Samsung LCD TV: no picture/sound, red light blinks, white light on, ignores on/off
  • lucasius
    • Dec 2012
    • 2
    My Samsung LCD TV (LN40A550-P3F-XZC) stopped working :-( I hope someone can help? Symptoms: the red standby light blinks all the time, and the white light at the bottom-center of the screen is on, but there is absolutely no image (not even in a pitch dark room) and also no sound. The voltage on the STB 5.3 pin measures 5.1V and the voltage on the PWR On/Off pin measures 4.33V. The strange thing is that I can't turn the TV off either: as soon as I just merely connect the power cord, the situation will become as described above: white light at the bottom-center of the screen is on, red standby light blinks -- can't turn it off, not with the remote control nor with the on-off button on the right side of the TV: white light at the bottom-center of the screen stays on, red standby light keeps blinking. The only way to turn off the TV is by disconnecting the power cord. However, interestingly, when I keep the TV unplugged for a few weeks and then plug it back in after all that time, then the TV may work as normal for a couple of minutes, showing a perfectly fine image from a local TV channel when I turn on the TV via remote control or on/off button, but then suddenly the image freezes (showing at much lower resolution and also colors off, sometimes accompanied by a loud buzz coming from the speakers) and then the next thing is screen goes black, no sound. FYI: I'm using a properly grounded power outlet (no surge protector in between). I'm trying to figure out which board in the TV might need replacement (I can check Ebay if they sell the board) -- I suspect it must be either the *PSU board* or the *main logic/video board*. Just want to avoid buying one of these two boards and then the next thing is it turns out that the board it replaces wasn't the one with the defect after all. Thanks in advance for any help/hints from anyone! B.t.w., although the caps on the PSU board are all looking good (no bulging/leaking), I replaced them (Rubycons from DigiKey) -- but it didn’t fix the problem. Maybe another component on the PSU board could be faulty (maybe a voltage regulator)? Or would the main board be the more likely suspect now?
  • DakotaKid
    • Nov 2010
    • 165
    Re: Samsung LCD TV: no picture/sound, red light blinks, white light on, ignores on/of
    **thanks**
    • lucasius
      • Dec 2012
      • 2
      I did some voltage measurements on the pins and found:
      * pin Power On/Of pin = 4.2V -- interpretation: power board powered on, also explains white light at the bottom-center of the screen is on; merely connecting main power cable gets TV in this state, can't power off (to get pin voltage near 0) using power button, power off commands seem to simply be ignored
      * pin Inverter On/Off = 0.03V -- interpretation: main board not sending inverter-on signal to power board, hence no backlight seen; backlight comes on when I manually apply 4V to this pin
      * pin Sync (pin 2) = fluctuating voltage -- changing in time anywhere between 0.3V and 4.3V, values seem random, not sure what to think of this, anyone has any suggestions?
      * All other pins showing expected voltage values
      Starting to think that my main board may be fried? Or maybe the EEPROM reset/replacement trick could work to fix the problem? Anyone has any thoughts?
      • ron77
        • Dec 2012
        • 63
        • united kingdom
        From the voltage readings you have taken, and the way your tv is performing, I would suspect the main board. I am only going on my own experience,after working on a number of Samsung tv's over the last six years. However, I can only remember one model of samsung tv that had a chronic problem with the main board. That was the Le40r88bd. This was caused by two capacitors, sometimes more, swelling on psu. Poor standby voltage caused main eprom to fail. In fact it got very hot.This tv had relays that kept clicking, I suspect your tv has no relays. Anyway models before this one, and after, caps going, main board survived. No invertor on voltage on any of those faulty boards.Bar capacitors failing had few problems with Samsung lcd psu's. Repaired a celcus tv last week, a vestel tv.Had voltage readings identical to yours, was main board faulty. If it is the main board playing up, I change them, pulled ones are inexpensive.
        Ron77
        • whatusername
          • Dec 2013
          • 456
          Hey guys i just got the same tv same issue blinking red light..If i left the tv alone for a long time it would attempt to turn on. you can hear the samsung chime then see backlight and when you look at the screen its flashing like low on power then shut off.. i found 1 bad cap on power board replaced it and still same thing blinking led.. but this time after a while it attempted to start again i heard half chime and then a annoying squeal coming from the speakers.. i did check all voltages on power board and everything is correct... the optical out on main board is not lit up but then when it goes to power on it lights up thats how i know its gonna attempt to start from behind.. i would like to fix this board if possible so where should i start?
          • whatusername
            • Dec 2013
            • 456
            bump
            • whatusername
              • Dec 2013
              • 456
              no one wants to help take on this challenge? i hear it could be the Ic but im not sure
                @whatusername, what is the power supply board P/N? BN44-?????
                • whatusername
                  • Dec 2013
                  • 456
                  get you that info right now bud
                    One of these?
                    http://www.shopjimmy.com/catalogsear...lt/?q=LN40A550
                    • whatusername
                      • Dec 2013
                      • 456
                      bn44-00197A
                        OK, here is the SCH.
                        So all the voltages (stb5.3V, 5.3V, 13V and the signals (Power_on/off, Inverter_on/off are >2.5VDC). If that is the case, then the problem will be in the main board. I never have luck fixing the Samsuung main board myself.
