Magnavox 37MF321D/37 No Power, No LED. Testing a diode.
  • johnboy1313
    • Nov 2012
    • 1959
    I've gone through several threads regarding this model television. I replaced four capacitors (one of which was obviously bad) with no change in the problem. I pulled the diode referenced in the picture below. With my meter set on diode setting, I get ~160 (not sure of the units) on the meter regardless of which direction I test it. Does this indicate a bad diode?
    Re: Magnavox 37MF321D/37 No Power, No LED. Testing a diode.
    John, of all the people, you can upload a good picture right?
    I can't see where the diode is on that board... I doubt anyone else can.
    It might not even be a diode you removed?
    Almost always a diode conducting in both ways is bad, but it's quite rare for them to fail leaky like that, and not dead short (000 both ways.)
    • johnboy1313
      • Nov 2012
      • 1959
      I know, crappy picture. I ran home for lunch and forgot my camera/phone at work. I'll get good pictures when I get off in a couple hours. It is a diode, a zener diode. For now, it looks just like this. I'll look online for a good picture of that area of the board.
      • johnboy1313
        • Nov 2012
        • 1959
        Check this out.
        http://video.circuitlab.org/2012/06/...-715t2056.html
        • johnboy1313
          • Nov 2012
          • 1959
          I'm not sure how to determine which one I need.
          http://www.digikey.com/product-searc...-C9V1&x=4&y=23
            What is the TV chassis number, the board numbers so we can try looking for the service manual?
            • johnboy1313
              • Nov 2012
              • 1959
              Here's the link to the service manual. The diode is listed on page 128, down towards the bottom.
              I'll get pictures of my actual PSU and the PSU number when I get home.
                Seems like you may be on to something then. There's a schematic of that PSU here.
                http://www.tgohome.com/ServiceManual...&Search=Submit
                in case the zener/diode is different on your model. Page 110 onwards.
                Not all diodes that look like that are zeners, and Philips has an annoying habit of using four digit numbers instead of letter-number.
                • johnboy1313
                  • Nov 2012
                  • 1959
                  That schematic is for PSU 313815864961, my PSU is 313815868291, just slightly different.
                  313815864961 http://www.shopjimmy.com/philips-313...wer-supply.htm
                  313815868291 http://www.shopjimmy.com/philips-313...upply-unit.htm
                  If you look close, you can just see the ends of the diode when you mouse over the upper left corner of the picture on the 8291 PSU.
                    I look at the board layout (tom sch) on page 111 (313815868291 your board) and look at the picture at Shopjimmy, I do not see that diode you shown in post 1.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      For most multimeters, when it is set to diode mode, the unit is always volts. In this case, it is 160mV or 0.160V.
                      --- begin sig file ---
                      --- end sig file ---
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        Bud, if you zoom in on connector 1089 in the upper left corner of the pic, you can see the anode lead of the diode between the label for pin1 and the connector name 1089. The diode is not in the schematic because the schematic is for the other PSU available for this set.
                        Here's a pic of my PSU.
                          It certainly looks burnt under the board there.
                          • johnboy1313
                            • Nov 2012
                            • 1959
                            Yeah, the little blob of hardened burnt PCB right at the top of the 0 in 6079 caught my eye. It wasn't until I pulled the diode that I realized how burnt the board was.
                            • johnboy1313
                              • Nov 2012
                              • 1959
                              I swapped in a 1n914 diode from an electonics kit that i had from school per the first pic. It's working now.
                                You replaced a zener diode, which has a 9.1V breakdown voltage, with a 1N914, which has 75V breakdown voltage.
                                Obviously the circuit works fine, but you'll probably find that you've lost some over-voltage protection or regulation circuitry.
                                • johnboy1313
                                  • Nov 2012
                                  • 1959
                                  That's kinda what I figured. I haven't buttoned it up. From the link in post #5, which one looks to be correct? Specifically, out of the two that can be ordered one at a time. I might as well order all of the small caps and replace them while I have the thing opened.
                                    Is that a the 5V line that the Cathode of the Diode is connected to?
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      Honestly, without looking, I believe it's a 16V line. I know the diode is only rated at 9.1V, but I don't think this power supply has a 5V line and the anode is connected directly to both of the 16V pins on connector 1089.
                                        I think it's the 18V diode for the 16V line. The 16V line might rise if 24V becomes unloaded (inverter failure) or if the backlight is dimmed to a low level. The supply is group regulated on 5V(?) and 24V only.
                                        i.e. 9.1V is wrong.
