Dell P2210f no power
  • zoop57
    • May 2013
    • 6
    • United Kingdom
    Hi guys,
    I'm new to this forum and was hoping someone could help me diagnose the problem with this power supply from a dell p2210f monitor.
    I've attached some photos of the board, no caps seem to be visibly bulging and I can't spot any blown components.
    Anyone got any ideas?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4476
    • Italy - Milan
    Re: Dell P2210f no power
    1: Clarify your skill level. if you will use the forum in the future report always which test you have done in the first post. 2: tests with mains voltage switched on or off with main cap. charged can be very dangerous, if you know about that, with a dmm control if around 325v arrives to the legs of the bigger cap. 3: if doesn't control the fuse for open, that black cilinder near 220VAC socket. if is ok wait for further instructions or 4: test the outputs voltages, keep present that testing voltages on primary need the negative lead of dmm to be put on a part connected to the - of the big cap., for the secondary you can use those points connected to - of biggers secondary caps, to find the one for inverter section check the middle pin of those 3pin double diodes, if there aren't test with voltage off for short the main transistor on the primary, if it's shorted test the big resistor near it and everything connected to it for open/short apart the transformer 5: check for any other fuse on the secondary, them are labeled F1, F2 or PF1, PF2 etc..
    • Rtech
      • Jul 2010
      • 1095
      How have you confirmed that it is the Power Supply that is faulty ?? When you switch the monitor on WITH a PC attached,does the Power light come on ?? Does the Power led change colour when the PC sends a signal to it ?? does that colour stay on all of the time ???
      • hano009
        • Oct 2012
        • 1
        • Sweden
        Im having the same exact problem, did you find a solution for this problem?
        • lexwalker
          • Feb 2011
          • 307
          • Malaysia
          Did you try checking the easiest components to diagnose? Check the fuses, thermistor and diodes first. Discharge the big main capacitor first before checking! Use the continuity test on the multimeter to diagnose these components. You can use the same continuity test to quick check the capacitors for ability to charge (again, discharge the capacitors first before using this test).
          Attach the IP (inverter and power supply) board to the mains power. Check for any voltages on the secondary side (one of them should be +5V while the other should be +12V or greater), then check the voltage across the big main capacitor on the primary side (should measure anywhere from +168V to +350V depending on your mains voltage).
          Warning! Please put the board on a piece of insulator (e.g. cardboard, thick plastic, etc) and avoid the direct contact with the primary section while the board is connected to the mains power. Just becareful!
          • mde_
            • Aug 2016
            • 1
            • Belgium
            as I found this thread googling around for the same problem and nobody seems to have documented a fix, here's mine:
            I had the same dead power supply and found that one of the big SR520 diodes was shorted. All caps looked fine in my case as well.
            It seems to be insanely difficult to come by new SR520 diodes. Due to incorrect data sheets online (essentially copied SB520 data sheets), I figured it was a 5A 20V diode when it seems that it is in fact 200V. So I ended up buying SB560 (5A, 60V) as a replacement. This did NOT work.
            I then went for a MUR420 "ultrafast diode" as a replacement - as suggested in another forum. Even though it is only specified at 4A instead of 5A, it seems to work well so far. As far as I can tell it is very unlikely that the diode actually has to support 5A in the first place: It is located on one of at least two secondary rails and the whole screen does not use as much power as this diode is designed for. If anyone has a different opinion about that I'm interested in hearing it, though.
            Anyway, I hope this helps the next person coming along with the same (apparently quite common) problem.
            • vhartong
              • Aug 2016
              • 2
              • Netherlands
              Just aquired two broken 2210f monitor (and time to look at it). All caps also looked fine and indeed it was the SR520 diode that is broken. I can confirm this for two boards now (with one it was D855 and the other D854). Will try the fix as soon as I have the new parts.
              Thanks for the post after 5 years!
              • vhartong
                • Aug 2016
                • 2
                • Netherlands
                On both boards I have replaced D855 and D854 with the MUR420 and now the displays work again! (And thus confirming with two more repairs)
                • Leanoric
                  • Jul 2013
                  • 3
                  Same with my dead Dell P2210F; blows one of the parallel configured diodes D855 or D854. One of them goes s/c. Replaced twice with SB type. Now will try with suggested MUR420 type - ordered on EBay. Will post results. (Not expecting to work, problem may be elsewhere, but worth a try?)
                  • Leanoric
                    • Jul 2013
                    • 3
                    Same here, with two Dell 2210f monitors. One monitor working fine. The other found to be faulty LCD panel - turns off after 2secs when power applied. Swapped the panels and found fault lies with panel. Both Power boards, with same repair, now fully working. Played all night on Neverwinter Online with my new HD monitor! Well chuffed. Thanks for this solution guys. Now just need to view more YouTube vids about repairing t-con boards for panels.
                    • Leanoric
                      • Jul 2013
                      • 3
                      Thank you it did. Just hope it's not 'masking' another problem? Will see how long solution lasts, hopefully, won't be a problem in future.
                      • SkullKill
                        • Mar 2022
                        • 2
                        My Dell P2210F blue power light kept tuning on and off in a loop.
                        Just wanted to say thank you. this thread helped me pinpoint what was wrong with mine.
                        removed both D855 and D854 and tested off circuit since they are in parallel.
