Plasma 42V7 problem - please help!!!
  • scokljat
    • May 2012
    • 275
    • Croatia
    Hello!
    Recently I bought nonfunctional LG plasma TV model PDP42V706A2 using 42V7 plasma module. I bought it very cheap and I want to fix it for my parents house. I have good repair skills especially for laptops, LCD's and synthesizers, but this is first plasma I ever put my hands on.
    I have read lot of repair info on the web, forums, downloaded and studied LG service manual, so now I have some knowledge about plasma principles, parts, boards, voltages, signals and common failures.
    My 42V7 initially suffered from common “no picture – sound ok” problem. I took LG 42V7 service manual and started diagnostics and adjustments step by step. When I disassembled TV and measured all voltages (+5V, Vs, Va, Vsc, -Vy etc…) I discovered that almost all voltages are wrong like someone was playing with trimmers, probably some unskilled serviceman before.
    Then I started to measure and adjust voltages one by one, first +5V, Vs +187V, Va +65V on the PSU, then Vsc +120V and –Vy -75V on the Y-SUS board. When all voltages checked OK I started to get (jerky) picture on the screen!! I was very happy. I also experimented with VsetUP and VsetDN on the Y-SUS but I don't have proper oscilloscope to do it like service manual instruct.
    Now, most of the time picture is black (no picture) with maybe some light pixel noise and sometimes suddenly picture appear but it's jerky and darker then normal like some connection is loose and then sometimes very rarely picture is displayed 100% normal for a few seconds with full brightness, and then again it starts to loose to jerky then back to black and so on. More then 90% of time picture is black. I recorded a movie that greatly describes this condition.
    Video:
    http://www.youtube.com/watch?v=2tfF-iK0hYE
    Here are my notices and measurements:
    - all measurements done with standard TV picture trough HDMI and external DVB-T tuner (not with full white test signal like service manual says because I don't have signal generator)
    - all fuses are OK
    - caps look ok (no cracks, spills...)
    - PSU: +5V, +19V, +6V, +3.4V, +12V - OK!
    - Y-SUS: Vsc +120V, -Vy -75V - OK!
    - Z-SUS: +128V on FET output - not sure if it's OK???! My Z-SUS board does not have adjustment trimmer for Vzb or R23 resistor to measure Vzb. There are two types of Z-SUS for 42V7 module.
    - CTRL board: FET1 IC5 +3.3V - OK! FET2 IC3 +1.8V - OK! Didn't measure oscillator because I don't have 200Mhz oscilloscope (I only have 60Mhz oscilloscope)
    - on CRTL board three status LED's are ON (D3, D4, D5), two are OFF (D1, D2)
    - small heatsink on CTRL board (over IC9) is cold all the time
    - I cleaned all contacts, cables and connectors
    - after approx. 30 minutes of operation Z-SUS IPM heatsink gets hot, but Y-SUS IPM heatsink gets barely warm.
    - Z-SUS IPM produces more buzzing noise than Y-SUS IPM
    - when suddenly picture start to display some light clicks can be heard from Y-SUS board (probably IPM) and when picture appears (after black periods) buzzing noise from Y-SUS IPM is equal like Z-SUS IPM
    - I checked all 10uF/350V caps from Y-SUS (took all 8 of them out) they measured barely in 20% tolerance around 8.5uF, one of them was 7.5uF (put them back)
    - Y-SUS output diode check - OK!
    - Z-SUS FPC output diode check - OK!
    - Y-SUS IPM diodes check - OK!
    - Z-SUS IPM diodes check - OK!
    - sound is ok, MENU displays OK, program and AV input change OK
    - I can't adjust VsetUP and VsetDN as I don't have proper oscilloscope
    - for now I didn't replaced any caps
    Board P/N information:
    PSU: JPSU-J006A 1H251WI P/N6709V00010A
    YSUS: 6871QYH045C
    YDRVTP: 6871QDH094A
    YDRVBT: 6871QDH096A
    ZSUS: 6871QZH049A
    XRLBT: 6871QLH052C
    XRRBT: 6871QRH060C
    CTRL: 6871QCH066E
    Service manual:
    https://cdn.badcaps-static.com/pdfs/...fa21a8ae9b.pdf
    I see people buy and replace all three boards (Z-SUS, Y-SUS, CTRL) and solve problems, but I don't have budget for that, so I prefer repair on the component level on the affected board or if IPM is bad I'll buy and change only affected board.
    All help and information is welcome.
    Thanks!!!
    Cheers!
    Suad
    Re: Plasma 42V7 problem - please help!!!
    Possibly bad BGA chip on the control board. Common issue with this generation. Does it look like this? http://www.youtube.com/watch?v=UAzsasx8od8
    With a 60 MHz scope, you should be able to see a slight oscillation from the crystal. On my 100 MHz one, I can view 300 MHz FSB clocks, just about.
      Nevermind. Just noticed your video. If picture is DIM, sometimes purple-tinted and slow to update, your Z-sus is the fault 95% of the time.
      • scokljat
        • May 2012
        • 275
        • Croatia
        Tom, thank you for quick reply. My TV looks like one from your link (same model), but symptoms are different. On my plasma TV picture is black (or ultra dark) most of the time and then sometimes picture appear but it's flashing and it's jerky, and very rarely picture is OK for second or two... When picture appears there are NO missing lines or black bars, so screen, drivers and TCP cables are OK, I belive.
        I tried put some pressure to CTRL BGA chip, and bend a board a little but no difference.
        thanks!
        S
          With your scope, check Zsus output. 10X probe, 5V/div, 20ms/div. TV trigger works sometimes, if you have it.
