Hi everyone,
I have searched the forum but couldn't find a thread with my exact model and problem. Please forgive my language errors.
Without any other worrying sign, after 5 years of impeccable service, my TV stopped showing picture.
The pattern is this: TV being in standby (red light), after turning it on by the remote or the panel buttons, the light flashes 3 times, and turns white-green (as normal). The panel shows fine for 3 to 4 seconds and then blacks-out. Nevertheless, sound goes on. If I put it in standby, I can replay the previous pattern as many times.
At the LG service center they asked for 180 euros to change every board in the set. As this is too much for me right now, I thought I should try to fix it by myself.
After some research before posting, I found the service manual I attach and two posts of this model serie in a french and a german forum. Through google translate, I suppose they cope with faults irrelevant to mine.
I have read this thread, did the hairdryer trick to no avail.
This thread model seem to use the same PSU but differs on main board and kind of problem.
So I read "A guide on how to troubleshoot 2 seconds to black", remarkable work, but I could make use of a "road map" to checking all these parts referred.
I started with capacitors.
Opening up my TV set, in the quest for bulged caps, I didn't find any. As seen on the first photo, here are 3 boards: the main logic, the power supply and the inverter. The PSU board (photos 2-7) uses SAMXON caps which, as I understand from this forum, are of poor quality, but I miss an ESR meter to test them.
With my DMM, I checked the voltages on the both connectors to the inverter.
(Tv set is on, connectors unplugged, black probe on a Gnd pin)
connector socket P205
24V -> 24,93
I-C -> 4,94
BRI -> 3,31
connector socket P204
ERR -> 0
DIM -> 0
I-C -> 4,94
BRI -> 3,31
Does this prove PSU board to be OK, so that I can move on to the inverter?
Or should I recheck with connectors plugged-in?
I'd appreciate your help.
24V -> 24,93
I-C -> 4,94
BRI -> 3,31
ERR -> 0
DIM -> 0
I-C -> 4,94
BRI -> 3,31