                        • whatusername
                          • Dec 2013
                          • 456
                          power on 4.32 stb 5.12 13's are 13.00v
                          • whatusername
                            • Dec 2013
                            • 456
                            inv on off 0.03
                              OK, what you can do then is to disconnect the INV ON/OFF wire going back to the main board first and then use 100~1K resistor between INV ON/OFF and the STB5V to force on the backlights, we have to disconnect that wire because we do not want the main board to keep forcing the inv on/off LO and not allow it to go HIGH when we try to force the line HIGH. When the bcaklights are on, if everything else is OK on the main board then you should see the pictures, and hear the sound and all the function should work.
                              • whatusername
                                • Dec 2013
                                • 456
                                cn803: connected to main
                                det 5v= 5.11
                                gnd=0
                                pwr dim= 4.76
                                nc= 2.46
                                inv pwr on/off = 0.03
                                if removed from main nc=0
                                • whatusername
                                  • Dec 2013
                                  • 456
                                  i dont have a 100 -1k resistor i dont have any resistors.. i do have a light bulb.. i remember we used it once just cannot remember how
                                    You can do without the resistor, the reason we use the resistor is just in case you slip and touch something else, the resistor will limit the current.
                                    • whatusername
                                      • Dec 2013
                                      • 456
                                      ok jumped it and bl came on front led still blinking red not responding to button presses
                                      • whatusername
                                        • Dec 2013
                                        • 456
                                        wait u said use 5v stb? i used det 5v does that make a difference?
                                        • Elecfronicsssss
                                          DA0NJJMBAG0 charging light blinks
                                          by Elecfronicsssss
                                          Laptop motherboard DA0NJJMBAG0
                                          PROBLEM-WHEN I PLUG THE CHARGER WITHOUT BATTERY THE CHARGING LIGHT BLINKS AND WHEN I PRESS POWER BUTTON THE CHARGING LIGHT STOPS BLINKING AND STAYS ON BUT THE POWER LIGHT DOESNT TURN ON AND LAPTOP ALSO DOESNT TURN ON NO FAN SPINS NO KEYBOARD LIGHT.
                                          CHECKED- ON S5 STATE TGE LAPTOP HAS 5V ON USB 3.3V BUT I DIDNT GET 1.8VOLTS ON BIOS PIN NO 8 WHILE PLUGGED IN AND EVEN ON S5 STATE.
                                          GUIDE ME WITH THE PROBLEM..
                                          SUMMARY-
                                          1.NO 1.8VOLTS ON BIOS PIN NO 8.
                                          2.S5 STATE ((PRESSING POWER BUTTON)))VOLTAGES ARE PRESENT...
                                          05-12-2025, 02:32 AM
                                        • ongobongo
                                          Dell Latitude 7420 - Status LED blinks white once
                                          by ongobongo
                                          Hi Guys
                                          I have a Dell Latitude 7420 here which doesn't want to boot.
                                          If i plug in a charger, the status LED blinks white once only, nothing more, no amber blinks.
                                          I'm trying to start it without battery as the old one inflated and had to come out.
                                          I've tried all kinds of startmethod, holding D, holding CRTL+ESC, holding M+power, nothing works. I've even checked voltage/current consumption: charger changes to 20V and 0,07A but despite the one white blink, nothing else happens.
                                          Does someone have an idea what i should look at / check?
                                          ongobongo
                                          03-23-2024, 10:49 AM
                                          RAB Lighting 30 and 48 White LED 9-12VDC Blinding Light Bars—> Very nice light bar
                                          by sam_sam_sam
                                          I bought these LED light bars from Electronic Goldmine surplus store online
                                          These light bars are the nicest LED light bars I have ever seen in there online store
                                          I read the description of these light bars and said yeah right there bright at 9 volts
                                          Let just see if this is the case or not and just how bright is bright because I bought some of there light bars that they said were very bright and were ok but I would not say they were as bright as they claim
                                          But I thought I would give these a try only because they had both light bars on sale as a bundle...
                                          02-11-2021, 10:03 AM
                                        • ruletero
                                          HP Omen only do not turn on, only flashes white light
                                          by ruletero
                                          Hi everyone
                                          Please help me with this laptop
                                          HP Omen 15-dc0003la , MB DAG3DBMB8D0 REV. D
                                          It doesn't turn on, when I connect the charger with battery orange light appears on power jack and without battery white light appear, it is fine I think
                                          But if I press power button, power led flashes white once, only that, not consumes anything power, not start, nothing more.
                                          Bios was programmed with a working version, no changes.
                                          Voltages
                                          +3vS5 = 3v when I connect charger, next goes to 0 (I think is fine)...
                                          06-07-2023, 10:11 AM
                                        • stevenallauca
                                          HP laptop does not charge the battery, the light turns amber and then changes to white.
                                          by stevenallauca
                                          Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
                                          - ACN (BQACN) 19.6v
                                          - ACP (BQACP) 19.6v
                                          - CMSRC (BQCMSRC) 19.6v
                                          - ACDRV...
                                          09-23-2024, 11:30 AM
