Register FAQ Calendar Today's Posts Search
Old 10-26-2012, 04:10 PM   #1
storexxm
City & State: 1180
My Country: Vienna
Default W241D (W240D) flickering Problem
I got the same problem like in this video
http://www.youtube.com/watch?v=YN12vGegYmY
Its the gm5868H-LF processor on the motherboard, which runs hot.
I already renewed all caps on the PSU.
[IMG]http://img189.**************/img189/3639/271020121065.jpg[/IMG]
Uploaded with **************
[IMG]http://img706.**************/img706/6058/271020121066.jpg[/IMG]
Seems a lot got the same problem, but i don´t think its a solution to install a fan, cuz i think the problem is getting worse-
Maybe someone know that issue and can help me here.
Greetings from Austria.
storexxm is offline   Reply With Quote
Old 10-26-2012, 04:55 PM   #2
nnname
City & State: Germany
Default Re: W241D (W240D) flickering Problem
It's interesting to see that Hyundai changed the imaging processor in the latest revision which I own (EV3.84, see photo).
Are you really sure that the above mentioned processor runs hot? I would rather expect one of the power transistors to run too hot.
Maybe a few heat sinks would solve the problem.
By the way, which capacitors did you use to replace the old "JH" (Jianghai) capacitors?
nnname is offline   Reply With Quote
Old 10-26-2012, 05:26 PM   #3
storexxm
City & State: 1180
My Country: Vienna
instead of the JH i actually use YAGEO.
yep i am sure it is the imaging processor.
i seperated the PSU from the MoBo and blow against the IP.
actually i put a heatsink on the chip which also "solved" the problem.
of course the power transistor gets hot, but the image processor too
did u also got problems with your hyundai screen?
till now i don´t know whats the difference between the 241D and the 240W?
Old 10-26-2012, 07:32 PM   #4
nnname
Fortunately, my Hyundai still works fine, even after three and a half years daily use .
The only flaw is the "vertical color lines" error which occurs very rarely when switching on the monitor. It seems to be quite normal for this monitor.
The difference between the W240D and the W241D is the TFT panel. Whereas the first mentioned only uses a more ore less bad TN panel, the W241D has a very good S-PVA panel by Samsung.
(Bezüglich deines Eintrags in meinem Profil: Ich würde im Sinne einer besseren internationalen Verständlichkeit gerne weiterhin auf Englisch schreiben. Den Hyundai werden schließlich nicht nur deutschsprachige Nutzer besitzen. )
Old 10-26-2012, 08:30 PM   #5
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
Looking at the video board, it looks like the two regulator ICs (they have 3 legs with big tab on one side) have been running hot, you can see the board in that area has brownish color. You should check the value & ESR of those 3 caps to the left and two caps to the right of those two regulators.
Also take the reading of each pin of the regulator, black probe on the chassis and red probe on each pin and report the readings. If the caps do not filter out the AC ripple properly and let it running through the circuits, it can cause over heating problem.
Old 10-27-2012, 03:26 AM   #6
storexxm
City & State: 1180
My Country: Vienna
how do i know what panel i got inside of the screen?
(there is only one sticker at the back of the monitor which says W241D)
every other part is described with the W240D.
@budm: thanks, but as u can see the video board from nname got the same brownish color near the regulator IC´s... but i´ll check that.
@nname: did u changed the caps on your video board? as i wrote in the first post i already changed the caps on the psu, but i guess i should do the same with the 6 caps on the video board. (i just saw that one domed at the bottom... could that be the problem!?)
[IMG]http://img41.**************/img41/2984/271020121067.jpg[/IMG]
Old 10-27-2012, 07:51 AM   #7
nnname
@ storexxm:
If the sticker on the back of the casing says "W241D", you have the W241D . Some PCB stickers and even the OSD nevertheless say "W240D" because they were also used in the TN panel model. Hyundai just did not change this details.
All caps in my monitor are still original.
Old 10-28-2012, 02:38 PM   #8
storexxm
City & State: 1180
My Country: Vienna
nobody got an idea what the problem could be that the processor runs hot !?
the only cap i didn´t change is the big one on the PSU.. or could it be a transformator..?
please help
Old 10-28-2012, 02:44 PM   #9
Th3_uN1Qu3
Believe in
City & State: Bucharest
My Country: Romania
Line Voltage: 230VAC 50Hz
In your pic of the logic ("video") board, the G-Luxon capacitor with the bung pushed out is likely bad. Replace that and see what happens.
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Old 10-28-2012, 03:02 PM   #10
storexxm
City & State: 1180
My Country: Vienna
already changed them with caps with more capacity and volt...
problem is the same...
could it be a other component part ?
just curious but could it be the t-con board that the lcd processor run´s hot?
its such a common problem but i am puzzled there is no solution.
and i think it´s not a real fix to put a heatsink on the chip ...
i am not sure but i think the flickering is getting lower when i turn the brightness and contrast down...
could it be the big cap on the PSU (i never saw a instruction to change it just on purpose)
Old 10-28-2012, 04:28 PM   #11
nnname
If the big capacitor was faulty, the whole monitor wouldn't work — it should be all right.
