HANNSG HG281D problem with pix and backlights
    Just fixed this model, the symptom is, at low resolution, the backlights will be on but I can noise and horizontal noise bar, when I set the resolution to its native resolution, it will act like 2-second to black, the blue power light will stay on.
    The cause of the problem was due to two bad DC filter caps (100uF 16V) for the 3.3V and the 1.8V LDO on the logic board.
    See pictures.
    One cap show 80uF with 3 Ohms ESR, another one read 100uF with 3 Ohms ESR.
  • tibimakai
    • Jan 2012
    • 3680
    Re: HANNSG HG281D problem with pix and backlights
    Great job.
      By the way, at first I thought the 3.3 and the 1.8 regulator were bad because the out put were more than 3% less than it should be, so I use the scope to see how bad AC ripples were, and they were high, around 150mV, so I just parallel the caps with another caps, then the output voltages went back to where they should be, 1.8 & 3.3V.
      So sometime you do need to use the scope or just parallel the filter caps with good know caps to see if it solves the problem, parallel is so much easier for DIY, I use the scope to find out what is going on.
        master hoarder
        • May 2008
        • 12168
        • Bulgaria
        Or if you don't have the expensive equipment or knowledge to use it, when you see electrolytic caps (especially ones from a crappy or not well-known brand) next to hot linear regulators, always try replacing those/adding new ones in parallel before suspecting the regulator.
        Congrats on the fix by the way .
        • Duncanbest
          • Jul 2012
          • 81
          • Taiwan
          Parallel the filter caps ---->Good debug technique ,thanks for sharing
          • abeeftec
            • Mar 2014
            • 43
            I cant make a new thread so I figured I would post my listing description and see if someone can tell me what Capacitors I need and point me in a direction where there is a tutorial on how to do this....Thanks....
            MY LISTING ON EBAY SAYS......
            "YES It does turn on and Works however....
            Turns on and runs perfectly beautiful without flaw for about 45 Minutes or sometimes longer
            Then it may or may not get NOISE(small vibrating dots) in the picture. Light Blues seem to be what it has the most issues with after it heats up for approx. 45 min's and that depends on differing factors.
            Occasionally it doesn't have any issues at all. Just last night my brother used it to game with and it worked perfectly for 5 hours of gaming and never had an issue the entire night.
            There are also times when the monitor takes a while to turn on after you hit the power button(3 seconds and sometimes up to 30 seconds) and sometimes you have to pull the HDMI cord and plug it back in to get it to come back on faster. Sometimes
            When you hit the power button you have to hit it a few times to get it to come on and this is why I believe it is a Power Supply problem that is causes all the issues.
            But I could be mistaken as I don't know everything about LCD's.
            Once it heats up it gets these dots all over the place shimmering. It is easier to see with Light blues. They are random it seems and follow cloud images and other images on the screen. But not totally. the shimmering light dots follow the images more so than everywhere else but they are still in other places.. THis is hard to describe of course.
            Also, it throws a code too(cant remember what the code is)
            But the Brightness control doesn't work correctly either.
            It has a bunch of issues. I am thinking maybe it is many caps that have gone bad.
            Can someone help me fix all the bad caps and point me in a direction to purchase good caps for this monitor please?
              master hoarder
              • May 2008
              • 12168
              • Bulgaria
              We have a big thread that probably lists every problem (from various people) that this monitor has had. It can be found here:
              https://www.badcaps.net/forum/showth...ghlight=HG281D
              Yes, I know it IS very long, but definitely worth reading (at least the first several pages).
              Judging from your issues, you plobably need to replace the caps on the logic board. Post pictures (either here or on the other thread) and you should find plenty of help.
              • abeeftec
                • Mar 2014
                • 43
                I will post pictures here.
                I posted another post before I saw this response.
                I noticed it seemed this was an old thread so I thought no one saw it.
                I took the thing apart and see no bad caps. SO now I am going to take some high res pics of the boards so someone else can see these caps. I could be wrong of course.
                • Chrissygizmo
                  samsung ue49ku6670xu boot problem after changing backlights
                  by Chrissygizmo
                  I've got a ue49ku6670xu main board BN94-11055E, the backlights were burned so replaced them , after doing so the new lights just flickered on and do a boot loop , I haven't got the screen back on yet as I was just trying out the lights before doing so, ive just tried another main board )totally different just tried it as the plugs fitted , just to Try checking the backlights, the board works the lights properly so I'm guessing it's my main board as I've tried a different power supply of the same model , I read in this thread something about jumper between FB_TRDV1 & FB_TRDV3 , could someone...
                  05-26-2024, 04:59 PM
                • theone111
                  by theone111
                  3. Problem: TV shuts down
                  07-22-2024, 10:36 AM
                • Zeonalbasta
                  Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                  by Zeonalbasta
                  i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                  The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                  09-13-2024, 01:17 PM
                • Gibon378
                  Problem with stopping audio and video for no reason
                  by Gibon378
                  PC Specs:
                  • CPU: Ryzen 5 1600
                  • GPU: GTX 1080 Palit JetStream
                  • MOBO: ASRock ab350 PRO4
                  • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                  • PSU: XFX 650W (don't remember what model)
                  • OS SSD: ADATA SP920
                  • OS: Windows 10 21H2
                  Problem description:
                  Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                  11-19-2022, 09:41 AM
                • perzyk23
                  Lenovo T580 - LCD Panel problem - error 0288
                  by perzyk23
                  Good morning,
                  I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                  10-25-2024, 12:42 AM