          • electronicsurplus
            • Jun 2012
            • 210
            I am betting, although rare, the Y-Buffer
            can you check for shorts to ground on the connector end there will be many connections which go directly to ground and, some that do not, these are data (signal lines) and voltage lines to fire the plasma (Be careful because there is very high striking voltages coming through them)
            Because, on LG when a buffer goes bad it does not take out the Y-Sus, unlike Philips Samsung) and, because of this the Buffers are cheap and easy to find
            Jon
            Electronic surplus
            This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
            Help keep these from the landfills
              If a buffer goes, you will get random black lines, noise or no picture.
              • scokljat
                • May 2012
                • 275
                • Croatia
                Please, would you show me precisely where to measure Z-SUS output? You could use and mark one of my Z-SUS pictures.
                Thank you!
                S
                • scokljat
                  • May 2012
                  • 275
                  • Croatia
                  Jon
                  Electronic surplus
                  Which Y-Buffer connector are you referring to precisely? The large one with thin flat cable that outputs signals to plasma screen or ones that connects Y-SUS board and Y-Buffer boards?
                    Thank you!
                    S
                    Just on any exposed pads connected to the large flat brown connectors going to the plasma panel itself.
                      Picture of where to test, you could use a hook probe.
                      • scokljat
                        • May 2012
                        • 275
                        • Croatia
                        I checked Z-SUS output with a 60Mhz scope. As I'm no expert at oscilloscope reading, I recorded a movie and few pics so if you can take a look. When TV starts to show some picture, lite clicks are heard from Y-SUS board and oscilloscope reading on Z-SUS changes a bit at that exact moment... I think it didn't happen during this video. Please if you can guide me step by step through this scope process, as I'm not familiar with scope and this types of signals. I measured voltage on that same point - it's +128V. Is it Vzb?
                        Video:
                        http://www.youtube.com/watch?v=yXpuKc4Fveo
                        Thanks!
                        S
                          Nice Tek scope...
                          Vzb should be around 90V for these TVs I think, although when I played around with it, it didn't seem to make much difference. But your Zsus waveform looks pretty good. It is only a square wave really; nothing else.
                          Check Ysus - there is a test point "Yscw" I think - you can check the sustain output to the buffers there. Ysus wave is much, much more complex.
                          • scokljat
                            • May 2012
                            • 275
                            • Croatia
                            Hmm, where exactly to find that "Yscw" point on Z-Sus? Should I check it with a scope? I searched service manual for "Yscw" with no results... Take a look on Y-SUS picture, please.
                            Thanks!
                            S
                              Just the big metal connectors going to Y buffers One will be ground, the other will be the waveform you need to test.
                              • scokljat
                                • May 2012
                                • 275
                                • Croatia
                                I found what you say in service manual. It's "Vscw" and it should be tested at bead B39 which is connected to center big metal which goes to buffer boards. Other two upper and lower metal are not connected to ground.
                                Should I test it with scope across ground and B39 (center metal)? See pics...
                                Thanks!
                                S
                                • scokljat
                                  • May 2012
                                  • 275
                                  • Croatia
                                  OK, we have some progress here! ;-)
                                  I measured Y-SUS output wave with scope. It's obvious something is wrong with it! When picture briefly appears, wave on scope jumps. I recorded a video of this condition. Actually, that was longest burst of displayed picture I ever got on this broken plasma.
                                  Look at the movie:
                                  http://www.youtube.com/watch?v=UTkkJBE5FdM
                                  When picture is near black voltage is 135V-155V, but when picture is briefly displayed perfectly voltage jumps to 190V and clicks are heard from Y-SUS and IPM get normal buzzing noise! Something like IPM is switching on and off...
                                  What do you think?
                                  Btw, picture is little bit "slow" I believe because misadjustment of VsetUP and VsetDN.
                                  Thanks!
                                  S
                                    Does your scope have a pulse-ramp rate trigger? Try triggering on the slow VSET ramp; it ramps up over several microseconds.
                                    It sounds like your Y-sustain is faulty. This issue can be caused by a walking-wounded IPM.
                                    • scokljat
                                      • May 2012
                                      • 275
                                      • Croatia
                                      Hmm, Tom, I'm really an oscilloscope dummy ;-)
                                      Could you please precisely describe what to do and where to measure? My oscilloscope is Tektronix TDS210 60Mhz. There is alignment tutorial for VsetUP and VsetDN in service manual that requires triggering with trigger probe to VS-DA point on CTRL board. Did you mean that?
                                      Thanks,
                                      S
                                        My work place has the 100 MHz version of that scope. I *think* it only has edge and video triggers. But yours may be slightly different. Press TRIGGER MENU and see what options you get. You can still get a decent trigger without, just requires playing around with the HOLDOFF control, which this scope definitely has (had to use it on one circuit with a data line with varying frequency.)
                                        • PlasMatt
                                          LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                                          by PlasMatt
                                          I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                                          09-20-2025, 06:50 PM
                                        • KYBOSH
                                          Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                          by KYBOSH
                                          Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                          No picture but you hear the TV static (white noise) playing loud and clear.
                                          The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                          But it seems they didn't get too far and just left it.
                                          When I first took a look I was amazed at how pristine the inside looked.
                                          Its as if the TV had been in a time capsule.
                                          Caps looked like they were just pulled off the self.
                                          Copper coils had no sign of corrosion on...
                                          02-01-2023, 11:10 PM
                                        • KYBOSH
                                          Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                                          by KYBOSH
                                          Saved this beast from the landfill this weekend.
                                          Manfactured July 2013 in Mexico.
                                          I love working on plasma TVs.
                                          Its been a while but I was lucky enough to find 2 this week.
                                          The TV powers on and stays on but no picture. Havent checked for sound yet.
                                          No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                                          Will start troubleshooting tonight.
                                          10-17-2024, 01:17 PM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
