
                        Anyway do yo have a meter to check anything?
                        i have the Aussie model TH-P42X20A, pretty much the same, the A board can cause SOS10, I caused mine to do it and it was the cabling was corroded and shorted out the A - SN board ribbom SN20. I fixed it by replacing the 2 buffer Ics on the A talk to the SN and the ribbon also sends 5v to the SN board, so P5v shorted tripped the SOS10 at the A.
                        I'd be tempted to check for shorted Vsus at either SN2 or SS11 first.
                        • adamp91gvm
                          • Jan 2014
                          • 699
                          • uk
                          im going to get a multimeter from work tomorrow and give it a go but im not too sure on where im testing as im kind of new to this .i can re build engines no problem but electronics im just learning
                          • tw2005
                            • Oct 2011
                            • 6458
                            Sure, i was going to suggest unplugging things, i like to back it up with measurements too.
                            So several things to try.
                            Disconnect 3 white ribbons at A, Disconnect SN2 (SN board LHS), SS11(SS rhs) and p35(PSU , feeds the C boards bottom of panel)
                            Power on.
                            Reconnect
                            disconnect SS11, see if SOS10 clears.
                            reconnect
                            disconnect SN2, SN3 and Sn20
                            Let me know the results
                            edit; don't reconnect straight away due to residual voltages on P2,P11 & P35, let it stand for 5 minutes, should really check with a meter. I've spiked those bottom buffers (c boards but a Samsung) and destroyed the Ics on them which means dead panel, no repair.
                            • adamp91gvm
                              • Jan 2014
                              • 699
                              • uk
                              Ill try tomorrow after work and let u know thanks for your help u guys
                              • adamp91gvm
                                • Jan 2014
                                • 699
                                • uk
                                Has anyone ever had transistors go on these ? On the power board
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  I reckon it would be rare, what's happening?
                                  • adamp91gvm
                                    • Jan 2014
                                    • 699
                                    • uk
                                    Just 10 flashing lights I have tried disconnecting different parts of the tv still it just stays at 10 flashes
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      So did you try disconnecting those ribbons at the A and isolate power from the SN,SS an C2 board(P35) and still SOS10?
                                      • adamp91gvm
                                        • Jan 2014
                                        • 699
                                        • uk
                                        Yer allways 10 flashes no matter what I take out
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                          Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
                                          by sam_sam_sam
                                          I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
                                          This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • canadaboy25
                                          Panasonic TC-P54VT25 No image. A or D board?
                                          by canadaboy25
                                          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                          The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                                          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                          01-17-2021, 01:06 AM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          I happened several times, in the search for help from the web, to consult this very interesting forum.
                                          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                          Having said that I come to the gist of my post on the forum as the title suggests.
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
