Samsung LE-40M87BD Screen Bleed?
  • anotherdude
    • Feb 2013
    • 488
    • uk
    Not sure if this is screen bleeding or what but in certain parts the picture can be seen through it
    have tried a hair dryer from the outside just in case it was condensation or the likes but makes no difference neither does touching the effected area
    any ideas? or just a bad panel with damage?
    also there appears to be no impact damage anywhere, lady i got it off said the usual "it just went like that"
    Re: Samsung LE-40M87BD Screen Bleed?
    This is a common issue with this model and is unrepairable.
    Also, I feel it's necessary to remind everyone that people lie, you cannot always trust them.
    • anotherdude
      • Feb 2013
      • 488
      • uk
      ye, keep it as a spare i suppose not too much into it
      cheers for the info tom
      save me opening it up, so how does this come about? just a aging lcd?
        I think it's related to a defect in the bonding between the layers of the LCD but TBH I've never had one myself, just see it now and then on this forum and on ebay.
        • anotherdude
          • Feb 2013
          • 488
          • uk
          spent £55 on it, too much you think?
            Way too much ... just my opinion.
            • anotherdude
              • Feb 2013
              • 488
              • uk
              seems theres another fault with the psu
              tv turns off after a certain ammount of time and turns itself back on
              caps?
                Check READY in service menu... if set turn it OFF... From standby, Info Menu Mute Power on remote.
                • anotherdude
                  • Feb 2013
                  • 488
                  • uk
                  was already set to OFF
                    No further ideas then, other than to troubleshoot rest of PSU by heating/cooling etc.
                    • anotherdude
                      • Feb 2013
                      • 488
                      • uk
                      heat makes no difference to the psu or main board
                      i've had a similar issue previously from a 32 inch model and found it was the main board causing reboots when powered up so i'm going to say it's the same here another bordeaux model too
                      if i remember right it was when the main board went cold it would happen (from startup usually) no idea about how this is seemingly getting cold when it is in operation
                      not worth my time or money to replace the main board
                      may try a rework on it later, some flux and a heatgun see how i get on
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        anotherdude not sure if your a member but may be worth you joining your local freecycle/freegal groups and put a wanted add on for faulty electronics etc i have picked up in the last week about 4 lcd sets and a panny plasma last night all for free i even ask for the remotes hahaha just a thaught to save you money if your not already a member of the sites.
                        • anotherdude
                          • Feb 2013
                          • 488
                          • uk
                          ye never even though to be honest
                          fed up of tv's going for silly money on ebay
                          people bidding them up and then they never sell
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            not sure if you have also tried your local gumtree and preloved sites as well a few cheap ones go on from time to time what part of the uk you in?
                            • anotherdude
                              • Feb 2013
                              • 488
                              • uk
                              found out it is the mainboard unsure whether it's caps surrounding the processor or the processor itself
                              If i let the fault occur then heat around the processor the fault disappears until cold again and continues endlessly rebooting
                              • anotherdude
                                • Feb 2013
                                • 488
                                • uk
                                just to follow up here with the fix (not for everyone)
                                decided against the heatgun and went for the oven instead
                                desoldered the shield hiding the processor/IC's give it some flux and wrapped the rest of the main board in some tin foil (made some foil balls to rest it on) let it bake at gas mark 4 for 15-20 minutes, let it cool and reassembled
                                TV no longer turns off after ammounts of time, left it on for 6-8 hours last night with turning it off and on in between and all seems good now
                                again probably not to everyones taste but easy way to fix cold solder joints (which i'm guessing was the issue)
                                • Chrissygizmo
                                  by Chrissygizmo
                                  02-10-2025, 12:33 AM
                                • Chrissygizmo
                                  samsung galaxy ao2s very temperamental after screen replaced
                                  by Chrissygizmo
                                  Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                  Ive eventually managed to get it on and working but it's very temperamental...
                                  The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                  05-26-2024, 12:05 AM
                                • Kiberge
                                  Samsung LH82QENELGC/EN Help needed - Static line on screen
                                  by Kiberge
                                  HI guys!
                                  I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                  I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                  the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                  This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                  04-22-2024, 11:28 AM
                                • Ryan.man
                                  by Ryan.man
                                  02-04-2025, 12:23 PM
                                • jkruns
                                  M1 A2338 screen and touchbar issues after cleaning up liquid damage
                                  by jkruns
                                  This is my first post after browsing this wonderful treasure trove of knowledge for many, many evenings. I've decided to learn how to fix these things, properly.
                                  My patient is an A2338 Macbook Pro M1 (late 2020).
                                  It had some corrosion around JT710 and JT700 caused by liquid spill, as well as against the protective barrier around the USB-C chips UF000 and UF100. So I took the main board out and cleaned it with a toothbrush and alcohol, then with alcohol in an ultrasonic cleaner. Cleaned the touchbar flex connectors as well. The board looks...
                                  04-22-2024, 06:45 AM
