Samsung LNS4692DX has backlights but no picture
    Check the CP (fuse) on the T-CON board. I replaced it with 3A PICO FUSE.
    Very simple fix for 46". The repair shop told the owner that it needs fuser! and wanted $250 to repair it. Going to let it burn in for a couple of weeks.
    Re: Samsung LNS4692DX has backlights but no picture
    I have encountered the same issue before - just a fuse blown - seems common on the old Samsung "LTA" LCD panels. The fuse is too small and blows after about three years, maybe up it to 4 or 5A.
    Looks like an older Samsung TV there - never seen a 2 layer PSU in an LCD from Samsung before... And 24V for inverters, very strange...
    • lilmonk3
      • Apr 2012
      • 259
      Budman.. Was your screen glowing white or bluish??
      • Tvtechtx
        • Mar 2012
        • 1
        • Harris
        What fuse did you change out on the tcon
          I use through hole Littlefuse PICOII fuse, just bend the leads.
          • Genosphere
            • Nov 2012
            • 1
            My tv just went dead and seems like it might be the fuse too, i hope thats all.
            When you say the CP fuse do you mean the one directly to the left and between C18 & C14 of your last image budm?
              The little device under CP1 and above VIN is the fuse.
              • neilc6
                • Nov 2015
                • 1550
                Purchased this model based on this and other threads indicating a high likelihood of just a blown fuse. TV has a giant shield covering all the boards. First found 3 bulged 1000uf/25V Capxon caps on the power supply. Tcon was a little tricky to remove since it is blocked by a shield and part of the frame. You need to peel back the foil to access the flex connectors and unscrew enough of the frame to slide the board out. The fuse is 0603 and disintegrated when I tried to remove it. I replaced it with a 1206 3A fuse from another tcon board.
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  You replaced the bulged caps and replaced the T-CON fuse.....The set is now working???
                  • neilc6
                    • Nov 2015
                    • 1550
                    Yes, it is working but haven't had time to leave it on for a couple of hours.
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      Great!!!...When you get time let it run for 4hrs 'burn-in' and share result. Thanks.....
                      • sordids999
                        SAMSUNG UE43AU7020K BACKLIGHTS BUT NO PICTURE
                        by sordids999
                        Hi
                        Really stuck on this TV
                        I'm thinking it's a bad screen ?
                        Voltages all seems good
                        Tcon 12v ok
                        Remove one tcon cable at a time no half image on the screen just backlight and no picture
                        even tried the tape trick still no luck
                        Thanks...
                        05-12-2025, 10:36 AM
                        09-07-2024, 05:50 AM
                      • TR103
                        by TR103
                        - it keeps rebooting
                        01-22-2025, 04:12 PM
                      • JJAAMM
                        by JJAAMM
                        Problem
                        07-06-2023, 06:01 AM
                      • stinger
                        Samsung UN70TU6980FXZA no sound no picture but does have backlights
                        by stinger
                        When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                        04-17-2024, 03:06 PM
