Intel D865PESO
  • Big Pope
    Approved Vendor
    • Dec 2005
    • 426
    Intel D865PESO
    I heard some users' Intel mobo crap with Nichicon 820uF 6.3v, and don't know how to got replacement. I got a Intel D865PESO last week, and some of Fujitsu polymers(yellow caps) on CPU VRM(output).
    My SAMXON Capacitors Database HERE!!
    X-CON is a new brand for SAMXON's Polymer Capacitors.
  • Big Pope
    Approved Vendor
    • Dec 2005
    • 426
    Re: Intel D865PESO
    Now, recapped with Samxon GC 1500uF 6.3 D8mm at all, rock stable.
    Of course also can recap with others brand Ultra Low ESR caps, such as Rubycon MBZ/MCZ and UCC KZG/KZJ etc..
    • linuxguru
      • Apr 2005
      • 1564
      Re: Intel D865PESO
      I've seen a stock board that has Rubycon MCZ at the VRM output and Nichicon HD for a few larger caps, including VRM inputs. The caps must have been upgraded mid-production.
      • jabadoo
        • Nov 2006
        • 4
        Re: Intel D865PESO
        on a related subject, i have a D875PBZ with some 6.3v 820uf which have gone poof.. is it ok to replace them with 1500uf like the OP?
        • linuxguru
          • Apr 2005
          • 1564
          Re: Intel D865PESO
          Yes, but there are only a limited number of series that offer 1500/6.3 in 8 mm - including Samxon, Panasonic FK/MCZ, and Chemi-con KZG. You may have better luck with 1200/6.3, where Chemi-con LXZ is widely available, but does not have as low an ESR as the MCZ or KZG.
          • Rainbow
            • Aug 2005
            • 1373
            Re: Intel D865PESO
            There are also 8mm Sanyo 1500uF/6.3V (seen them on some boards) and also OST (but you don't want them) and even GSC (seen them in trashcan after recapping )
            • jabadoo
              • Nov 2006
              • 4
              Re: Intel D865PESO
              Great, thanks for the advice guys I've never come across a motherboard with odd caps like this.. (Abit SA6R victim twice, Gigabyte 8IEXP.. but they were easy!)
              • Paul S
                • Sep 2006
                • 326
                Re: Intel D865PESO
                Oh No! I thought that the D875PBZ was a board with good caps. I have three of them. I bought them to replace my VIA P4PB boards that have bad caps.
                Paul
                • jabadoo
                  • Nov 2006
                  • 4
                  Re: Intel D865PESO
                  i'd venture out to say that intel had some in the beginning that used these dodgy capacitors.
                  I'm not sure what revision the board is.. i know it was first built into a system halfway through 2003.
                  • Paul S
                    • Sep 2006
                    • 326
                    Re: Intel D865PESO
                    I have one Intel D875PBZ that's been on since I built it, maybe 1 1/2 years ago. The caps look good on that one, and the other, that has been running for less than a year looks good too.
                    Paul
                    • jabadoo
                      • Nov 2006
                      • 4
                      Re: Intel D865PESO
                      should be golden then
                      • Spacedye69
                        • Nov 2005
                        • 698
                        • US
                        Re: Intel D865PESO
                        I have my sister in laws Dell here with a similar board, except the AGP slot and 2 dimm slots are gone(cheap bastards!). There are all polymers on o/p, sleeved Nichicon HD on vrm i/p, and from what I can see, the rest of the board is filled with a bunch of Nichicon VR/VZ! When did mobo mfrs start using non low esr caps on motherboards?
                        • Shroomie
                          • Apr 2006
                          • 356
                          Re: Intel D865PESO
                          My guess is around the same time they started taking the AGP slot off of AGP motherboards...
                          They cheap out however they can, as we've seen.
                          You know there's something wrong when you open up a PSU and are glad to find Teapos.
                          Why I don't buy cheap cases!
                          • Spacedye69
                            • Nov 2005
                            • 698
                            • US
                            Re: Intel D865PESO
                            Must have spent too much on those 4 extra polymers around the cpu!
                            • linuxguru
                              • Apr 2005
                              • 1564
                              Re: Intel D865PESO
                              Intel has been using Nichicon VR/VZ for the non-VRM bypass caps on their mobos for a long time now - perhaps since 2002/03. They could have used Rubycon YXGs instead at minimal extra cost, and achieved higher reliability.
                              • Big Pope
                                Approved Vendor
                                • Dec 2005
                                • 426
                                Re: Intel D865PESO
                                Because I don't trust reliability for these 5 Fujitsu polymers (yellow only), so i recapped at once.