So if you already replaced all G-Luxon caps on the video board, maybe the ESR of the new caps is still too high for the circuit?
Please compare the data sheet of the original capacitors with that of your replacements.
Old 10-29-2012, 07:27 AM   #12
storexxm
City & State: 1180
My Country: Vienna
instead of the (maybe dead) cap i used a 35V 470µ from the PSU (which was not domed)
is it also very important to use low ESR caps for the PSU (i just bought them @ conrad... guess u know that shop )
could it be a problem when i use higher voltage and higher capacity instead of the old caps?
i read this -> http://www.badcaps.net/forum/showthread.php?t=1458 -> but my technical know how and english is too bad that i get the information about the ESR in the given data sheet ;(
Old 10-29-2012, 09:20 AM   #13
nnname
The capacity of the replacement caps should be as high as of the originals. A higher or lower value can affect functionality negatively. A higher proof voltage is okay (and even better).
So you should try to use more suitable replacement caps. Because I didn't find any data sheets for Yageo caps (which I only found at Conrad ), I cannot tell you if they are suitable for high ripple currents that are common at PSU circuits. They even can go bad after a few days/weeks.
You can find really good explanations of "low ESR" and much more in German at the Elko-Verkauf website.
Old 10-29-2012, 10:24 AM   #14
storexxm
City & State: 1180
My Country: Vienna
i found this pdf... think there are the specs. of the caps.
http://www.yageo.com/exep/pages/down...p_20120524.pdf
but as i understand it correctly, the ESR is only important for the lifetime...
but the monitor doest work correctly at all... it might not be a long term solution if i take any kind of cap, but it should work anyway...
is my idea correct ?
because its the SAME issue, no matter which caps i use
what do u think about budm`s idea ? shall i change the silver small caps too....?
stupid overheating problem ---
Old 11-13-2012, 02:36 AM   #15
storexxm
City & State: 1180
My Country: Vienna
now i tried it with a passiv cooling system... seems like the problem can´t get fixed-
Old 11-13-2012, 04:09 AM   #16
selldoor
Slow Learner
selldoor's Avatar
City & State: Lancashire UK
I dont think said which series of Yageo caps you bought as replacements so we cant check them on the datasheet.
You never posted the results of the test Budm suggested on the Voltage regulators.
If the caps are not good enough the voltage at the regulators may be incorrect causing them to overheat.
If the voltage at the regulators is incorrect the voltage supplied to the main processor may be incorrect causing it to overheat.
selldoor is offline   Reply With Quote
Old 11-13-2012, 04:14 AM   #17
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
Line Voltage: 230Vac 50Hz
I doubt Hyundai changed imaging processors; that would require a new board. More than likely ST acquired Genesis or something...
Here is a news release: http://investors.st.com/phoenix.zhtm...000&highlight=
Free service manuals: http://www.toms-service-manuals.com/ -- 72 LED/LCD TVs, 5 monitors, 28 plasma TVs, and 2 AVR 6.1 amplifiers fixed! -- I repair Pioneer 9G Plasma Main Boards & KRP-M01 Media Receivers (PM me for info)
2 Pioneer KURO 9G, 12 Panasonic LCD/Plasma, 1 Sony LCD, 1 NEC Plasma, 2 Yamaha HTS, 5 Sharp LCDs, 5 Toshiba LCDs, 7 Philips Plasma/LCD, 1 Hitachi Plasma, 11 LG LCD/Plasma, 18 Samsung LED/LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Grundig LCD, 1 Dell LCD, 1 iiyama LCD, 1 Acer LED, 1 Logik LCD, 1 Baird (China) LCD, 6 Bush LCDs, 22 Vestel LCDs (Best->Worst)
Old 11-14-2012, 04:03 PM   #18
storexxm
City & State: 1180
My Country: Vienna
u mean the capacitors on the power or the video board ?
i can´t believe that the old "broken" caps can produce the same error like the new ones !?
the caps have more µF and more voltage.. so there should be no problem...
greetz-
Old 01-28-2013, 06:23 AM   #19
manray
City & State: Paris
My Country: France
Hello, i had a problem with my W240D V2, problem shown here:
http://www.youtube.com/watch?v=8gdDYlKLzVQ
i changed the LDO (shown on this image):
http://www.hostingpicture.fr/upload/...99ba2ed30a.jpg
http://www.hostingpicture.fr/upload/...ad2f55f55c.jpg
My W240D V2 works fine for 1 month now.
Hope i help you in any way.
PS: excuse me for my english.
manray is offline   Reply With Quote
Old 01-30-2013, 04:59 AM   #20
manray
City & State: Paris
My Country: France
I think i made a mistake, the components that i replaced are voltage regulators not LDO. Right?
Badcaps.net Technical Forums © 2003 - 2023
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
