panasonic TC-P50U50 8 blinks
  • freakaftr8
    • Oct 2012
    • 3743
    just picked up this TV tonight. Blinking 8 times. Looked into the SS bored and found shorted Q051. DG302 mosfet. my understanding is there are a few discreet semi conductors on this board that go south along with the shorted MOSFET. I have yet to find any other short circuits on any components. I wonder if I just replace this DG 302. Does anybody know a good substitute. I don't feel like spending 50 bucks on eBay for a repair kit for this board. I have another Panasonic sustain board that uses a few different mosfets. they fall just a tad short of the specifications of this mosfet. anyone with experience on this board could you tell me what else I should look for in the way of other failed components. it appears to be a common failure on this SS board. Thanks
  • tw2005
    • Oct 2011
    • 6458
    Re: panasonic TC-P50U50 8 blinks
    Nothing like getting it from the source
    • freakaftr8
      • Oct 2012
      • 3743
      Your awesome. Thank you. Surprisingly the components minus the mosfet all test good.
      • tw2005
        • Oct 2011
        • 6458
        so only the one shorted igbt on the whole board? on 2010 SS they had 45F128 Toshiba yet to find the datasheets to see the specs but I'm expecting the DG302 is 360V 40A ?
        • freakaftr8
          • Oct 2012
          • 3743
          Yes thats spot on.
          • freakaftr8
            • Oct 2012
            • 3743
            The heat sync handling the dissipation of this high speed switching mosfet and diode is less than adequate for the task at hand. The bottom of the ss board is dark in the area. Bad design in my opinion.
            • tw2005
              • Oct 2011
              • 6458
              SO do you have the specs for the DG302? SMD version is 330V 45A, 45F128 is 330V 45A what do you have in the Panasonic junk pile to steal from?
              With D041, what are the markings on it ? RF2001T3D?
                2012 Panny? 1080p? Died already? What a joke Panasonic.
                • tw2005
                  • Oct 2011
                  • 6458
                  Did you see the arc marks on the panel? I think Norcal highlighted a quality issue with this series where the screws were loose. Do you think poor earthing may have killed this?
                    Personally I doubt it. They had that issue with their 2010 & 2011 panels. They've had more than sufficient time to sort it out, if it did cause it, that's poor design. I'm going to hug my PZ80, because it looks like there are no good plasmas made beyond about 2011.
                    • tw2005
                      • Oct 2011
                      • 6458
                      I totally agree, The PZ although they have PSU issues are the last of that heavy duty look of engineering. Touch wood my 2009 HD has been going well after a SC going out of spec not shorted was replaced june 2012, the 50 full replacement of SC/SD/SU sept 2012.
                      The 2006 SD I gave to my mate is still going after that simple LVDS reseat and he loves it.
                      Early days
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Agreed. Oh btw. There are arc marks on every screw lug of the ss board. A shame that panasonic went this route.
                        I however have a tc-p55ut50 with a busted screen. Looks like its part scavenging time.
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          Oh yes top screw was loose.
                          • tw2005
                            • Oct 2011
                            • 6458
                            Is the 55 SS the same board as the 50? If you only have 1 part to fix this nothing else in the stash. there'd be a good chance of another 55 being picked up since these are failing by the looks of things.
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              good call check when I get to work that's for the t_v is
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                On a side note thw the pic quality seems to have degraded after th PZ series as well. I put my tc-p55ut50 next to a tc-50pz80u and whe whites are dimmer on the 55 and black level is not great either.
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  Personally, I have the 50G20 equivalent 2010. My 2009 HD has better contrast, and i have a 46 PZ800 and it's definitely sharper. The FHD 2010 model is washed out a bit and dimmer, also has better power consumption and that's probably why as i believe they've concentratedd on reducing power consumption, Just my 2 cents worth.
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    my two cents worth is the less components on each board and the more confined that these TVs have to be lately the worse picture quality. On a side note it appears that the tc-p55ut50 inch uses the same SS board so I already have the board go figure. Oh and the top screw was loose on this one just like my 50 with the shorted SS. Maybe the panel is beind used for some kind of "last resort" heat sync and if the screw loosens the SS cant cool the top mosfets?
                                    • oliku
                                      • Oct 2013
                                      • 2
                                      Good evening. I stumbled across this site & thread because I also have a TC-P50U50 with 8 blinks. I'm a copier tech, so I'm not as savvy with TV's as some of you may be. I know 8 blinks can indicate a number of issues. Since I have low experience, I want to just buy & replace the SS Board because it seems like the most likely culprit.
                                      I was wondering if there was any alternate suggestions or if anyone knew of the best place to buy this board. Seems like the only place I can find one is ebay. Thanks for your help!
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        that's all I found too. yes this board is failure prone. Looj for thus model ir tc-p55ut50 ss board. Same part number.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                          Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
                                          by sam_sam_sam
                                          I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
                                          This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • canadaboy25
                                          Panasonic TC-P54VT25 No image. A or D board?
                                          by canadaboy25
                                          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                          The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                                          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                          01-17-2021, 01:06 AM
                                        • Biruslapio
                                          Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
                                          by Biruslapio
                                          Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
                                          It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
                                          It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
                                          02-16-2021, 09:44 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