                        D854 was bad in mine.
                        replaced with a HER605 diode (400V 6A) since that was the closest that was available locally for pickup at Altronics.
                        https://www.altronics.com.au/p/z0120...silicon-diode/
                        Screen is back up and running fine now.
                        • jrcollins
                          • Jun 2022
                          • 7
                          • New Zealand
                          I've got the same problem here. One of the diodes was faulty. Could I use this diode as a replacement? https://www.jaycar.co.nz/diode-6a4-4...ck-10/p/ZR1044.
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            In the original post of this thread you can find the service manual:
                            https://www.badcaps.net/forum/showthread.php?t=48690
                            I would replace both diodes with a matched pair of ultrafast diodes with a voltage rating of at least 400v and 5A because that is what is in the schematic. (SF50-04)
                            Ultrafast diodes are required because this diode sits on the secondary of a high frequency switching transformer, unfortunately Jaycar only seems to stock a 1A ultrafast diode.
                            Note that it is not good design practice to put two diodes in parallel:
                            One will always be slightly different than the other so it will conduct more and eventually fail, this is the reason for replacing both as a matched pair.
                            Even better would be to just leave out one of the diodes and use a higher rated single diode as replacement.
                            It is interesting to note that the schematic seems to show this, because D854 is listed as "NC" implying "no connect" as a possibility:
                            • jrcollins
                              • Jun 2022
                              • 7
                              • New Zealand
                              Thanks for that. Are you are able to give me a link to the schematic?
                              • jrcollins
                                • Jun 2022
                                • 7
                                • New Zealand
                                Sorry, I see you already posted the link.
                                • jrcollins
                                  • Jun 2022
                                  • 7
                                  • New Zealand
                                  I was hoping to find the output power voltages on the 12 pin connector (CN851) but it doesn't seem to be in the manual.
                                  • jrcollins
                                    • Jun 2022
                                    • 7
                                    • New Zealand
                                    What about this one? https://www.ebay.com.au/itm/23460226...cAAOSw5cpit78s
                                    • Per Hansson
                                      • Jul 2005
                                      • 5895
                                      • Sweden
                                      I would not buy from that seller because he mixed up the type of diode in the title of the AD vs the description!
                                      "Ultra Fast Recovery Diode" vs "Standard General Purpose"
                                      -Typical Chinese crap, basically you can never trust to buy semiconductors from eBay or Aliexpress and other such sources.
                                      I realized I made a mistake on Jaycar: I didn't see there where multiple pages to view because of their weird page layout, so here is one that should work great:
                                      https://www.jaycar.com.au/diode-fr60...ck-10/p/ZR1054
                                      As for the schematic it seems a bit of the right of the paper got cut off when it was produced.
                                      But it can be inferred that you should have a +16v for the backlight, and then +12v and +5v for the logic on that connector.
                                      • jrcollins
                                        • Jun 2022
                                        • 7
                                        • New Zealand
                                        Yes, I try to avoid those websites too whenever possible. Thanks for your help.
                                        • zlr8r
                                          Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                                          by zlr8r
                                          hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                                          Ill try and give as much info as I can.
                                          Dell Inspiron 17 (7786) Laptop
                                          Service Tag: 5J0NHT2
                                          Bios: 1.9.0
                                          When I received this , it would only flicker on the KB backlight for a second, then off and on.
                                          Then it started getting weirder!
                                          Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                                          12-12-2023, 09:31 PM
                                        • seppde
                                          Dell XPS 9380 No Power - After providing 3VALW and 5VALW once, they persist - still no power-up
                                          by seppde
                                          I've recently gotten my hands on a defective XPS13 9380. I will attach a zip of the schematics and boardview.
                                          My first discovery on the Board was that the reverse current Diode PD103 of the 1st USB-C was blown.
                                          Nothing to worry about, the board got 3 USB-C ports which support Power/Charging. On I go.
                                          Next I inspected the power-rails to see why the diode blew up and found a short on the 3V3 rail which I traced back to the Power-IC for the LCD (UZ2). I desoldered it and the very low-ohmic short is gone. I checked on the LCD-connector that there's no short...
                                          10-01-2024, 10:57 AM
                                        • khelane
                                          test active pfc power with lamp test
                                          by khelane
                                          Hello
                                          I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                                          Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                                          Is there a way...
                                          06-03-2025, 01:00 AM
                                        • SuperJames
                                          Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                                          by SuperJames
                                          This one's a weird one, and still unsolved despite it having gone back to Dell once.
                                          Specs
                                          i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                                          Backstory
                                          I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                                          10-23-2023, 04:09 PM
                                        • rob_hen
                                          Dell XPS 13 9370 Laptop, No power, not charging
                                          by rob_hen
                                          Hello!
                                          This is my first post for help, and I am quite newer to board repair, so bear with me.
                                          I have this board here (LA-E671P), with no power, and doesn't charge. No lights come on when plugged in.
                                          After visual inspection of the board, U22 is obviously blown up. This is the for backlight, and there is no shorts present after removing the chip and replacing.
                                          There is 3 USB C ports to power this board, USB 1 gives 20V, while 2 and 3 only give 5V.
                                          My observations using USB 1 at 20V (0.075A draw on Ammeter, slowly drops from 0.136A)...
                                          05-01-2025, 09:20 PM
