#1 |
City & State: Ridgebury, PA
Samsung Syncmaster 2233RZ
Tried replacing capacitors with new ones. Screen still shuts off after 2 seconds. Can see the screen still with flash light. Removed the transformer and tested the secondaries. 1st pair: 854 2nd pair: 902 So they are just barely within 3%. Anything more definitive I can test for or just order a new one? I have pics just can't post them from this iPod. Dan |
#2 |
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
Try test lamp, such as this: http://www.badcaps.net/forum/showthread.php?t=19987
or T5 4WATTS lamps. or inspect the lamps and wiring. http://s807.photobucket.com/albums/y...klight%20lamp/
Never stop learning Basic LCD TV and Monitor troubleshooting guides. http://www.badcaps.net/forum/showthr...956#post305956 Voltage Regulator (LDO) testing: http://www.badcaps.net/forum/showthr...999#post300999 Inverter testing using old CFL: http://www.badcaps.net/forum/showthr...er+testing+cfl Tear down pictures : Hit the ">" Show Albums and stories" on the left side http://s807.photobucket.com/user/budm/library/ TV Factory reset codes listing: http://www.badcaps.net/forum/showthread.php?t=24809 Last edited by budm; 07-15-2012 at 06:15 PM.. |
#3 |
City & State: Buenos Aires
My Country: Argentina
Line Voltage: 220VAC 50Hz
What about mosfets and transistors? Are they working?
#4 | |
City & State: Canada
2) I always do the math this way. If 854 is the "correct" reading, then 854 x 0.97 = 828.38 854 x 1.03 = 879.62 So if the second transformer falls in between the two above numbers, then it is good. 3) Before buying a new transformer, do the ccfl test and examination as suggested by budm. If your transformer readings were 854 and 1500, then it is more obvious what is wrong.
--- begin sig file --- If you are new to this forum, we can help a lot more if you please post clear focused pictures (max resolution 2000x2000 and 2MB) of your boards using the manage attachments button so they are hosted here. Information and picture clarity compositions should look like this post. We respectfully ask that you make some time and effort to read some of the guides available for basic troubleshooting. After you have read through them, then ask clarification questions or report your findings. Please do not post inline and offsite as they slow down the loading of pages. --- end sig file --- |
#5 |
BTW, this person had a 2 seconds to black problem (same monitor), but his transformer readings were more obvious.
http://www.badcaps.net/forum/showthr...hlight=tm-0915 |
#6 |
I don't have access to spare pink or blue connectors for the ccfl test. The connector is pretty tiny to get anything in there to make the connection with anything else. What type of connection could I use in place of the pink/blue connectors?
#7 |
You can solder the wires directly to the connectors on the board, you can see the two pins per lamp on the soldered side of the board.
#8 |
What gauge wire do you recommend to solder to the connector?
#9 |
24AWG should be fine, or even 26AWG.
#10 | |
Anything else to test before ordering the transformer? |
#11 |
My checklist (regulars may skip the URL below)
More details starting with post #19 at http://www.badcaps.net/forum/showthread.php?t=10419 |
#12 |
Slow Learner
City & State: Lancashire UK
#13 |
My bad. 4 lamps. The 2 connectors on the side where the push button connector is are the ones that turn on 2 seconds. The other 2 connectors are not lighting the test lamp at all.
#14 |
So is this a single transformer setup or two transfromers, one per two lamps? If it is two lamp setup, then I would swap the working one with the one that does not light up the lamp, if the problem follows, then you have bad transformer, if the same two lamps still do not light with the know good transformer, then more components in that section will have to be investigated.
#15 | |
#16 |
If it is single transformer, then that will eliminate the transformer driving circuits problem since the primary winding is driven by single circuit, so it does look like you do have one bad secondary. Are there four small blue caps close to the secondary side of the transformers that lead to the lamp connectors?
#17 |
#18 |
Yes, there are the 4 small blue caps.
#19 |
Please use the Ohm meter set to the highest scale and see if they are leaking on that bad section.
Let me see if I have the transformer at the recycling place, I will be working there tomorrow. I save some boards from monitors with broken screen. http://s807.photobucket.com/albums/y...pply%20boards/ Last edited by budm; 07-20-2012 at 09:05 PM.. |
#20 |
0.893 K ohms at secondary pins 1&2.
0.897 K ohms at secondary pins 3&4. Same for the 2 blue caps near pins 1&4 http://t.co/gbXoWzO Last edited by dcooke570; 07-20-2012 at 09:53 PM.. |
