Vizio P42HDTV10A with LG internals shutting off after 15 seconds.
  • johnboy1313
    • Nov 2012
    • 1959
    I picked this set up yesterday because I have a ton of parts for these LG plasmas lying around. It showed the symptoms of a bad YSUS board. I brought it home, swapped in a good YSUS and buffer and turned it on. It showed a good screen with the typical sparklies, but then it shut itself off. One at a time, I unplugged the YSUS and the ZSUS with no improvement. After 15 seconds, it shuts off. I swapped in a different PSU, it still shuts off. At this point, I figured it was either the Sub-PSU, which I don't have an extra of, or something on the main board, which I also don't have an extra of. The sub-PSU showed correct voltages, even after the unit shuts off so I focused my attention to the main. I've traced it even deeper to either the tuner board (the small square board on the left in the pic showing the whole main) or the circuit on the main that powers the tuner board. With the tuner unplugged, the unit will power on and stay on but none of the controls work i.e power, menu, channel, etc. From the unplugged connector, left to right, I see...
    12V
    12V
    0.0V
    0.0V
    5V
    This makes me believe the main is functioning, but there is a short on the tuner somewhere. I've verified all surface mount voltage regulators are outputting the correct voltages per their label. There are two more larger regulators that show as follows...
    U1
    7805CT
    RRD605 G
    12V
    0V
    5V
    U2
    MSP1250
    ADJS
    52N03
    5V
    3.3V
    0V
    1.2V
    0V
    At this point, I'm leaning towards a bad tuner board, but I guess there is a possibility that the main board could have a problem when that circuit is under load.
    Any thoughts?
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Vizio P42HDTV10A with LG internals shutting off after 15 seconds.
    With just the 5V wire pulled from the plug to the tuner board, the tv will power up with no controls.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      checked the fuse on the tuner board?
      • johnboy1313
        • Nov 2012
        • 1959
        Yeah, I checked both fuses on the main board too. They all check good.
          Check the control board for an AUTO GEN option.
          • johnboy1313
            • Nov 2012
            • 1959
            The control board is the main board right?
              No, it is the equivalent of a T-con on this LG plasma.
              • johnboy1313
                • Nov 2012
                • 1959
                OK, I found it. It's a connector with four pins.
                • johnboy1313
                  • Nov 2012
                  • 1959
                  What should I do with it?
                    Can I see a picture of it?
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      Here you go.
                        Wire up the PSON and VSON so you get good Vs/Va.
                        Short pins 1-2 of the AUTO GEN.
                        Do test patterns appear?
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          It would appear that the panel works fine. I can connect a signal to the set and see a good picture. The only problem is that the power supply shuts off after 15 seconds when the tuner board is connected.
                          Do you think it's a bad panel causing the set to power off?
                            I doubt it, a panel cannot fail in such a way. If the picture is good (minimal to no maldischarge, no stuck rows/columns) then there should be no issue.
                            Perhaps the tuner board has an erroneous sleep timer set up?
                            • johnboy1313
                              • Nov 2012
                              • 1959
                              I ordered a tuner board. I'll update when it's installed.
                              • johnboy1313
                                • Nov 2012
                                • 1959
                                New tuner board installed, TV still shuts off. I've got one more ace up my sleeve. If that doesn't work, I'm going to strip it down and swap the panel into a 42" Akai that I've got in the basement. It uses the same PSU, Y-SUS, Z-SUS, buffers, and logic board, but a different main and no sub-PSU.
                                • johnboy1313
                                  • Nov 2012
                                  • 1959
                                  No dice. Something is up with the 5V circuit in the main board. I'm going to swap this panel into the other set when I have time and (hopefully) be done with it.
                                    I emplore you to avoid these LG based plasmas in future (42X2, 42X3, 42X4, 50X3, 50X4 etc.) They are utter nightmares.
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      Yeah, I'm done. I need to be smacked for continuing to pick them up. I'm trying to get rid of some parts that I've accumulated, but I keep adding more parts.
                                        Newer ones are almost as good as Panasonic picture quality wise and are fairly well built, but the IPM based ones are abysmal.
