cant find the name of the caps on my pc
  • k-9
    • Feb 2013
    • 4
    • US
    ok to start with my pc is a hp pavilion a350n the motherboard is a MB manufacturer: ASUS P4SD-LA
    HP name: Yale-UL6E
    i can see some of the spec the 7 that are bad right by the cpu they are 6.3v @1800uF the writing on them are wcz or wc2 and to334. can any one help me find the right cap
    thanks robert
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3266
    • Singapore
    Re: cant find the name of the caps on my pc
    lol top view pic is not really helpful at all. cant make out anything when the writing is supposed to be on the side... how bout side view pic on either side?
    tho i hope they arent rubycon mcz as these are top grade caps.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Unfortunately they went through a period when the were not!
      That is what they will be see
      https://www.badcaps.net/forum/showth...mcz#post304144
      Do search on D530 or MCZ and there are a few threads about it.
      This may also help
      https://www.badcaps.net/forum/showth...D-LA#post81545
      • k-9
        • Feb 2013
        • 4
        • US
        ok pulled the pc down and yes they are rubycon caps is it ok to use a different brand cap with the same spec and if so what have you guys found as a good replacement cap . and what i have read these are good caps if so what else should i look at that might have caused this the psu ?
        thanks
        • brispuss
          • Dec 2012
          • 54
          • NZ
          A suitable replacement for the Rubycon 1800uF 6.3V MCZ series capacitor would be a Nichicon 1800uF 6.3V HZ series capacitor here.
          • ChaosLegionnaire
            HC Overclocker
            • Jul 2012
            • 3266
            • Singapore
            usually when caps vent or bloat they are due to overheating. most likely they overheated since they are right next to the cpu heatsink.
            my suggestion is to get a better cpu cooler if u are using a pentium 4 3ghz or faster. a top down blower cpu cooler usually is the best for keeping the surrounding components cool.
            the scythe zipang is one example of a very quiet top down blower tho it is too big to fit in a mini tower micro atx case. maybe try big shuriken or shuriken b instead tho i think they may not be powerful enuff to cool a hot 3ghz+ pentium 4.
            • k-9
              • Feb 2013
              • 4
              • US
              thanks for your guys help got the nichicons orded and as far as the cpu cooler im looking in to one the my hp has a Pentium 4 / 2.80 GHz so im looking for a replacement for better cooling
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                Should have went with all-polymer replacements. These boards work great with them. See this thread for more details if you want:
                https://www.badcaps.net/forum/showthread.php?t=23503
                • SluggerB
                  Can't find exact matching caps for replacements, what should I get to prevent video issues?
                  by SluggerB
                  I have an old Tivo. The Power Supplies are known to have caps that fail. Here are the caps that come with the original power supply:
                  I could not find replacement caps with the exact same specs. I followed an online guide and recapped the power supply with caps with these specs
                  The power supply now works, however the HDMI video is giving me eye strain. I don't know how a capacitor on a Power supply could impact an HDMI video signal, but it does, the Tivo interface has a flicker now and the color/brightness is off. So I want to get some new caps...
                  04-05-2024, 07:47 PM
                  Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
                  by momaka
                  I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
                  For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
                  https://www.badcaps.net/filedata/fetch?id=3591771
                  https://www.badcaps.net/filedata/fetch?id=3591772
                  It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
                  https://www.badcaps.net/filedata/fetch?id=359177...
                  03-12-2025, 03:42 PM
                • CdDvdFlash
                  Please teach me how to find datasheets to obsolete caps
                  by CdDvdFlash
                  I've got a Toei arcade CRT chassis and printed on the PCB is CM-R14 but it might be a CM-R20 and so far needs two caps replaced, I've looked on the Nippon Chemi-Con site and got their 2020 catalogue I cant find any info about the first cap in the catalogue or on their obsolete catalogue, on the cap is:
                  (Radial electrolytic cap) Nippon Chemi-Con 1uF 160v 85c 8mm diameter, roughly 15mm long (cap is bulging at the legs) with 6mm PCB hole spacing, the chassis service manual says this cap C58 is a CE04W with "04" in a smaller font than the capital "CEW" so it must be...
                  08-12-2023, 12:29 PM
                • Paxman_Swede
                  Identifying caps on an old Zoom 9000
                  by Paxman_Swede
                  Hello!
                  I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
                  The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
                  I have studied the board and...
                  01-14-2025, 09:51 AM
                  by momaka
                  03-15-2023, 10:17 PM
